Results 1 to 8 of 8
    Senior Member Two Rings alimo20's Avatar
    Jan 25 2011
    Philly
    would a stuck open thermostat trigger the check engine light?
    i'm pretty sure my thermostat is to blame for the very long warm-up period. i did a coolant flush and something must have screwed the coolant system. was wondering if a check engine light would come on for a stuck open thermostat..
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Or maybe it's just the really cold weather we've been having...
    Jan 25 2011
    Philly
    it started 3 weeks ago, when it was much nicer out..
    Jun 27 2011
    No it wont. My B7's thermostat is stuck open and no MIL. Doesn't even throw a code.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Yes it will, mine was bad and when I removed it I noticed it was broken and stuck open. The CEL associated with it was for cooling system. This also caused slow warm up and never truly warmed and stayed at mid position on the temp gauge. When it was colder than 40 degrees it would also stall out from time to time in the first 10 minutes of driving when I came to a complete stop or shifted from neutral to 1st gear.
    Jun 27 2011
    Oh really? weird. Mine doesn;t even throw a code. I know its bad though. Strange...
    -CP
    2017 Q7 3.0t
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    The CEL was associated with the difference in coolant temps at cold idle and running, not an actual CEL for just the T-stat. Changed sensors first which left only the T-stat. Yours maybe partially stuck, mine was 100% wide open.
    Jun 27 2011
    Quote Originally Posted by pondside36 View Post
    I actually don't know. When I logged measuring block 130 and 131, the only reading it spit out was the Engine temp. Everything else was blank, including the Thermostat duty cycle, which shows the opening percentage of the T-stat.
    -CP
    2017 Q7 3.0t
