Results 1 to 40 of 48
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    DEPO LED A1 Style Smoked Headlight - REVIEW
    As a few of you know, DEPO came out with a new style of and aftermarket headlight for the B6 A4/S4 cars. These come with a solid white LED strip that traces the outer edge of the headlight. It also has a yellow LED strip that's used for the turn signal. Companies on eBay and here on AZ (Pars4Euro) are also selling it with a HID kit. The description of these lights also mention that they come with auto level motors to make them compatible with those that use them (those who's cars came with factory xenons).
    Nobody knew if they would look ok on the car or not. So like I did before, I bought a set to try and give as much info as possible so that you can make your own informed decision. There are 2 choices of headlights to buy....
    Chrome:
    Or Smoked:
    I opted for the smoked headlights. Placed the order and got them a week later. Decided not to go the eBay route and chose Parts4Euro as they state to have a better HID system that won't cause any errors. The headlights look exactly like they do in the photos The only difference is in the back where the HID kit was added (cutting out a hole to feed the wires to the ballast).
    I took a close look at the rubber grommet used to cover up the cut out hole for the wires. The grommet was sealed with clear silicone to prevent any moisture to get into the housing and cause condensation issues. Good work there! I later tested this to be accurate as I have not encountered any condensation after going through several touchless car washes (uncluding undercarriage spray) and several heavy rainy days (highway and back roads with standing water). Headlights remain clear and fog free.
    Installation is a breeze. The only thing I will note is that the top tabs of the headlights are very tight against the frame of the car. I was a bit worried that they might crack or break, but they remain solid. I would advise taking your time to put it in and not force it in place.
    Now for some shots..... first... at night.
    The light from the garage was causing the reflection of the parts to show up.
    The LED strips for the parking lights look really good by themselves.
    The yellow LED strip is the turning signal. It will only light up when the turn signal is on, but still distinctive.
    The white LED strip will get washed out when the Xenon light is turned on, but still noticeable.
    The high beam halogens are a joke. They provide no additional lighting value to the driver.
    Here's a vid showing it in action...
    http://FatRings.smugmug.com/gallery/...4_Lct9dHv-A-LB
    The beam pattern is no a true Xenon HID pattern. These headlights are originally desined as halogen projector headlights. Therefore the beam pattern does not have a stairstep pattern. Instead, each projector housing will have a horizontal cutoff from the left side to the middle, and then slant up at a 45 degree angle from the center to the right side. Like this.... _/ _/ I did some adjustment so that when on the road, the two merge together to form a single _/ pattern.
    The halogen projector lens on mine turned out to be really good. No hot spots or dark areas. It results in bright and even light distribution across the road. It is narrower than OEM projectors, so the sides on the driver's side isn't lit up well. On the other hand, the passenger side was lit well due to the cutoff pattern. Out on the road, highway signs are lit up better than with my OEM set. Haven't been flashed by any oncoming cars either.
    Only caveat I will say is that because these were built as halogen headlights and retrofitted to HID, your results with the clarity and light distribution out on the road will vary.
    The HID kit that came with the headlights work well. No codes thrown for any bulb out or ballast not firing. The only error code I got was from a lack of communication from the auto level motors. They are either not present in the headlights (which goes against product description), not compatible with our cars (which goes against product description), or are broken. I've sent email to Parts4Euro along with a VAG-COM scan to show the signal error, but have not yet received any reply. For now, I've removed the fuse to stop seeing the error warning in the DIS.
    Here are some daytime shots.....
    This is with the LED strip and turn signal both on. While the turn signal is visable, the LED strip is weak in daylight.
    With headlights on.
    Daytime video...
    http://FatRings.smugmug.com/gallery/...8_VtmQ88V-A-LB
    These to me are well built, but it dearly needs more intensity for both the turn signals and the LED strip. Functional high beams might be nice too when out on isolated country roads, but the light projected from the HIDs are very good for daily use. Last night I drove through a snow shower, and the headlights offered very good visibility of the road.
    I'm going to hold onto these and see if I can do some upgrades to the LED strip and the turn signal. I'll do my research and planning over the winter and get it done during the spring. Might also look into "joey modding" the chrome used in the turn signals and maybe some sort of "black chrome" for the high beam reflector.
