Bottom End
IE offers everything you need to build a strong short block. We built our name on offering you the strongest and top selling connecting rods for VW/Audi applications and continued on that name to bring you anything you might want from full stroker kits, forged pistons, main caps, dowel pin kits, specialty hardware, and much more to ensure you build a bottom end that can handle anything you throw at it.
Integrated Engineering 1.8T H-Beam Forged Rods
Integrated Engineering is proud to manufacture the highest quality connecting rods available for European applications at a reasonable price. IE rods feature a light weight to strength ratio that works well in today's high rpm applications, and holds up to a lifetime of torture. A 4340 Chrome Moly steel, the material is multi-stage heat treated to ensure the highest possible fatigue strength as well as good dimensional stability. All of our rods undergo a strict quality check process right here in
USA, every single rod is finish honed and checked for strict roundness before being packaged in-house. IE H-beam rods have seen extensive real world testing for over 700BHP!
H Beam 144X19 Connecting rod for stock 19mm wrist pin
More info here
H Beam 144X19 Connecting rod for aftermarket or stock 20mm wrist pins
More info here
(Optional rifle drilling available)
Integrated Engineering Tuscan I-Beam Forged Rods
Tested well over 1000BHP and all the premium features for our new top of the line connecting rods for the highest quality builds!
COMING SOON!
Calico Coated Race Bearing Sets
These bearings are the real deal coated bearings. Starting with premium ACL brand race bearings the base shells feature a hardened steel backing, with increased crush for better rotation. They have increased ovality to compensate for distortions at high rpm levels, and are designed with a high strength overlay plate for maximum fatigue resistance. All of this is covered up with a professionally applied coating by Calico, giving a truly high performance bearing from the coating all the way to the outer shell. They are available in standard or +.001" extra bearing clearance for the most extreme applications.
Calico Coated Race Rod Bearing Set
More info here
Calico Coated Race Rod Bearing Set +.001"
More info here
Calico Coated Race Main Bearing Set
More info here
Calico Coated Race Main Bearing Set +.001"
More info here
Integrated Engineering Billet 4140 Standard Main Caps
These VW 4 cylinder main caps are carefully crafted, in-house, from USA 4140 alloy steel. They provide extreme rigidity to the main bearing and crankshaft, which is a necessity for high horsepower engines. In addition, the large profile and high strength material is much stronger and stiffer than the factory main caps.
Requires machine work including line bore & hone for fitment. More info here
Integrated Engineering Billet 4140 Tall Boy Main Caps
These main caps are specifically designed to work with a crankcase bedplate/girdle. Typically, the installation of those products requires machining small spacers, which go between the main cap and the girdle, bringing it up to the same level as the pan rails and typically are very difficult to machine to the correct height. IE Tall Boy Main Caps ship standing slightly proud of the pan rail to be machined level with the pan rail, resulting in a perfectly flat surface for the installation. The large profile and high strength material is much stronger and stiffer than the factory main caps.
Integrated Engineering 1.8T Torque Plate
Boring your engine with a torque plate is one way to ensure the cylinders of your high performance engine are as round as possible. This plate simulates a cylinder head being bolted onto the engine, distorting the block into the shape it will be in with the head on. Boring it in this state ensures that the bores are actually round with the head on.
(available for rental) More info here
Integrated Engineering 1.8T Timing Belt Gear Dowel Pin Kits
One of the major weaknesses of the 1.8T 20V platform is that the timing belt system is slightly under specced for the large load placed on it by the 20v head resulting in a keyway that has been known to shear off the crank pulley. IE Dowel Pin Kits uses a 7200lb shear strength alloy dowel pin through the joint to hold the load. Our kit allows the crank to be successfully modified even in the car. Featuring a brand new OEM timing pulley, which has been drilled, reamed, and then chamfered in our CNC Milling center. This ensures that the bore is placed right on the money and square to the end of the crankshaft. The kit includes a pulley, drill bit, reamer, high strength alloy steel dowel pin and 2 page instructions with pictures.
Timing Belt Gear Dowel Pin Kit for 06A blocks
More info here
Timing Belt Gear Dowel Pin Kit for 058 blocks
More info here
1.8T 20V Timing Belt Gear Dowel Pin Kit for 2.1L strokers using TDI crank
More info here
Integrated Engineering Stroker Kits and parts
Integrated Engineering Stroker Kits are assembled with IE forged rods, genuine, your choice or forged VW 2.0 FSI crank shafts, and your choice in a variety of forged pistons to achieve 2008CC displacements or higher. IE stroker kits are a very robust setup which is a huge upgrade from standard 1.8T parts in every way while providing quicker spool, more torque off boost, and more power and torque per pound of boost. IE also carries bring your own crank kits for 2.1L strokers and a variety of stroker parts to build your own.
IE custom JE Piston 2.0L Stroker Kit
This stroker kit features a set of IE 20mm rods, custom made JE pistons that we have made to our specifications, and a genuine, forged VW 2.0 FSI crank shaft. It utilizes an 83mm bore JE piston to achieve 2008CC displacement.
