Results 1 to 10 of 10
    Aug 19 2011
    wilmington nc
    what is the sensor in the intake manifold called
    in my 01 s4 there is a sensor that layes inside the intake manifold, just behind the throttle body. It looks burnt and I believe this could be the cause of my issue. my issue is that when my car in cold it rns amazing but as it heats up and a sensor pops up on the dash it starts to jerk real bad when you apply the gas. sometimes it will even lose throttle reponse all together. can anyone help me ?
    Veteran Member Four Rings bigdo26's Avatar
    Jul 21 2009
    Sounds like the MAF?
    Edit - what codes to you get?
    2014 Mustang GT w/track pack and Recaros
    Sold: B5 S4
    Track videos: Watkins Glen
    Track videos: Limerock Park
    Aug 15 2009
    2001.5 S4---1988 toyota cressida (1uz turbo swap in progress!)
    maryland
    u mean MAP?
    Real cars have chips in the paint.
    Aug 19 2011
    wilmington nc
    last time i checked i had like 11 codes pop up. I dont know whats wrong with it. I replaced my throttle body not to long ago and two of my codes say it has a low circit. as far as the maf sensor i replaced it also. what does the map sensor do ?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    on the top near throttle body is manifold absolute pressure sensor(map), on the bottom side its your intake air temp sensor (iat)
    Aug 19 2011
    wilmington nc
    so it would be the map. the sensor im talking about is right inside the intake. if you remove the throttle body and look inside the intake you can see it. it sticks stright up and you can acess it from the bottom. it looks like a v with a stip running up the middle of it
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Thats the IAT sensor - it tells your ECM how hot the charge of air entering the manifold is
    MAP tells your ECM how much boost pressure is hitting the manifold
    Aug 19 2011
    wilmington nc
    could that be the problum im having when my car warms up ?
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by mklegge
    I looked up a iat sensor and that is the sensor i was asking for. Im not to good with these cars so i dont mean to sound stupid. do you think that may be the casue im having with my car. it runs perfect when it is cold but as soon as it warms up it jerks really bad and sometimes throttle reponse is lost all together when i apply the gas
    You can log your intake air temps with vagcom. block 011 I believe will show you what the sensor is reading.
    Did you run a throttle body adaption after you replaced the tb? Also use a liberal amount of maf sensor cleaner on your maf just to be sure.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by mklegge View Post
    Like Thirdstrike said, that is the IAT sensor (Intake Air Temperature).
    If you have VAGCOM, you can log it and check to see, or run for codes, but if it is malfunctioning, it certainly can cause problems.
    Let me know if you need a replacement;
    http://www.034motorsport.com/034efi-...sor-p-117.html
