Page 6 of 8 FirstFirst ... 45678 LastLast
Results 201 to 240 of 290
  1. #201
    Veteran Member Three Rings majerrahim's Avatar
    May 31 2013
    Miami FL
    didnt you said it was 350???
    AWE EXHAUST, Downpipe, AWE FMIC , Carbonio Intake, AEM water/methanol kit, CTS BorgWagner K04 turbo kit+Test Pipe, APR K04 software E85 24/7, alu kreuz drivetrain stabilizer, KW V1 , AWE boost gauge, CTS catch can kit, Sline steering wheel with shift paddles, inlet hose, intercooler hose kit, rear diff mount, transmission mount, enkei19in with michelin pilot super sport 255/35/19, ECs slotted rotors with stainless steel lines and hawk hps 5.0, rs5 grill, SPC adjustable control arm
  2. #202
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by homelessNY_LI View Post
    What is a faulty battery?
    I suppose. It always gives me a 'battery will charge when running' they replaced it
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
  3. #203
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Im confused, I checked my battery in the trunk yesterday. This is what I found.
    It says VARTA JCB 12V 105AH 580A DIN, and the BEM code does not match the info I find in VCDS.
    Why is the B replaced with 1 ?
    If I want to use a Varta Ultra dynamic AGM G14 850A 95A will that be a problem, as its capacity is not the same (95ah vs 105ah), and the CCA is 850A and not 580A as the OEM battery ?
    What code do I use ?
    This is the battery I want to use and what the VARTA homepage says Im supposed to use, the QR code is not working.
    hlp :)
  4. #204
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    You need: Varta H15 105/950...
    http://www.eurobateria.es/BTVARH15/en
    It will match with yours genuine figures, ignore 580 see en/sae figure of oem its 950! I would not go lower with Ah specialy in Norway:)
    What are your genuine battery(4L0915105) dimensions 353*175*190 or 390*175*190, second one should be correct ?
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  5. #205
    Nov 13 2006
    Oslo, Norway
    Im not sure what the dimensions are, Ill measure later today and post here.
    I did found and order the Varta H15 battery which is identical as the OEM, Ill pick it up tomorrow and see if it has a BEM.. If not I might need help decode the coding ;)
  6. #206
    Oct 21 2012
    Earth...
    Quote Originally Posted by 029kid View Post
    H14 is shorter, if you get H15 just change last digit of current coding and you fine if no BEM.
  7. #207
    Established Member Two Rings toast88's Avatar
    Mar 07 2012
    I replaced my battery yesterday. But it still acts like it is low on power - lights don't come on when I unlock the doors, radio doesn't turn on unless I press the button.
    I guess this means it must be coded in order for the car to "know" that the battery has been replaced. You would think the computer could tell that there is a fresh battery
  8. #208
    Nov 13 2006
    Oslo, Norway
    Was your car in power saving mode when you changed the battery?
  9. #209
    May 09 2015
    usa
    My '09 has been sluggish to start in the mornings lately, but the MMI still shows the battery at 100%, even after it just struggled to start the car. I have a new battery waiting to be installed -- I just wanted to read through this thread to see what I needed to do as far as coding. But now I'm wondering if I even need to code the new battery, since I never hit low power mode. Should I just swap the battery and not worry about coding it? Why is my battery meter still showing 100% when the battery is obviously struggling to start the car?
  10. #210
    Veteran Member Four Rings doowopaudi's Avatar
    Aug 10 2011
    North Whittier
    Quote Originally Posted by misterpepper View Post
    My car has been struggling to start up at times too. I think i'll buy one and have it ready too.
    I actually read through the entire thread and some ppl report they didnt code and their car works fine. Others report they needed to code.