IE custom JE piston 2.0 stroker kit 8.5:1 Compression
More info here
IE custom JE piston 2.0 stroker kit 9.5:1
More info here
IE custom JE Coated Piston 2.0L Stroker Kit
This stroker kit features a set of IE 20mm rods, custom made coated JE pistons that we have made to our specifications, and a genuine, forged VW 2.0 FSI crank shaft. It utilizes an 83mm bore JE piston to achieve 2008CC displacement with a 9.5:1 compression ratio. These JE pistons come standard with tool steel wrist pins, ceramic dome coating, and JE's Tuff-Skirt anti friction skirt coating. They also feature oil ring rail support, which allows the piston rings to be moved further down on the piston. Lateral gas ports also come standard to build up pressure behind the compression ring and seal it against the cylinder wall.
This kit is special order, call 888.60.INTENG to order
IE Mahle Piston 2.0 Stroker Kit
This stroker kit features a set of IE 20mm rods, Mahle Pistons and a genuine, forged VW 2.0 FSI crank shaft. It utilizes an 83mm bore Mahle piston to achieve 2008CC displacement, with 9:1 Compression. Mahle Powerpack pistons are extremely high quality pieces which provide improvements in strength without sacrifice. Precision forged from 4032 alloy, forged side reliefs, slipper skirt designs, and ultra flat ring grooves, and exclusive Grafal skirt coating ensure uncompromising top notch quality in your stroker kit.
More info here
IE Wiseco Piston 2.0 Stroker Kit
This stroker kit features a set of IE 20mm rods, Wiseco Pistons and a genuine, forged VW 2.0 FSI crank shaft. It utilizes an 83mm bore Mahle piston to achieve 2008CC displacement, with 9:1 Compression. Wiseco pistons are a great upgrade for someone looking to build a stout, reliable engine. These custom pistons, available only at Integrated Engineering, feature anti-detonation grooves on the upper ringland, accumluator groove between the 1st and 2nd rings, and thick ringlands which ensure there will be no failure of the ring lands under high boost.
More info here
IE BYOC (Bring Your Own Crank) 2.1L Stroker Kits
These stroker kits features a set of IE 20mm rods, custom JE pistons, and a specially modified drive pulley. This kit is "Bring your own crank" (BYOC), in that you need to source a MK4 TDI Turbodiesel crankshaft to go with it. Utilizing 83mm bore IE custom JE pistons to achieve 2067CC displacement. This kit allows the end user to quickly install a 2067cc stroker kit in any standard 06a block. The installation is no different then a standard rod and piston combination... Bore the motor to match the pistons using a torque plate, then build the motor as normal using a TDI crankshaft and the provided rods, pistons,and timing belt pulley.
IE custom JE piston 2.1L BYOC stroker kit 8.5:1 Compression
More info here
IE custom JE piston 2.1L BYOC stroker kit 9.5:1 Compression
More info here
Forged FSI Crank Shaft for 2.0L Stroker Conversions
This stroker crank is a brand new OE factory forged 2.0L FSI crankshaft. We specially modify it with a special oil pump drive gear which makes it a drop in for 06a 1.8t blocks. Requires a set of stroker pistons to match, as well as a set of 144x20mm rods.
More info here
Crank Sensor Trigger Wheel for 2.1L 1.8T Stroker
This is the correct trigger wheel to use when stroking a 1.8T engine with a 1.9L TDI crankshaft. These are brand new OEM parts sourced specifically to make the TDI crank a direct fit into 1.8T blocks.
More info here
IE Oil Pump Drive Gear For 2L Stroker using FSI Crankshaft
This gear is essential when building a 2L stroker conversion for a 1.8t using the factory 2.0 FSI Forged Crankshaft. The factory gear is not available in North America and thus must be imported at considerable cost. We reverse engineered them and had a large batch made from carburized steel.
More info here
Overbore Head Gasket
This is a cylinder head gasket that has been specially modified to accept pistons up to an 83.5MM bore. It does NOT change your compression and provides better sealing characteristics then N/A head gaskets frequently sold for stroker applications.
More info here
1.8T Pistons
Integrated Engineering has a huge selection of Forged Pistons including JE, Mahle, and Wiseco available in various compression ratios, strokes, and bore sizes. Whatever piston combination you need, we have a set to meet your budget. Don't see what you need? We can custom order anything!
JE pistons
JE pistons are a great upgrade for someone looking to build a stout, reliable engine. JE's 2618 alloy is stronger then most other pistons made from 4032, and are specifically engineered for extreme applications, and is why we chose to use them in all our race engines. Dish requires no deburring or preparation.
JE's use 20mm wrist pins so they will require a set of rods with 20mm pins to match.
