View Poll Results: How to properly install?
Voters
20. You may not vote on this poll
  • Hats and spacers?
    7 35.00%
  • oring and no clip?
    1 5.00%
  • oring and clip?
    12 60.00%
Results 1 to 32 of 32
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Whats the desired way to install EV14 injectors?
    Use hats and spacers?
    Change the lower o-ring with a stock size one with no stock clip?
    Change the lower o-ring with a stock size one with a clip?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Established Member Two Rings Mrdeezy's Avatar
    Oct 04 2009
    Northern California
    I just did mine today. I used clips with no hat or spacers. No leaks seems ok.Turned sideways awe style with uscar adapters.
    I think there are 4 different lengths so be careful what you order.
    Veteran Member Four Rings durfA4's Avatar
    Jan 01 2006
    2012 A7 Stage 2, 2014 Q5 3.0T SLine, 2001 Laser Red S4
    Boston
    Mine are 52lb installed using oem injector o-rings and clips facing same direction as oem. Fit is perfect.
    2012 A7 3.0t EPL Stage 2
    2014 Q5 3.0t
    2001 S4 STUKLR tuned
    Veteran Member Three Rings ThePeoplesChamp's Avatar
    Apr 28 2009
    New Brunswick, NJ
    I did oring and clip and they seated perfectly
    2001 Audi S4
    2004 IS300
    1997 Chevy Corvette
    Registered User Three Rings GWerks's Avatar
    Sep 11 2010
    Grand Rapids, MI
    O-ring and stock clips, just like if you were installing stock injectors. No leaks for me.
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    If you wanna get the nozzle way down in the hole you gotta get the rail spacers and injector spacers swap the stock o-rings over.
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Jan 11 2007
    Salt Lake City, Utah
    The o-rings seemed fine for me, and they fit well enough for me with no spacers. I'll check for leaks when the car's running for sure though. Word is that you're supposed to twist them so that the connector is parallel to the rail flow for best spray pattern. Just repeating what I heard.
    ** GT2860R-7 S4 Build Log--
    LOOKING FOR:
    --Late 2.7t Block "BF"
    Sep 11 2009
    NE
    #4 grind manifold posts down 1/8" -1/4".
    Dec 14 2008
    Finland
    is it common for EV14s to have leaks and therefore you should change the lower O-ring? I´ve never heard anyone changing anything but the reason why I ask is I have huge boost leak between one injector and intake manifold. Haven´t checked yet is the O-ring seated properly but they were lubricated before install.
    Can someone post I pic how the OEM O-ring differ from the EV?
    Veteran Member Four Rings Sole_'s Avatar
    Oct 29 2009
    Definitely get the injector hats. When tuning at 2nd gear WOT, 2 popped off the fuel fail since it was too small.
    Imola<3
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by Mikse View Post
    The ev14 o ring on the bottom is smaller than a stock one. You should change them.
    Dec 14 2008
    Finland
    So basically I could swap lower O-rings from stock injectors? Is the O-ring´s inner diameter same if I take the OEM as a model to buy correct size?
    Dec 14 2008
    Finland
    Changed the lower O-rings to thicker OEMs but I'm still leaking from one injector. As there are more than one type of EVs there are also different length injectors. My EV14s came with EPL fueling kit but don't exactly how long they are. Can someone confirm should or shouln't I install these injectors with spacers between fuel rail and IM? I have rs4 intake manifold and fuel rail. At the moment I have 5mm spacer between fuel rail and manifold because it look that the injectors would go too deep inside the manifold without spacers.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    With injector hat and fuel rail spacer.
    Veteran Member Three Rings protocol_droid's Avatar
    Nov 20 2009
    01.5 Nogaro Avant 6spd Sport, 14 gs350 FSPORT
    socal
    The EPL (KO4) kit comes with injector hats already installed, spacers for the fuel rails and you use the stock injector clips. There was another post by 034 that confirms this somewhere if you search.
