Results 1 to 35 of 35
    Established Member Two Rings mishonio's Avatar
    Nov 10 2011
    Audi A4 6MT, VW jetta GLX
    san fran
    Does 2010 Audi Q4 Quattro need snow chains for Tahoe?
    I have the original all season tires and they have less than 15K miles on them. Also on Tahoe, Cal Tran do a good job cleaning the snow - if it's too much they close the highway.
    Please advise. If chains are needed, Pls advise what type to use, and whether I need chains for all wheels or just the front two.
    Thanks,
    Michael
    Oct 09 2008
    You will not need chains.
    The Awesome™
    Senior Member Three Rings Speycaster's Avatar
    Aug 16 2011
    2006 Audi A6 Premium (Wife's); 2008 Chevy 3500 Club Cab Duramax Diesel; River Wild, Custom Jet Sled
    Roseburg, OR
    No chains. If it is so bad that CalTrans will not let an AWD vehicle with snow tires pass, they will close the road. Now Oregon is a different matter. The only time I have ever seen a read closed in Oregon, it was either under water or had a mud slide.
    2010 2.0T 6MT, APR Stage 2 ECU flash, APR turbo back quad exhaust, APR Carbonio intake, Eurocode HFIP, Eurocode Intercooler Hose Kit, 034 Turbo Inlet Hose High Flow Silicone, E-Code Xeon head lights, Various Vag-Com changes, H & R Coilovers, Hotchkis H-Sport ARB's, Eurocode Alu Kreuz Billet Aluminum Drivetrain Stabilizer, Stratmosphere Hypershift short shifter, TyrolSport Brake Caliper Stiffening Kit, S-Line Side Blades, 19" x 8.5" Hartmann Euromesh 3-GS:ML wheels, 255-35-19 Toyo Proxes 4 Tires
    Jan 24 2008
    West Coast
    You guys need to look up California LAW before just randomly chiming in. California law REQUIRES that chains be carried at ALL times, regardless of FWD/AWD/4WD. If you have snow tires and awd, you'll probably be ok in the snow (depending on depth), but you still have to carry chains. It's the law. When you are stopped on HWY 50 or HWY 80, they will ask if you have chains and sometimes will actually look to verify. That said, if they don't verify and you happen to spin out and CHP has to pull you out, you'll receive a ticket for not carrying chains.
    Moderator
    Veteran Member Four Rings MilesM's Avatar
    Jan 17 2011
    RSQ8
    LA / SF
    +1 to Dan's comment, but please check the regional forums as well.. Tahoe specifically is one of our topics at the moment in the Southern California region.
    Aug 16 2011
    Roseburg, OR
    He asked if he needed chains. Not what the law was. He may only be going up there once in a blue moon, and might want to take the chance that it will either not snow, or that he will not be asked by the CHP. He IS going to Tahoe, he might WANT to take the gamble.
    Nov 10 2011
    san fran
    Since I go to tahoe a lot, sounds like I will need chains. In this case what type to buy and how many are needed for an Audi A4 Quattro?
    Thx
    M
    Nov 10 2011
    san fran
    Quote Originally Posted by mishonio View Post
    Thx
    M
    I need them because as it seems the CA law requires them...
    Jan 17 2011
    RSQ8
    LA / SF
    I've been going to Tahoe my entire life, if you NEED chains in a quattro car, you shouldn't be on the road regardless of your setup.. That said, it is required by law that you atleast carry some, so personally I just carry a set of the cheapest chains I can find in case I get questioned by CHP.
    Nov 10 2011
    san fran
    Do you have 2 pairs for the front and rear wheels or just one for the front ones?
    Veteran Member Three Rings vtheman's Avatar
    Jul 09 2011
    Crown Vic Interceptor
    California
    The Ca law does state that you have to have chains but the reality is in the past 10 years I have never been asked to show or install chains on my Audi or any other AWD vehicle and I have driven trough some pretty bad storms. If I were you I would have a dedicated winter setup. With factory all season tires with 15k on them you are pushing it. Check Craig list, I recently got a killer winter wheel/tire set up.
