Results 1 to 13 of 13
    Oct 12 2011
    WA
    What is an acceptable level of oil in the K04 housings?
    I recently helped pull apart a stg3 and noticed that there was oil in the bi pipes, throttle boot, and a slight film in the throttle body as well. The engine was yanked out and I noticed no shaft play what so ever, but on the hot side, I noticed oil in there as well. I just pulled the bi-pipes on my bone stock k03s and everything was super dry..
    K04s have about 25k on them. Is it normal to have oil blow by on the hot and cold side of these?
    01 Nogaro 605, AMD tuned with custom no-mod list signature.
    May 02 2008
    2001.5 Audi S4
    Long Island, NY
    From what I understand this is normal, but it is also why people get an oil catch can.
    May 13 2011
    2015 BMW F30
    Normal.
    | Autospeed | JHM | Pure MS
    Oct 12 2011
    WA
    thank you guys.
    Sep 17 2005
    Fremont, California
    Bit if a blanket statement to just say normal, but a film of oil inside the intake and charge components is very normal.
    How much oil is acceptable in the turbine housing is generally dependent on whether the car smokes under boost, etc. Shaft play isn't the only indicator of an oil seal condition, but it certainly helps.
    From the sound of your description, everything sounds normal. Depending on the effectiveness of the breather system and other factors, some cars have more oil in the intake then others. I often encounter oil in the turbine housing when removing and reinstalling turbos.
    Oct 12 2011
    WA
    Gotcha. I'll go get them checked out prior to the install. They looked to be alright but I'm not a genius at this..
    Mar 10 2009
    il
    Would the oil film be beneficial to engine operation?
    Deactivated Two Rings
    Nov 15 2011
    Escondido
    The oil is typically not from the turbo itself but from the valvetrain, i.e. valve cover vents, and crankcase vents.. this will usually cause oil to flow into the intake system. Oil from the turbo will usually flow into the hotside and create white smoke out of your exhaust before it will flow into the intake stream since the only thing that region would be the cold side fins. Oil catch cans is good way to create less oil blow by. Look into doing that if it bothers you, and no its not beneficial for oil to be in the intake stream as it will eventually get sent into you cylinders and create buildup on your pistons and valves.
    Jan 29 2006
    b5 s4 stage 3, 4runner
    livermore
    my car will smoke under boost (22psi). my ft's only have 1400 miles on them
    May 23 2007
    What does smoking under boost indicate and why does it happen? My gt's lay a smoke screen under boost and im losing a lot of oil because of it.
    Nov 15 2011
    Escondido
    Quote Originally Posted by bs6x View Post
    Could mean you have bad valve seals or your turbo (s) may be going out
    May 23 2007
    Any way to confirm which it is?
    Oct 12 2011
    WA
    huh, all really good information. Hopefully I can take a look at the valve seals on the engine that these are coming from.