    01.5 B5 S4 Nogaro Avant 6MT Sport, OE RS6 turbos, 034 DP, 034 3.5 exhaust, ER IC's, Torque Factory Y-pipe/Heads/Built engine, 034 2.0T coil conversion, JHM Shifter, Stasis Ohlins MS Coilovers, 18Z cayenne and 034 rear brake upgrade, Sparco carbon evo and evo2 seats
    14 Lexus GS350 FSport
    22 Audi etron. Navarra blue sportback s-line.
    Dec 14 2008
    Finland
    Quote Originally Posted by FlyboyS4 View Post
    Is that with RS4 parts or oem? It looks that the lower O-ring needs to come out from the "tube". How thick fuel rail spacer you have and do you know the length or you injectors (or are the from EPL so same as mine)?
    Quote Originally Posted by protocol_droid View Post
    I believe EPL K04 kit is ment to use with S4 rail and manifold but RS4 parts require shorter injector and thats why there is no need for hats.
    Jan 06 2007
    Mk7 Golf R
    FL
    EV14 injector, I did not measure the length. EPL hats and spacers, stock manifold and fuel rail.
    Veteran Member Three Rings PovGRide742's Avatar
    May 07 2009
    2001.5 Audi S4, 2010 Audi A6
    Womelsdorf, PA
    For proper securement of Bosch EV14 52lb injectors...
    Size: Standard, 48.65mm o-ring to o-ring (part #0280158117)
    Spacers: Yes
    Hats: Yes
    Clips: Yes
    O-rings: OEM
    See my thread for when I researched this: http://www.audizine.com/forum/showth...ssary-Hardware
    2001.5 Pearl White Audi S4
    034 Carrier / DPs / Exhaust / Inlet Hoses / MAF Hose / Y-Pipe / X-34 | AAM DS | Apikol Diff/Snub Mounts | APR Bipipe | AWE Gauge / DTS / SMICs | B&M Oil Cooler | CM Clutch / Flywheel | DW FP | Enkei RPF1s | EPL Fueling / Tune | FT F21-BTs / Inlets | H&R Premiums | Hotchkis Sway Bars | INA FSI | JHM BBKs / Knob / Trio | SAMCO Hoses | STE PPD | Stern Motor/Trans Mounts | Zeitronix ZT3
    Nov 08 2007
    Lake Tahoe, CA/NV
    Quote Originally Posted by PovGRide742 View Post
    Spacers: Yes
    Hats: Yes
    Clips: Yes
    O-rings: OEM
    I did this same setup. Have had zero problems. 034 did a nice job of providing all the proper parts. The OEM orings just got a little more meat on them. I didn't like the way the Bosch orings felt a little loose. The OEM are so close in size but a little more snug. Have had zero leak issues.
    Current Rides:
    @audijedi
    Dec 14 2008
    Finland
    Spacers: Yes
    Hats: Yes
    Clips: Yes
    O-rings: OEM
    Thanks for the link but the difference between S4 and RS4 parts is that OEM RS4 injectors are only 38mm long so If I'd use hats I'd need even thicker spacers.
    The picture flyboy posted the injector is much deeper than where the stock injector is. I quess I just need to install the injectors as deep as they go inside the RS4 manifold and hope theres no leaks...Or I have faulty manifold
    May 07 2009
    Womelsdorf, PA
    Ah, didn't see you have an RS4 manifold... my apologies.
    Jan 11 2007
    Heads up, I change my opinion from above. Do what you can to preemptively avoid leaks. I installed mine with no spacers, EV14 o-rings and had a pretty bad leak or two. Took everything off and ground down the fuel rail posts 1/8" - 3/16" and reinstalled. I have to double check now that it's been a minute, but that took care of the lower leaks. [It was a huge pain though, because I first started shaving the posts down with the intake mani installed on the car. I cut a wire to the coilpack with my grinder, and the thing I was using to cover the intake ports came off. Needed to repair the wire (obviously), and take the intake mani off to clean the debris out of the intake ports. No fun. So yeah, just deal with it up front.]
    LOOKING FOR:
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    I had the EV14 O-Rings on and no clips and they were super loose and leaked. Got new O-Rings from the dealer and installed my injectors again with no clips and they are super tight.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Jan 09 2011
    Pleasant Gap PA
    This is full of half truths. You can:
    A. Certainly run purple spacers from ID or similar size other brands on the injectore tops. You then do not need to run clips (in fact cant) and replace the bottom o ring with a stock sized one since the ev14 ones are a touch small.
