Results 1 to 10 of 10
    Veteran Member Four Rings boy412's Avatar
    Jul 15 2007
    2015 Golf Sportwagen TDI, 1988 Alpineweiß 325iC
    Mount Rainier, MD
    What to do with old control arms?
    I was going to make a little tree out of them for the garage...but figured there must be a better way to put them to use. I know some have just replaced the bushings and re-used the arms themselves. Are they of any value to anyone?
    I'd be willing to give them away for nothing...I just don't want them to end up in a landfill somewhere. My other thought was to take them somewhere that accepts scrap metal?
    PM me if you want them (just pay shipping). They came off a '03 A4 1.8T and the bushings are all pretty shot. The boot on one of the UCA's got wrecked by a pickle fork but the others are OK. This is both upper and lower control arms.
    ~Eric
    SOLD: '03 Ming Blue A4 Avant 1.8TQM | GTRS | MTM cat/exhaust | Maestro | Spec Stage III+ | Vogtlant GT's | JHM trio | STE PPD | OEM+
    Veteran Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    i posted up mine with all the mounts (tranny, motor, rear) for 50 bucks .. nobody bought them .. posted them up for free and had someone come the same night lol
    Jul 15 2007
    Mount Rainier, MD
    That's more or less what I'd like to do. I'd rather someone got some use out of them instead of just chucking them in the trash.
    ~Eric
    Feb 03 2007
    Audi A4 b6 1.8T Avant
    Port Elizabeth, South Africa
    You don't happen to know where to get just the bushings??
    I'd take your set of arms if I could find bushes from a reasonably priced importer( I'm in south africa and they not locally available)
    (Idea is to put the new bushes on while out of the car and then replace them as a unit)
    Any ideas?
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Got a TIG machine? Make them into a mascot for your garage.
    Dec 05 2007
    When I replaced my control arms (replaced all lowers when just one of them was bad, and didn't do the uppers yet), it wasn't the inner bushing that went bad. It was the outer joint. Just a heads up if someone wants to go the route of replacing the bushing and not really thinking about the outer joint. It would be better to replace the entire arm, and not just a bushing.
    Jun 30 2008
    Erie, Pennsylvania
    The joint is what makes them rattle. That is the major failure point on these. Sure, the bushing get a little torn here and there, but it is ball joint play which dictates replacement for state inspection and such. You can test them for play pretty easily off the car. If the ball joint is still nice and tight and the boot isn't ripped, it might be worth it for somebody to reuse. But if there is play in the joint, even a little bit - it's junk.
    At our shop we throw these arms in the aluminum scrap pile and we take it all in about once a year.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    ^. Chucked mine in the aluminum recycle bin at work.
    Dec 25 2004
    Earth
    recycle bin...
    Oct 08 2009
    Mass
    Aluminum is only around $.50/lb. Not worth it for just a few control arms.