    Not a bad setup. I think the LED strip works well with the car. I would skip these if you have a boser hood as most of the LED strip will be covered.
    Let me know if you have any questions or need any more info. Finally, before anyone asks, I'm also keeping my S4 Bi-Xenon headlights too.
    USP CLUB MEMBER #34
    Veteran Member Four Rings Turbwhistle's Avatar
    Jan 02 2011
    Not terrible, i would like to see how the chrome would look though.
    Chris|1999.5 B5 A4 Avant 1.8TQM Brilliant black|Flickr
    PSS9 | StopTech | Fikse | Challenge Motorwerks | EPL
    Jun 08 2008
    Calgary AB Canada
    Look decent, but I still prefer a nice pair of e-codes.
    Nice writeup though, thanks!
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings 613B6's Avatar
    Jul 29 2009
    Street racing in Ottawa
    oh the horror, but props on the write up.
    A3 8V | 10.89@129 | Boss700 | Eurodyne
    Veteran Member Four Rings vintagespin's Avatar
    Sep 15 2008
    CO
    looks so Tron at night lol
    2005 Dolphin Grey A4 1.8T Quattro 6-speed Sedan
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    ehh, I pass. totally won't look good with my boser that's why.
    I'll wait til the next one!
    good write up are you keeping it as it is or you'll change the projector for better cut off?
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Established Member Two Rings m3ph's Avatar
    Nov 04 2011
    Looks like a chrysler 200, 300 and A4 headlight mixed into one. The idea is cool, just not for our cars :(
    -Alex
    -SOLD- 2002 A4 1.8TQ 5MT | Unitronic Stage2+ | TT225 | K04 | Forge DV | CAI | FMIC, USP, 034 HFC
    -SOLD- 2009 GTI 6MT | BSH Intake
    2013 Golf R - APR STAGE 1 | LED R Tail Lights | LED Interior Lighting |
    Flickr
    Seattle Golf Rs & friends
    Veteran Member Four Rings Shayneduboulay's Avatar
    Nov 16 2009
    Ontario Canada
    Way to much going on with those lights but I really like the front of the car
    Veteran Member Three Rings 03a4sport's Avatar
    Nov 14 2006
    Noblesville, IN
    Awesome write up. Not sure that I'd go for these though just based on the fact they're still a cheaper aftermarket option than OEM set up.
    Quote:
    Originally Posted by B6driver
    its suppose to scoop up air, not snow... too much air + missing screws = dragging pan at 70 mph and people behind you scattering when the pan flies off
    ____________________________________
    Current: 2010 B8 S4 Prestige DSG / Roc Euro Intake / 034 Transmission Mount Insert / Ebay LED interior lighting
    Wrecked by someone paying attention to their Iphone and not the road: 2006 S4
    Sold: 2003 A4 1.8TQM
    Jul 15 2011
    Kennesaw, GA
    I would mistake it for the new Chrysler 300 at night. It would look much better without the solid strip… its just too much for the simple lines of the b6.
    Deactivated Three Rings
    Apr 10 2011
    What they should have done was make the lower individual LEDs white and leave them on all the time for DRLs. And then make the other part on top yellow and make that the turn signal. That would look much better, IMO.
    Senior Member Three Rings Abuck35's Avatar
    Sep 11 2009
    PA
    Quote Originally Posted by m3ph View Post
    X2
    REVO2** AWE FMIC** Genesis 380's** Carbonio** ER tip** EVO MS DV** Magnaflow** gutted cat** N249 bypass**
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    they look nice, but i wish the amber part was the white LED (drl lights)
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Veteran Member Four Rings EUROaleksey's Avatar
    Aug 10 2007
    Toronto, Ontario
    great write-up! ty :)
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by audi_nightrider View Post
    I want to see if I can use different LEDs that produce brighter output. Would involve tearing it apart. I'm still waiting to hear back from Parts4Euro about the auto level motor not responding. It was advertised to have them to work with those that came with Xenon setup from the factory. I seem to have lucked out with a set of good projector lenses, but will consider upgrading the projectors if I'm opening it up to upgrade the LEDs.
