Originally Posted by
clubaudi
when it is plugged in it idles crazy and is really jumpy when you start off but when it is unpluged it idles good but you cant go into boost.... does it mean the sensor isnt any good or is there another problem with my car?
Try this,
Go in vag-com and clear your engine codes, even if there is none, this will reset the fuel trip and timing tables. Start the car again, the Ecu will relearn the base values. Drive for a few minutes without going in WOT.
If it still idle badly, the MAF appear to be the problem.
you can test it by logging the Group 002, (g/s) air intake read by the maf. I don't know if your car is chipped... Let's say you should have 170hp, multiply this by 0.8 and you should have a peak of 136 g/s of air. The MAF should read a peak value near this.
