Results 1 to 6 of 6
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    Avant Led tail lights wire diagram?
    For the guys that have done this, I bought a set of lights from guy that didn't use them he got em from Alex. My wire set up is different than the one that now is on his site just by a little. I have one long harness that runs from one side to the other for the outers and it has two wires going to bcm. But the only other wires I have are two Little yellow ones. How do the yellow ones wire into the bcm?
    Thanks
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Feb 13 2004
    Silicon Valley, CA
    Do you have all the directions?
    http://www.europrice.us/Avant/
    Kevin - Moderator, Audizine
    Established Member Two Rings DB33's Avatar
    Mar 25 2010
    12 A4 Avant Prestige S-Line
    Scranton,PA
    Hey Bezlar,
    I just did the conversion on my Avant. It was a pretty easy install with Alex's instructions. From what you listed it appears that you have all the necessary wiring. The two wires get taped into two wires on the BCM listed in the above instructions. You will need a a pinning tool for the conversion. If you do not have one ECStunning.com has them. Good luck with the install. You will be very pleased once you did the conversion.
    Apr 05 2006
    992 c4s
    Blue Springs
    I have instructions. It's just I don't have a plug with a green tie on it. All I have are two loose yellow wires with pins on one end. I guess these are to extend the wires that you take out of the t32 plug? If I'm right my ? Is which wires get plugged into the T17 plug locations? Green and the black and yellow from t32 go into pin locations 9 and 8 on t17. But which one goes to 8 and which one goes to 9?
    Thanks
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
    Stage 2 Banner Advertiser Four Rings
    Aug 07 2008
    Dallas, TX
    Bezlar- I ran through custom instructions for your kit today. You don't want a wiring diagram, will only serve to confuse you. You want to follow the instructions for replacing the inner taillight plugs. Then you want to follow the instructions I just sent to get those two crimp on pins properly wired and fitted.
    Cheers,
    Alexander van Gerbig
    www.europrice.us
    [email protected]
    Apr 05 2006
    992 c4s
    Blue Springs
    Thanks all, I think im set will know in a couple of hours.
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2015 golf r gone
    2018 rs3 garage
