Results 1 to 16 of 16
    Feb 14 2011
    Cleveland, OH
    Drive Select Individual settings for snow?
    Was thinking to set up the individual setting to be a "snow" setting. Thoughts...
    Steering - dynamic
    Sport diff - dynamic
    Power - comfort
    Veteran Member Four Rings PsYkHoTiK's Avatar
    Aug 23 2010
    Redmond, WA
    I don't think it'd make a difference really (unless ADS has a "tire grip" setting)... But the above is what I drive in all the time (well "Power" set to "Auto"). Set in MMI and VAG COM'd to default to Individual (thanks NWS4Guy - lol)
    Current: 2022 Audi RS6 | Ultra Blue | 034 Lowering Links | 034 Resonator Delete
    Old: 2017 Chevrolet Corvette Z06 (Z07) | Blade Silver
    Older: 2013 Audi RS5 | Sepang Blue | Eurocode Alu Kreuz | 034 Transmission & Rear Diff Mount | Apikol Diff Mount | Girodisc 380mm Rotors | H&R RSS+ | SPC Upper Control Arms | H&R sways | AWE Track Extreme exhaust
    Olderer: 2011 Audi B8 S4 | Ice Silver | DSG | Sport Diff | APR 93 stage II+ V2
    Veteran Member Three Rings Zed 2.0's Avatar
    Feb 12 2010
    San Diego
    I'd think that "comfort" all around would be the most conservative for slick conditions. By setting the sport diff to dynamic, you're telling it to allow the back end to step out more, and more quickly. The sport diff will still be active in "comfort" but it will gravitate towards safer understeer. The steering input won't matter too much unless you have the full drive select (in which case, the lower ratio comfort setting is probably the best, as you can be more precise in your inputs and less likely to over-correct).
    Veteran Member Four Rings apexit1's Avatar
    Jun 04 2010
    northern nj
    I have full ADS and drive in Comfort for the snow. If it's anything but super rainy or snowing I drive in individual set completely to dynamic.
    Jul 11 2011
    2021 Ford F-150 Lariat PowerBoost
    Quote Originally Posted by Zed 2.0 View Post
    I agree...
    The sport diff definitely reacts to the mode it is set in regardless of the traction. On slick surfaces I've had no problem getting the rear end out on even light throttle input (with snow tires), followed by the stability control reacting sharply to reign it back in - much like a modern RWD car. I've found the best mode for snow/ice is Comfort - if you don't mind the overly light steering. This way the sport diff can't get you into too much trouble.
    2022 /SQ7 P+ | Daytona Grey Metallic | Executive Pack | Carbon Inlays | Driver Assistance | EA825 4.0T (IYKYK)
    APR Stage 1 685+ HP (Planned)
    Gone But Not Forgotten
    C7.5 S6 - Moonlight Blue
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
    2008 V10 TDI Touareg II - Floret Silver
    2006 V10 TDI Touareg - Reed Green
    Veteran Member Three Rings dawei213's Avatar
    Oct 05 2011
    Philadelphia, PA
    off topic but can using the Vag-com default the ADS to your individual settings when you start the car? I hate to always have to select it to the Individual setting.
    2012 S4 | REVO - Stage 1 | AWE Resonated Exhaust | BILSTEIN PSS10 | Eurocode Alu Kreuz | ALU FELGEN SF-71 HB 19x9.5 | H&R Spacers 15/20 | 20% Tint
    Jun 04 2010
    northern nj
    Yep, this is why we need a sticky. Heres the link.
    http://www.audizine.com/forum/showth...?highlight=vag
    Oct 27 2009
    Miami, FL | Boone, NC
    Quote Originally Posted by apexit1 View Post
    Why wouldn't you just put it in Dynamic instead of putting it in Individual and setting everything to Dynamic?
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Active Member Two Rings Audihopes's Avatar
    Jan 28 2011
    Chicago, IL
    I would agree with everyone so far, the rear diff on low traction can be overly aggressive. On snowy or potentially icy conditions i shoot for:
    Steering: normal or dynamic
    Throttle: normal or comfort
    Diff: comfort
    Suspension: comfort
    From what I hear, when driving in low traction conditions you want everything to be as progressive as possible, hence the comfort setting on suspension and rear diff. With the throttle in comfort I find myself over-reacting constantly thinking its not responding when in reality its just responding more smoothly and slowly, hence the normal or comfort for me. Steering is mainly a personal preference imho
    2010 B8 S4 | Ibis white | MT | ADS | Hartmann RS4 Reps | No mods yet
    Jun 04 2010
    northern nj
    TBH, I didn't look into what settings dynamic used. I looked at the individual settings and went to town. Does the Dynamic keep everything in dynamic?
    Veteran Member Four Rings tomh009's Avatar
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Quote Originally Posted by CJ_S4 View Post
    I would prefer to keep stability control switched off. At least if I'm planning for some fun in the snow!
    2012 S4 · 6MT · Glacier White/Black Nappa · sport diff · navigation · black optics · BBS RG · TT-RS steering wheel
    Jul 11 2011
    Quote Originally Posted by tomh009 View Post
    Haha...correct! If lurid powerslides and AWD donuts are your goal then by all means leave in dynamic and turn off stability control!! I haven't had the chance to get too wild yet.
    8V S3 - Nogaro Blue
    B8 S4 - Ibis White
    Jul 10 2010
    2004 GTI 1.8T
    Canada, eh
    Controlled sliding is my goal. For fun, I always drive my A4 with stability control off, and I expect to do the same with the S4. On the other hand, getting to work etc with a heavy snowfall I'll have the stability control back on.
    Oct 27 2009
    Yes.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Yes.
    LOL
    Jun 04 2010
    northern nj
    damn lol
