The stock headlights are almost impossible to open so retrofitting them seems to be more trouble than it's worth. I haven't tried to separate the lens on the housing because i can't really risk it. I've wondered for a long time if there were any clear lenses that are a direct swap for these projectors and i stumbled
upon a thread where a guy had done a tsx-r lens swap and also a thread on how to do the lens swap by removing the projector from the rear of the housing instead of opening the headlight housing. This was the way that i went about doing this and it was actually really easy.
I took step by step pictures of the whole thing but I won't bore you with those unless you're really wanting to see all of the steps. I'll post a link the the writeup and then if you guys need any help, i'd be glad to help however i can.
I'm sure you guys are tired of reading and want to see the pictures so let me show you guys what i've got. Some of the pictures are crap from my phone since i don't always have my 7D with me. Some may also be huge so I can resize them if that's the case.
Here's the difference between the lenses
Old lens...bleh
New lens!
In this picture, the right headlight is obviously with the old lens. Believe it or not, my right projector was the better of the two.
They're only aimed like this to show the difference. That wall was a bad wall to compare the two on because it doesn't show how
bright they actually are. I should have used a white wall but I couldn't find one near my house and was trying to beat the rain.
Lots of color in the stock cutoff but so blurry...I hated it.
Here are my terrible iphone pictures but they show the beam well on the wall.
These pictures are crap but decently show how blurry it was before.
That's really all of the pictures i have for now. None of these pictures do these lenses justice.
$40 and it's like driving a brand new car. By far, the best $40 i've spent in a very long time.
Definitely worth the money and time it takes to do the job.
Here's that thread: http://www.audizine.com/forum/showthread.php/411463-Fix-for-weak-headlights-in-stock-Valeo-housings
I also, retrofitted projectors into my fogs. I'll leave you with a little teaser until i make a post on those.
