Results 1 to 8 of 8
    Established Member Two Rings NewB7's Avatar
    Nov 15 2011
    Bay Area, Ca
    Any test pipe friendly smog shops in San Jose?
    I need to find a test pipe friendly smog shop in SJ or surrounding area. Any recommendations?
    Nov 15 2011
    Bay Area, Ca
    So it looks like I have to bite the bullet and get a stock cat swapped back in????
    Jun 10 2010
    Yea, I don't think anyone is going to risk their job (or a hefty fine) over this.
    Sep 17 2005
    Fremont, California
    More like risking their entire business, not just a job or fine!
    Audizine doesn't condone illegal SMOG passing so you won't find any recommendations here for that; it is way too big of a deal in California.
    Your best best is to run a high flow cat (which has 95% the performance of a test pipe), swap in the stock for a bit, or get that test pipe red red red hot and hope for the best.
    If you do try to pass with the test pipe, make sure you get a Pre-Test first; lot of people do not know that if you fail SMOG, the DMV is alerted and your car can become a gross polluter, requiring you to SMOG every year rather then every 2 years.
    Nov 15 2011
    Bay Area, Ca
    Max, how much would you charge just to swap out my test pipe? I'll have a stock cat w/ me. I would do it myself, but I don't have a high enough jack/ramps
    Quote Originally Posted by Max@034 View Post
    Senior Member Two Rings Quattro SFC's Avatar
    Jul 16 2009
    2014 S5 | 92 325i
    San Francisco Bay Area
    Quote Originally Posted by NewB7 View Post
    Christian charged me $125 to put my 034 hfc in so i assume it would be the same to swap the stock one back.
    | Rotiform RSE | Michelin | H&R | EuroCode | Moog | CR | Zimmerman | Akebono | Estoril Blue | B&O | Carbon Inlays | Sports Diff |
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    Car will not pass smog if you have only a test pipe. Some high flow cats will pass, howevewr if you have a stage II file you will most likely fail.
    This is what we recommend:
    • Put stock cat back on
    • Flash to non test pipe file
    • Let us do the readiness checks with the scan tool
    • Go straight to the smog shop and get your certificate
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Forum Moderator Four Rings doobiesdaddy's Avatar
    Sep 05 2008
    2001 Stage 3 allroad 2.7t 6mt TDI gearbox , 2021 Mercedes E 350
    Montana / San Francisco
    x2
    Thread closed
    Dave - Moderator
    Issue? send me an email
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down ‘happy’. They told me I didn’t understand the assignment, and I told them they didn’t understand life.
    -John Lennon
