Results 1 to 8 of 8
    Veteran Member Three Rings 2010S4's Avatar
    Jun 09 2010
    2010 Audi TTS, 2011 Audi Q7 S-Line Prestige
    Virginia Beach
    Question Q7 Backup Camera Question
    So I have been told that this is possible to do, but I can't seem to be able to figure it out. Can someone tell me how to get the backup camera as the default screen when I put my Q7 in reverse. Currently it goes to the screen that shows the distance sensors. Then I have to hit a button to get it to change to the camera. I have to do this every time I put it in reverse. There has to be someway to make the camera the default. I appreciate any feedback anyone can give me.
    Mike
    DD: 2010 S4 Prestige, Brilliant Black, DSG, ADS, Black Alcantara, Side assist, Carbon inserts
    Mods: APR 93 tune, APR pulley, Strat Intake, StopTech ST-60 BBK, H&R OE Sport springs, H&R rear sway, VAG-COM, tint, LED plate lights, under door LED, lamin-x on tails, Black-optics grill, R8 GT Alcantara steering wheel, Milltek Non-Res exhaust w/ black tips, JL 10" W7, black 19" factory wheels, BFI 10 & 5mm spacers, rear valance in matte black, RS6 shift knob, oCarbon MMI dash surround
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    You need to use vagcom...go to backup camera and change the setting for both graphic and display
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Jun 09 2010
    Virginia Beach
    Thanks, Ill give that a try and see if I can get it. Do you know if it is in the long code helper or do i need to change the code manually? If manually, do you know what needs to be changed?
    Veteran Member Four Rings palewhitemale's Avatar
    Sep 22 2004
    MT
    pretty sure you don't have to do anything with the VAG com. I believe you can do it while standing still in the car/setup/parking system portion of MMI.
    not 100% on this, but I'm almost certain I changed ours from the park distance screen to the camera screen, and I've never plugged in a vagcom to that vehicle.
    -bill
    2003 RS6 Avant, Goodwood Green/Black - Stock
    2018 Q7 Prestige, Glacier/Cedar - Stock
    2015 Q7 TDI Prestige, Carrera White/Espresso - Totaled @ 25k miles
    2015 Q5 TDI Prestige, Scuba Blue/Chestnut - Stock
    2001.5 S4 Avant 6sp, Stg III, Casablanca/Silver - SOLD
    2008 RS4 Avus/Black - SOLD
    2012 A3 TDI Monza/Black - SOLD
    2003 RS6 Sedan Avus/Black - SOLD
    2004.5 A4 Avant 1.8t - SOLD
    Jun 09 2010
    Virginia Beach
    Quote Originally Posted by palewhitemale View Post
    -bill
    Someone else told me that as well. I checked there and did not see anything about setting the default setting. All that was on that menu was the Volume levels and pitches for the sensors. But ill check it again before I start messing with the vagcom.
    Dec 17 2008
    Charlotte, NC
    It's under the car settings.... Go into the parking system under car. I'm about 95% on that.
    Ol' Whitey - 1996 A4 2.8 quattro 5MT Arctic White w/ Remus
    #2 - 2008 A4 2.0T Quattro 6MT Quartz Gray - w/ AWE exhaust (1/08 - 1/11)
    #3- 2011 A4 6MT Quartz Gray - Prem Plus, B&O, Titanium - Full Gen1 AWE dual exhaust, Eurocode Everything, 3M Clearbra, Piano Black Dash Surround, MY10 rear headrests, Huper Optik, S-line Stoneguards
    #4 2014 Audi S4 6MT - Monsoon + Black optics Neuspeed exhaust, Eurocode bits
    Audi Brand & Audi Sport Specialist at Northlake
    B8 Titanium Club Member #4
    Deactivated Two Rings
    Sep 03 2011
    Ohio
    How do you get it to show the distance menu. I can only get my A6 to show the camera.
    Thanks.
    Jun 09 2010
    Virginia Beach
    Quote Originally Posted by AofC_RR View Post
    I just tried that and there was a setting that allowed me to turn display On or Off. So I thought maybe that meant the distance display, so I turned it off, now it won't let me turn it back on and I have to distance display or backup camera. I guess I need to take it into the dealer.