    B. You can install the injector without a purple size filtering hat (ID talk) and use the injector clips and replace the lower o ring with an s4 one. This seals perfect and puts it in the hole quite deep
    You do not need any fuel rail spacers of any kind. You do not need anything but injectors technically and you reuse the stock injector clips and lower o rings if you are cheap.
    I promise this is the truth listed above.
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    Quote Originally Posted by sweets4style View Post
    I haven't gotten around to my 605 install yet, but I'll ask the masses about my setup to be sure I'm prepared.
    I got 72lb injectors, clips, hats and fuel rail spacers/hardware with my EPL kit. Since you say I don't need the fuel rail spacers, but to replace the Bosch o-ring with a stock o-ring, are they including fuel rail hardware just to call this a "complete kit"?
    It makes more sense to install the purple hats and leave the spacers out to ensure a snug fit. Maybe they're included just incase you decide to retain the Bosch o-rings for 'that much more'? Not exactly sound logic if this is the case.
    I think I will install mine with hats and stock o-rings first since it seems to be the concensus...
    WTB - Electric high flow fan kit - FORGE 007 DVs
    Sep 11 2009
    NE
    There must be some difference between early and late (A6/allroad) style manifolds as mine sit just fine and don't leak in my allroad. The bosch o-rings (whatever color they are, I am using 1000cc injectors) are in pretty tight, no looseness anywhere.
    Maybe early style manifold has slightly larger holes.
    Jan 09 2011
    Pleasant Gap PA
    I have installed ev14 injectors in both early and late style manifolds as well as an rs4 manifold, although it was using a stock s4 fuel rail on top. I have also installed the ID 850's which are an LS9 application which are shorter but they do indeed need much longer adapters. The standard length ev14 that you get from most tuners and ID etc require no spacer but should have the lower oring changed for good measure and the clips to be used. I personally like the shortest ID (purple) hat because it has a 9 micron pre filter thats replaceable and built into it. Just a nice added feature. When using them you do no use the injector clip. The injector will sit flush with teh fuel rail cup up top and be quite a bit into the manifold.
    If I took pictures during the installs that actually showed any of these with clarity I would post them but I didnt.
    Jun 29 2010
    Absolutely no clips required, huh? I wonder why EPL would send all this stuff if we don't need it?
    Deactivated Two Rings
    Jun 07 2010
    Stratford, CT
    For S4 intake manifold and fuel rail, the injectors use the ev14 orings that come installed on them, with the hats, spacers, and clips. For a while now we have been shipping hats that allow the use of the clip for the fuel rail, as well as a clip to keep the hat attached to the injector. Every set lately has been leaving the shop with the hats already installed on the injector to help avoid any confusion.
    The oring size difference isn't the problem; its that the o-ring height on the EV14 body is slightly higher than the OE injector, so if you were to install the injector into the fuel rail without a clip and bolt down the fuel rail, you'll notice you can move the manifold side o-ring in and out of the manifold. The spacers and hats may seem like a weird combo, but with both those installed there is no chance the injector can move around.
    RS4 fuel rails and manifolds need a different size spacer, but may not require the hats (it's been forever since we've even had a car through the shop with an RS4 intake manifold and OEM RS4 fuel rail).
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by DaveM@EPL View Post
    that made it simple stupid. I loved it, I hate thinking at night
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Jan 09 2011
    Pleasant Gap PA
    Ok you forced me to put the time into picturing this for you all since we are gettiong incorrect info.
    I will do both stock s4 fuel rails on both box and spider look manifold and do it with the clips and no spacers and then without clips and with spacers.
    YOU DO NOT NEED ANY OF THESE above mentioned WITH EITHER MANIFOLDS.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Yes, I'm bringing up an old thread but doing so for documentation purposes.
    I did as Dave said above and have zero leaks and everything works as intended. I have the EPL Stg3 fueling kit with an S4 fuel rail and S4 intake manifold. Ran the EV14 o-rings, hats and spacers. Clipped the hats to the injectors and reused factory clips to clip hat to fuel rail. Needed a few shims to bolt the fuel rail down which was included in the kit. Zero fuel leaks. Injectors sit snug.
    -Doug