    ::2010 A4 Premium+ Quattro::6SMT::Meteor Gray Pearl Effect::35% 3M tint all around::Vag mods::debadged::RS4 replica grille w/ fog grilles::LED interior lights and lic. plate lights::ST Coilovers::19x9 OEM A5 Peelers::245/35/19 Achilles ATR Sport::Underseat Storage Bins::Zubehor Diffuser::Door Handle storage bins::LED reverse Lights::
    Former: 2008 A4 S-line::2007 Mazdaspeed3::1991 VW Cabriolet
  11. #211
    May 09 2015
    usa
    I just checked again a few minutes ago and my MMI is now showing 70%, so not only is it working correctly, but my battery is failing. It seems like the MMI wouldn't give you much warning before the battery gives out, at least with the battery mine has (according to the dealership there were something like 6 different batteries for my model year). Looks like I'll go ahead and swap it out tonight. Now, do I recode???
  12. #212
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    I just changed 1 digit of the BEM code since my new battery didn't have one. The battery meter went from 15% with the old battery to 100% after the coding.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
  13. #213
    May 09 2015
    usa
    I don't know why I'm making this hard. I have a vagcom -- it's not like recoding it will be that big of a deal. I think I'll swap the battery first without recoding for a few days, to see if it goes back to 100% by itself, but I'll recode regardless. Thanks.
  14. #214
    Nov 13 2006
    Oslo, Norway
    New battery bought, Varta H15 - the dimensions is exactly like the OEM.
    This is the current coding of OEM battery.
    What will the new code be?
    VCDS shows 10 digits (serial number) on old OEM battery, new Varta shows 12 digits.. What do I do?
  15. #215
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Just add a Zero and a One?
  16. #216
    Nov 13 2006
    Oslo, Norway
    Serialnumber is supposed to be a 10 digit code. If adding 01 to the current code, it's 12 digit.
    Whats the meaning behind adding 01?
  17. #217
    Mar 26 2012
    Charlotte, NC
    The easiest thing to do is to change 1 digit in the code. so it knows its a new battery
    - (N) Part number - (11 digits) - kept this the same as the previous battery.
    - (V) Vendor code - (3 digits) - in my case VA0 for Varta
    - (S) Serial number (10 digits, but leaving out the starting 3 digits of manufacturer)
    NNNNNNNNNNN VVV SSSSSSSSSS
  18. #218
    Nov 13 2006
    Oslo, Norway
    I really appreciate you helping me :)
    So what you are saying is, as long as the new battery has the same specifications I can just edit one of the 10 digits in the serialnumber so it triggers "new battery installed" mode?
    This is the current with OEM battery
    4L0915105 JCB 210413D0SD
    New code
    4L0915105 JCB 210414D0SD
    As shown, I changed the digit 3 with 4.
    Is that correct?
  19. #219
    Mar 26 2012
    Charlotte, NC
    Yup
  20. #220
    May 09 2015
    usa
    I put my new battery in a few days ago without recoding anything. No problems so far, and battery indicator shows 100%. I will recode anyway, since I have another change I want to make at the same time, but I don't think that skipping the recode is a problem if your battery hasn't gotten to sub 10% levels.
  21. #221
    Jun 05 2009
    Scottsdale Arizona
    So, the lack of responses regarding the question of an Optima Battery replacement had me doing some research and staring at pictures of the battery bracket and posts etc.
    It looks like the dimensions are as follows:
    Optima 8020-164 35 REDTOP / Interstate MEGA-TRON PLUS 94R/H7 790 CCA
    Length: 9.38, 12.44
    Width 6.75, 6.94
    Height 7.69, 7.50
    Weight 31lbs , 42.9lbs
    Looks like the clamp base on the Optima will work just fine. So I'll take a look around for a good price. Had an Optima in my VW TDi and was a darn good a long lasting battery. Losing a little weight is not a bad thing either.
    Looks like the price is right too: $174 from Summit Racing
    UPC: 811405001642
    Battery Usage: Starting
    BCI Group Number: 35
    Volts: 12 V
    Battery Terminals: Top
    Battery Type: AGM
    Cranking Amps at 0 Degrees F: 720 amps
    Cranking Amps at 32 Degrees F: 910 amps
    Reserve Capacity: 90 minutes
    Length (in): 9.380 in.