    For now, it will remain as is while I do some research to these ideas. It's built well... much better than the DEPO set I tried a while ago. Better quality.
    I agree that you really can't beat OEM. With OEM Bi-Xenons now going for $1200 or more, this is not a bad alternative.
    USP CLUB MEMBER #34
    Dec 06 2007
    YES, I am not the only well fed guy on the forum. lmao
    I actually have a great idea for these and it's all planned out, I just wasn't sure how they'd flow. Problem solved. I think I'm going to buy a set.
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    As others have said, they do seem Chrysler-ish. Do you see the auto level motor in the headlights?
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Veteran Member Three Rings karp's Avatar
    Feb 04 2008
    2012 STG2+ S4 and Triumph Daytona 675
    New York
    i was having the same issue with the auto leveling called parts4euro and they said they'd contact the manufacturer and get back to me.
    Feb 04 2008
    New York
    that was a week ago.
    Feb 23 2004
    Stow, OH
    Have had no response from Parts4Euro on this. Will check on the motor this Saturday.
    USP CLUB MEMBER #34
    Veteran Member Four Rings airjordan223's Avatar
    May 04 2009
    Ohio
    Quote Originally Posted by Beakerz View Post
    this
    2013 S4 | B&O | Sport Diff | Magma Red | DSG | LED Fogs| Stance SF03 | Michelin PSS | Gyeon Ceramic Coating | EPL Stage 1 | Maxton Design V2 | H&R OE Sport Springs | ECS Diffuser
    2002 A4 3.0 Quattro | 17" BBS RK | ST Coilovers | LED DRLs | Hardwired V1 | Alpine 12" Type R | Pioneer 800W Amp | eDead 80 | Dice iPod Integration | Power Slot Rotors | Hawk HPS Pads SOLD
    Dec 19 2007
    York, PA
    not bad. i agree with the fact that the intensity should be improved for daylight use.
    Dec 06 2007
    how about a shot of the beam pattern
    -Kirk
    Veteran Member Four Rings 32_d3gr33s's Avatar
    May 14 2009
    '16 Tiguan TSI, '08 Suburban, '02 Ninja ZX-6R, '06 Ninja 650R
    West Michigan
    they look a lot better than i thought. I would just run them without the daytime led's. i really like the turn signals though...
    I could write something cliché and insightful, but that would be too cliché and insightful.
    **-Anthony-**
    2003 A4 3.0 Pearl White | Autopilot V2 | Airlift Slam Series | Koni Sport Shocks | Pioneer X920BT | Kenwood 9105 | Kenwood 8405 | Infinity 6030 | 15" Alpine Type R | Ram Air Intake | Adams Rotors | Air Horns | Oettinger | Varrstoen Wheels| ABT Grille | 5% Tint | Build Thread
    Dec 19 2007
    York, PA
    man, i really want to buy a b8
    Feb 23 2004
    Stow, OH
    Got a reply back from Parts4Euro.... these are halogen headlights with a HID aftermarket kit installed. They are meant for cars that come with halogen headlights from the factory.
    I've replied back to indicate that the description is misleading. Here's part of the product description from their website....
    Crystal Projector Headlights With Auto-Leveling motor for 2002-2005 Audi A4 / S4 B6 Chassis 4D Sedan & 5D Wagon Only
    and later in description...
    HID for the Low Beam is Pre-Installed as stated in the above. In addition, the headlights require H1 for the High Beams. Bulbs are included for the High Beam. Designed for direct bolt on. This fits on both with factory xenon and factory halogen models, new xenon HID bulbs and ballasts are included. You will NOT be using your factory xenon bulbs/ballasts.
    Comes with Auto-Leveling Motor, so if you have auto-leveling feature from stock, you will continue to have that feature when you use this headlight
    Nowhere in the description does it indicate that these headlights are only meant for cars equipped with halogen headlights. The auto-leveling motor only came with cars equipped with xenon lights from the factory. I've never heard or seen auto-leveling halogen headlights. Told them that if that description was not mentioned, I would not have tried these headlights out. I was expecting 100% plug and play with no errors or issues. The description of the product is misleading. I'll still check to see if there really is an auto-level motor in there, but I'm expecting it to be missing. Waiting to hear back from them.
