hey guys. When I started my car this morning I immediately got 3 beeps with no associated warning light. Tried again and got the same thing. I checked my oil level and it was extremely low. Since I was in need of a oil changed, I figured I would just do it. I checked how much oil came out and I only had roughly 1.7 quarts
and there was no oil pressure complaint in the past few days. But even after the oil change (now with the appropriate level of oil), the I still get the 3 beeps with no associated light. I checked the fluid levels and topped off the coolant, but still get the same problem. I also vag-com the car and got HVAC, Airbag, and Radio fault codes that were already around in a previous scan.
I did unplug the coolant sensor jsut to see if it would show the warning light for that. What happened was that i would first get the 3 beeps immediately after starting up the car, and then a few seconds later get the 3 beeps complaining about the temperature (with the picture showing on the panel).
I've also read about the low main battery, and alarm battery problem, but the battery level seems fine so far. For the alarm battery problem, the 3 beeps sound like the normal 3 beeps when you have a low oil pressure and not really like the alarm arming beeps.
any help would be appreciated.
thanks