    BTW: look up Spikes-Spider.
    Nov 10 2011
    san fran
    I have 1 pair of spider spikes for my other car. For an Audi quattro, do I need to have spider spikes on both the front and rear wheels?
    Veteran Member Three Rings routertyty's Avatar
    Aug 09 2010
    Honda Mini van
    Menlo Park, CA
    I've driven to Tahoe countless times in my B5 A4 quattro and never has the chain patrol stopped me for chain inspection. Of course, the wise thing to do is have a set of winters on, then chains as a backup in case it gets really bad. Of course, i've never been stuck in my A4 either. All season tires worked great for me.
    Has any one ever used these?
    2011 Meteor Gray - A4 2.0T Tip Quattro Prestige & Sports
    Alu Kreuz Drivetrain Stabilizer • Eurocode Sways and End Links • Weather-Tech Mats • Hüper Optik 50% • S-line Stone Guards
    LED License Plate • VAG-COM'd • Sun Shades • B&O Stereo • OEM Chrome Tailpipe • 034 Silicone Turbo Inlet Hose
    Jun 02 2009
    San Francisco
    Quote Originally Posted by Speycaster View Post
    And he needs chains, so says the law.
    Jul 09 2011
    California
    I would assume you'd need 2. But for the price of 2 sets of Spiders you can get a pretty good winter wheel/tire setup :) In fact I was in the same situation you are now. I have 15k on my original tires and I would not take them anywhere near the snow in their current condition (and I am very experienced winter driver). I've tested them in the snow for the past 2 years and I can tell you that they are mediocre in the snow. Nothing will ever substitute dedicated snow tires. BTW: Don't know how true this is with the Audi but some car manufacturers will void your warranty if you use chains.
    Mar 02 2007
    Fresno, CA
    Slightly off topic, but has Tahoe even gotten enough snow to matter at this point? Pretty dry season so far...
    Jan 17 2011
    RSQ8
    LA / SF
    There's snow on the ground, but the mountains are still making snow.
    Jan 24 2008
    West Coast
    Iknowright?
    Yep...dry so far. But still a La Nina pattern for the weather. They're still expecting it to be 33% wetter/snowier than "normal."
    My Tahoe trip, as of right now, is scheduled for February 6-12. There will be snow by then.
    Moderator
    Nov 19 2011
    Sacramento, CA
    I have lived in and around tahoe for my entire driving life.
    I've owned wagons (first subaru, then bmws, now audi) that are AWD, and I've NEVER been asked to see chains or install them.
    On time, driving home from king's beach to reno, they had the "4wd with chains required" for local travel only. That is the only time i've seen that in hundreds of snow driving days.
    Even then, I pleaded with them to allow me through, and they did, without much fanfare.
    Jan 24 2008
    West Coast
    ^ Good to hear, Jed.
    I lived in Tahoe for 20 years. Graduated from South Tahoe High. It doesn't change what the law says...
    ...but whether you need to put the chains ON or not is a different question. It's easier to just be safe.
    Moderator
    Jan 17 2011
    RSQ8
    LA / SF
    Dan I'm surprised you don't know my dad, he went to UNR and lived in Incline for years haha. Of course I'm assuming you guys are about the same age.
    Aug 16 2011
    Roseburg, OR
    And you've never driven over the posted speed limit; which IS the law;(
    Jan 24 2008
    West Coast
    Quote Originally Posted by Miles M View Post
    That's hilarious that you think I'm THAT old, Miles.
    Moderator
    Jun 02 2009
    San Francisco
    <- 2mph below the posted speed limit, eyes straight ahead with hands at 10 and 2 at all times.
    Jan 17 2011
    RSQ8
    LA / SF
    Hey, even people in their 20s are old to me Guess that's a no on knowing him! Lol.
    Jan 24 2008
    West Coast
    All us Avant owners drive like granies...don'tcha know?
    Avant5.21-2 by DPBPHOTOS, on Flickr
    Moderator
    Mar 02 2007
    Fresno, CA
    I just came in here to say something similar about your perspective.