    USP CLUB MEMBER #34
    Dec 06 2007
    Quote Originally Posted by CyberPMG View Post
    I believe in Europe and Canada it is mandatory for all headlights including halogens to have auto-leveling motors. The B6 had that feature in the foreign models and was controlled via a 3 or 5 position switch inside the cabin next to the headlights.
    -Kirk
    Feb 23 2004
    Stow, OH
    Quote Originally Posted by AudiA4Turbo22 View Post
    If that's true, then is there any way of getting it to work in US cars?
    USP CLUB MEMBER #34
    Senior Member Two Rings Ruski's Avatar
    Nov 30 2006
    Toronto, Ontario, Canada
    Well that doesn't sound very honest! No mention of halogen only compatibility, no mention of missing motor, etc...very suspect.
    Jul 10 2007
    trunk
    I don't believe that's correct for Canada.
    Stage 0 minus - .5
    Veteran Member Three Rings hbodo08's Avatar
    Apr 06 2009
    04' a4 3.0 ** 02' envoy slt--85' iroc z 28 (7400 original miles) 2010 Mercedes e350 4 matic
    The ville, Ohio Akron, Ohio
    haha i was so going to call you to see if you were going to get a pair.. those look cool i just wish the led strip was day time running in stead of the turn signal
    I drive it like i stole it , then again
    /____________________\
    [_oo_\===0000===/_oo_]
    \_o___[HMB-30A4Q]___o_/
    Senior Member Two Rings RawrItsCris's Avatar
    Jul 23 2009
    88 Alpine E30, 06 E92 325xi WAGON
    Spanaway WA
    Quote Originally Posted by onceover View Post
    x2
    These Remind me too much of the new 300c headlights.
    db.DirtyBirds
    "Magazine feature in Japanese, of a German car, in America.
    Legit."
    Feb 23 2004
    Stow, OH
    Ok... got some updates....
    There are auto-leveling motors in these headlights, but they're not compatible with the auto-level motors used in the factory xenon headlights. Apparently in Europe, there's an option to be able to auto adjust halogen headlights (little knob by the headlight switch). So that's why it's in the product description. These are halogen headlights and really only meant for cars originally equipped with halogen headlights.
    With that said, I think I'm going to switch back to my Bi-Xenon ecodes and maybe work on doing some upgrades to these (more intense DRL and turn signals, and maybe all new bi-xenon projectors).
    USP CLUB MEMBER #34
    Sep 03 2009
    San Antonio, TX
    Hmmm...I'm not sure if there is just too much going on there...I reserve judgment...for now. LOL
    MY BUILD
    Sep 16 2010
    Central Wash
    *sigh*.... meh. I'm with everyone else: could be worse. But every aftermarket headlight I've seen with the SQUARE high beam is just horrendous. It doesn't work. It barely worked on the B5/C5 cars, but being oem they managed to make it acceptable.
    The round high beam on the B6 and Allroad just look great, why do they mess with it?
    But- as for the leveling motors, can you just swap your oem motors in there? They just twist to remove. Might have to splice the wires?
    Veteran Member Three Rings Slavchob's Avatar
    Apr 27 2010
    2003 Audi S8
    Syracuse NY
    That is all
    Dec 06 2007
    If you want to sell them LMK
    -Kirk
    Veteran Member Three Rings 4RedRings's Avatar
    Nov 18 2011
    03 A4 1.8t FWD & 03 A4 1.8t Quattro
    Greenville, SC
    Just installed these DEPO black Halo headlights on. I know it's beemer thing. But hell, she does look mean. Shall I keep the eye braws or not don't know yet. was and after
    Sep 27 2008
    Long Island, NY
    ^ you should lose the bumper vinyl, eyebrows, and turn off those angel eyes. headlights don't look too bad but the angel eyes have got to go. All IMO, of course.
    Edit: also lose the s-line badge since it's not an s-line.
    Instagram: @_vishis
    Jul 10 2007
    trunk
    Quote Originally Posted by 4RedRings View Post
    Bimmer.
    That's the height of my technical knowledge.
    Stage 0 minus - .5
