Results 1 to 11 of 11
    Nov 05 2011
    vegas
    bright green fluid leaking by front differential
    a bright fluid is leaking by the front diff. not sure what it could be thought it could be coolant that dont belong in there cause theres some by the firewall on top of the trans i think, and the hoses are all deteriated from the inside could coolant thats not g12 do that?? need help fast pls and thanks
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    What color is the coolant in the reservoir?
    Probably a bad coolant flange.
    Veteran Member Three Rings Lornnn's Avatar
    May 01 2011
    Pe
    or simply the o-ring surrounding the temperature sensor..
    Nov 05 2011
    vegas
    mike i dont see any coolant in the reservoir and the reservoir is discolered planning on buying a whole new 1 but need to find where this leak is coming from like badly so i can get it running, thanks for your help both you ima check and see if those are any of the probs and will get back to you and let you know again thanks for your help
    Jul 01 2008
    Minnesota
    Green= power steering fluid or air conditioning PAG oil if it is fluorescent green.
    Pre-99 1.8
    May 01 2011
    Pe
    Quote Originally Posted by LVSVAG View Post
    i have a feeling the previous owner put PEAK or some other green coolant in it
    flush whatever might remain of your coolant and fill with the right G12 mixture first before you go buying parts
    here's a DIY if you need help with that: http://www.audizine.com/forum/showth...h-Your-Coolant.
    as far as your leak, what is your car? 1.8T, 2.8?
    Nov 05 2011
    vegas
    coolant res. is empty suspecting some kind of leak there.
    also its a 1.8t...
    and the fluid is fluorescent green
    also alot of the hoses look like they been rotting from the inside...
    Veteran Member Three Rings hazard860's Avatar
    Aug 22 2011
    1984 gti, 2001.5 s4 (stg3)
    Lebanon, CT
    florescent green, almost yellowish, im going to say a/c fluid, freon..
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Just use distilled water in the reservoir to help diagnose. Chances are, if the reservoir is empty, and you didn't know what was in there before, then it probably is the green stuff.
    I personally run G5.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Nov 05 2011
    vegas
    alright soor y to get back so late.. so i did the coolant flush and theres no leaks there, so ima assume its the a/c but how would i find the leak there??
    Jun 30 2008
    Erie, Pennsylvania
    You would take it to a place for A/C service and pay them cash dollars to fix it...basically. They have special tools to pinpoint refrigerant leaks, and more special tools to properly evacuate the system, repair it, and refill it.
    If you want to save money and do the part-changing yourself, you can take it there, have them find the leak and evacuate the refrigerant. Then take the car home and change out the leaky part yourself (probably the condenser or compressor). Return to the shop for a refrigerant refill.
    I'm kind of wondering how you are leaking refrigerant oil near the axle, though. That's kind of odd. The common leaks are at the condenser (from rock damage, etc), compressor itself, or various line fittings/o-rings. There's not any A/C stuff that runs very near to the axles or transmission.