    Dan, you lived in Tahoe longer than Miles has been alive, so go figure...
    Veteran Member Three Rings rippin'av's Avatar
    Nov 18 2009
    '00 S4 Stage 3, '05 LR3, '08 ML63 AMG, '02 BMW 1150GS, '71 BMW R75/5
    CA
    I've driven up in the Tahoe area every year for the past 20 years and I've never been asked to stop and get chains on. I have had a few Audis (A6, Q7 and now B8) and have never been questioned. A solid all-season will get the job done as long as you're not plowing through deep snow. For a day/weekend trip you're fine without a dedicated snow tire. The checkpoint guys see the four rings and just wave me past. The law says you need to carry chains, doesn't mean you need to use them. Read the owner's manual but I think it is not recommended to use them on these cars. I know it voids the warranty on my land rover if I use chains.
    Theres not enough snow up in Tahoe now on the roads to worry about anything. They do a great job on clearing the roads.
    Sh!t...last January I rode my BMW 1150GS motorcycle (with knobbies) through Tahoe and Reno areas on my way down to the 395. There was ice and snow everywhere but the road was fine. If I can make it in a 1WD you can make it in a AWD, lol...
    2015 Jeep Unlimited Rubicon
    2000 S4 6MT ASP Stage 3
    Veteran Member Three Rings formula1guy's Avatar
    Apr 14 2009
    B8 A4 Avant S-line,2010 A4 prem + w sport package
    Northern California
    I know my post is the same as some others but regardless of what CA law states, i've never once been asked to put chains on any of my quattro cars when heading to Tahoe. When driving through chain control check points, they've waved me right on through. Must be the rings:)
    Watch, this will now be the first year I'll be turned back (I don't own chains) so maybe I better get some just to be safe.
    Active Member Two Rings sgary1's Avatar
    Nov 25 2009
    2012 S4, 2007 A4 3.2 Cab.
    Grass Valley, CA
    The owners manual states that if you must use snow chains they are to be used on the front tires only and the links must be no larger than .53 inch. It also says they shouldn't be used with certain tire sizes and to check with the dealer. It doesn't say anything about cables. As others have said, buy proper chains or cables so you are legal. You probably never need to use them. I live in the foothills of Sacramento, I have never needed chains on my many trips to Tahoe each year. Just make sure you have good all season or winter tires.
    2011 A4 Avant P+ Ibis White Ti Nav
    2012 S4 Prestige 7spd Ibis White Ti Nav Sport Diff B&O Side Assist Side and Rear Shade
    Nov 10 2011
    san fran
    Thanks to all for all the info. So, as I thought on an A4 quattro in the rare cases when chains are required, they need to be installed on the front wheels only
    Happy Holidays!
    Veteran Member Three Rings NickZag's Avatar
    Feb 22 2010
    2006 S4 Avant
    Northern, CA
    Turn 3A at Infineon?
    2021 A4 | 2006 S4 Avant
    Senior Member Two Rings B8SlineNate's Avatar
    Mar 15 2010
    Northern California
    Quote Originally Posted by routertyty View Post
    i'm curious about this also
    2010 B8 S-Line Avant Prestige w/Driver Assist
    Feb 19 2010
    Newbury Park, CA
    I still don't think it has snowed in Tahoe much this year. Very dry.
    I have had good luck with these low-clearance cable-type "chains" on some of my other cars: http://scc-chain.com/Traction%20Pages/Trac_SZLT.html
    - Mike
    2013 Audi Q5 2.0T / 1986 Porsche 911 Turbo (West Coast Editor for Autoblog.com)
    Nov 10 2011
    san fran
    Well I am definately buying winter wheels.
    That's because according to tirerack, the Pirelli P6 all season tires installed by Audi on many B8s with 18" wheels are no good
    Click on the Survey tab
    http://www.tirerack.com/tires/tires....0&autoModel=A4 2.0 Quattro&autoModClar=Premium Plus
    Why did Audi pick them is a mystery...
