Results 1 to 4 of 4
    May 21 2011
    Ca, fontana
    Angry valve cover bolt broke. any advice?
    I was tightening a loose bolt that holds the cam cover down when I went to far and snappped itHave any advice on using an easy out for broken bolt removal or is it easier to take it to a machine shop and have. them take care of it. If I do decide to do this what sealent would you recommend OEM or aftermarket. Any advice is welcome or point me in the right direction. Thank you.
    Jun 27 2011
    Just use the black RTV sealant from your local auto parts store. The insanely expensive OEM sealer is unecessary.
    ECS sells Valve cover studs I believe. You'll be fine driving without one stud for a little bit but get it fixed asap. Machine shop might be easy, but possibly expensive.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    May 21 2011
    Ca, fontana
    Thanks for advice. I'll more than likely take it to a machine shop since I don't feel to confident on using this easy out tool.
    Oct 14 2009
    Okinawa Japan
    It really depends in how much of the bolt is sticking up.
    If it were me, I would remove the valve cover (15-20 mins) and take a peek at that bolt, there's a lot of 10$/20$
    Tools designed specifically for stud removal that you can find at most automotive or hardware stores.
    If it was me I would prob get some big vise grips and get a good hold on the sucker and spin it out...
    My .02 make sure to update the thread :-)
    -Shane Drake-
    2006 A4 Avant Dolphin Grey
    2007 GT3071R A4 Moro Blue-RIP
    >DRAKLOREs Build<
    Formerly DRAKES-PERFORMANCE
