Results 1 to 18 of 18
    Veteran Member Three Rings Trile's Avatar
    Jan 26 2010
    Podgorica - Montenegro
    quick universal o2 sensor question
    b1s1 is throwing a code.
    Will bosch 15730 sensor be a good replacement for the front o2 sensors?
    And related - are fronts and rears interchangeable ? Can I just take out the rears, clean them up and swap them in the front?
    Will they work the same? I will have the rears coded out eventually anyway
    I searched btw but no deffinite answer, just a bunch of not-working ebay auction links
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    I dont think those are the correct ones.
    I have the bosch 15733 universals: Autozone Bosch 15733, Amazon Bosch 15733
    They seem to work just fine, had em on there for almost a year.
    Fronts and rears are interchangable.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Jan 26 2010
    on here http://boschoxygensensor.com both 33 and 30 are listed as 'universal'.
    I wanted to get the oem ones but they are 185 euros a piece, thats like 250$ for ***k sake !
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    no worries.
    The Autozone part finder does not list the 30's for our cars, I would be leary of using them instead of the 33's.
    $250 for o2 sensor is dumb, lol.
    Jan 26 2010
    Quote Originally Posted by csosnowski View Post
    no worries.
    did you solder the new wires to the old or ..what?
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    no just the connectors that come with them
    Jan 11 2007
    Salt Lake City, Utah
    I decided to not use those bulky connectors that come with them and just used these butt connectors (sourced from a local auto store IIRC) and shrink-wrap. Turned out pretty decent IMO, and was definitely worth the $100+ that I saved over going with a new OEM connector.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    sweet
    Senior Member Three Rings GyzmoS4's Avatar
    Feb 07 2006
    Bronx, NY
    J-Fonz tuned Stg 2+
    "Two wrongs don't make a right, but it makes us even."
    Account Terminated Four Rings
    Feb 26 2011
    las vegas
    stay away from cheapo stuff like this, you will just end up kicking yourself for not buying a bosch sensor
    Quote Originally Posted by GyzmoS4 View Post
    Feb 07 2006
    Bronx, NY
    Quote Originally Posted by itguy View Post
    Kind of figured that, but figured I'd check anyway. Thanks.
    J-Fonz tuned Stg 2+
    Jan 11 2007
    I would agree, the bosch is only $50 shipped, so I personally wouldn't risk it. Having said that though, I have no experience with the other sensor in question.
    LOOKING FOR:
    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    dont buy the cheap ones. they dont work. buy Bosch.
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    Quote Originally Posted by jibberjive View Post
    That works as well. The reason for the connectors that come with the universal sensors is because they're weather pack connectors. Since they're universal there's many different areas they can/will be mounted, so Bosch opted for the optimal idea to keep water and dirt out of the connectors. Yes, they are bulky, but they definitely do work. On that note - I installed 2 of them in place of the primary oxygen sensors on the last S4 and I've got 1 in my current S4 in place of a primary. All 3 worked perfectly, no more misfires and gas mileage has increased. They are absolutely worth the extra 15 minutes to install and saving yourself $50+ every time you have to replace one.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    Jan 11 2007
    Quote Originally Posted by The_Auto_Tech View Post
    Yeah, not saying that the connectors are inferior or don't work, I just found it easier for me to just crimp on these butt-connectors and do it this way. With the heated shrink wrap, I feel comfortable that these are almost as weather resistant as the box and grommets, and I personally am not going to stress them at all.
    Just so everyone knows though, like people are saying, the universal O2's come with splice connectors and everything you need to put the old connectors on the new ones. You don't need to buy any extra installation hardware like I did.
    LOOKING FOR:
    Jan 26 2010
    So jibberjive, theautotech and csosnowsky all used bosch 15733. Great, good enough for me.
    If now I could only find someone who ships them internationaly. Amazon and ebay have so far yielded nothing good. Shipping to US only. Damn.
    @Autotech, did you get CELs before you replaced o2s or maybe intermittent errors like me ? Hope this will help my mpg and some misfires
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    yeah i ran the universal bosch in my allroad for close to a couple years and worked great no codes and made my mileage go up about 2 when my originals were bad, the cheapest place i found the REAL bosch ones was amazon and i did a ton of research back in the day link: http://www.amazon.com/Bosch-15733-Ox...3371877&sr=8-1
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Nov 29 2010
    Des Moines, IA
    Quote Originally Posted by Trile View Post
    Yes, I had CEL's for the sensors along with random/multiple misfires. Replaced both primaries in one car and one primary on the other and it cleared the issue for good. I ordered mine from Amazon as well. Looks like they just recently went up in price too. I think I paid 34 dollars a piece for mine. Would do it all over again the same way.
    - Cody T.