81MM Bore 86.4MM Stroke 8.5:1 CR
81MM Bore 86.4MM Stroke 9.25:1 CR
81.5MM Bore 86.4MM Stroke 8.5:1 CR
81.5MM Bore 86.4MM Stroke 9.25:1 CR
82MM Bore 86.4MM Stroke 8.5:1 CR
82MM Bore 86.4MM Stroke 9.25:1 CR
82.5MM Bore 86.4MM Stroke 8.5:1 CR
82.5MM Bore 86.4MM Stroke 9.25:1 CR
83MM Bore 86.4MM Stroke 8.5:1 CR
Mahle Pistons
Mahle PowerPack Pistons are extremely high quality and an excellent choice for those looking to increase strength while maintaining a lightweight piston with oem fit and finish. Mahle pistons provide improvements in strength over OEM pistons without some of the sacrifices sometimes found in other forged pistons. Precision forged from 4032 alloy, a low expenasion rate aluminum. They all feature forged side reliefs, reducing the weight of the overall package. They also use slipper skirt designs, reducing friction and further reducing weight. Mahle PowerPack pistons feature ultra flat ring grooves, which promote excellent ring seal and most importantly reduce the chances of micro-welding during break in. Every set of Mahle PowerPack pistons comes with their exclusive Grafal skirt coating, which is not only anti-friction but also offers impact absorbing qualities, reducing piston noise and decreasing stresses in the piston skirt. These have 20mm wrist pins so they will require a set of 144x20mm rods to match.
Wiseco Pistons
Wiseco pistons are very high quality cost effective piston, machined and forged in USA using state of the art facilities. Wiseco Pistons are forged using 4032 alloy, this alloy isn't quite as strong, but has less thermal expansion, so motors can be built tighter. This is a good thing in those that rely heavily on knock sensors. These pistons are an exceptional value. These have 20mm wrist pins so they will require a set of 144x20mm rods to match.
81MM Bore 86.4MM Stroke 9:1 CR
81.5MM Bore 86.4MM Stroke 9:1 CR
82MM Bore 86.4MM Stroke 9:1 CR
JE Stroker Pistons
Integrated Engineering Custom JE stroker pistons are designed to be used when over boring the block specifically for stroker conversions. This increased displacement yields more power on the same boost, less chance of detonation at a given power level (Lower peak cylinder pressures) and faster spool. JE pistons are a great upgrade for someone looking to build a stout, reliable engine. They have 20mm wrist pins so they will require a set of rods with 20mm pins to match.
83MM Bore 92.8MM Stroke 8.5:1 CR
83MM Bore 92.8MM Stroke 9.5:1 CR
83MM Bore 95.5MM Stroke 8.5:1 CR (2.1L stroker with TDI crank)
83MM Bore 95.5MM Stroke 9.5:1 CR (2.1L stroker with TDI crank)
IE Spec JE Race 1.8T 83MM Bore 92.8MM Stroker Pistons
This is a set of custom made JE pistons that we have made to our specifications. These are the pistons that we run in all of our high HP race cars. These pistons come standard with tool steel wrist pins, ceramic dome coating, and JE's Tuff-Skirt anti friction skirt coating. They also feature oil ring rail support, which allows the piston rings to be moved further down on the piston. Lateral gas ports also come standard to build up pressure behind the compression ring and seal it against the cylinder wall. These are made to be used with the FSI 2.0L crankshaft.
83MM Bore 92.8MM Stroke 9.0:1 CR
Mahle Stroker Pistons
Custom made to IE specifications, this is a set of extremely high quality Mahle PowerPack pistons for 2.0L stroker motors. These Mahle pistons increase displacement yielding more power on the same boost, less chance of detonation at a given power level and faster spool while retaining all the features found on PowerPack pistons. They have 20mm wrist pins so they will require a set of rods with 20mm pins to match.
83MM Bore 92.8MM Stroke 9:1 CR
Wiseco Stroker Pistons
Wiseco stroker pistons increase displacement yielding more power on the same boost, less chance of detonation at a given power level faster spool. Wiseco stroker custom pistons, available only at Integrated Engineering, feature anti detonation grooves on the upper ringland, an accumulator groove between the 1st and 2nd rings, and thick ringlands which ensure there will be no failure of the ring lands under high boost. These feature a 20mm wrist pin and require 144X20mm rods to match.
New Product
Integrated Engineering Crankshaft Girdle/Bedplate kit for 06A 1.8T
Under increased RPM horsepower, and torque your block can begin to flex, causing severe main bearing wear or even a broken crank or block. Reinforcing the block is a necessity for extreme applications. This girdle kit uses a 3/8” specifically designed steel plate bolted to the underside of your block increasing lateral support and preventing flexing under high power use. The girdle plate bolts to all of the main journals, using the supplied custom extended-length ARP main stud kit. It is then sandwiched between the block and the oil pan to keep the block from flexing. This kit includes all lengthened hardware needed to install the girdle plate. Spacers are included for use with factory main caps, however IE “Tall Boy” billet main caps are a highly recommended for high horsepower builds.
More info here.
Take a look at our Crankshaft girdle install DIY