    Width (in): 6.750 in.
    Height (in): 7.690 in.
    Weight: 31.700 lbs.
  22. #222
    Oct 23 2014
    Mississippi
    Quote Originally Posted by booost View Post
    Should be this one: AutoCraft Platinum AGMBattery, Group Size H8, 900 CCA Part No H8-AGM. It was like $120 after the pick up in store discount and rebate. As for the code, I changed one digit in the BEM code that was already in there and it seems to work fine, the battery meter has gone back up to 100%.
    Thanks booost and every one else for this info! I got this exact battery. And coded it by changing the last number on vcds, cleared all my faults, and enabled the battery level meter. I have a 2010 Audi A4 premium with the concert ami radio. Everything is all good now. Spending 157 after taxes and core, and got 20 dollars for joining the speed perks membership.
    There's a 30% off coupon for advanced auto if you spend over 50 dollars by the way. Code is: TRT30. Ordered online and picked up in store.
    2010 Premium Phantom Black A4 with Sport Package Suspension and Wheels
  23. #223
    Aug 10 2011
    North Whittier
    Just replaced my OEM battery with an AutoZone Duralast Gold *** 900 Cold Cranking Amps (1000 Cranking Amps) ***. 150 reserve minutes. 5 year warranty for $149.99 (3 year free replacement and 2 year prorated)
    The old battery was struggling. My car wouldn't turn on right away and then my interior cabin lights wouldn't turn my lights on either while I sat in the car. I bought the new battery before I ended up stranded somewhere, went home and installed it and now everything is back to normal. No recoding done because I don't have vag-com. After intalling the new battery, i went back to AutoZone to return the OEM core for $18 credit. Before they issued me credit, I asked them to test the battery and sure enough, it said "Bad Battery". I'm glad I changed it now. Hopefully this one lasts me another 5 years, since I plan on keeping this Audi for a looong time.
  24. #224
    Aug 10 2011
    North Whittier
    I bought my car CPO on April 2, 2013 and I am the second owner. My car is a 2010 A4. Is there any way to tell whether this is the OEM battery that came with the car when it was originally sold to the first owner? Also, is there a way to know when my car was built (exact day or month and year)?
    This is the battery that was in my car and I didn't find any dates. If this does happen to be the original battery, then I am really impressed. This battery would have lasted from 2010 all the way to today! That's 5 years and a few weeks (or months depending on the install date).
  25. #225
    Aug 10 2011
    North Whittier
    Quote Originally Posted by richardm0025 View Post
    Not sure if I did this correctly. I installed s new battery and coded it just wondering if these numbers make sense. Car doesn't seem to be in the low battery mode (forgot the term) and I coded the battery meter to show on the mmi without having navigation and showing 100%
    Any thoughts?
    I guess my MAIN question is as long as the car sees a new battery code, it will work as if the dealer installed it? It would have been nice to have the BEM code but does it really matter if the car sees a new number that doesn't totally 100% MATCH the new battery...? I would think that my old battery and new battery both have the same characteristics so everything should be fine... Just looking for some thoughts on this one!
    I don't have a vag com, but exactly how does one arrive to the screen shots shown above when coding the battery? I am currently in search of someone locally with vagcom who can assist with coding and I want to make sure I provide instructions on how to arrive to the correct screens. Thanks.
  26. #226
    Oct 23 2014
    Mississippi
    Quote Originally Posted by doowopaudi View Post
    It's on the top of the pictures. After plugging the vagcom cable in and downloading the software. Open vcds up and select the setting "19-gateway" then it should say long coding like the last picture or battery status on 1st picture. Just play around with it alittle. It's not too hard. Good luck.
  27. #227
    Veteran Member Four Rings kwbdc's Avatar
    Mar 29 2012
    2006 Mazdaspeed6 RIP
    Seattle/WA/United States
    Quote Originally Posted by A4 Centaur View Post
    Length: 9.38, 12.44
    Width 6.75, 6.94
    Height 7.69, 7.50
    UPC: 811405001642
    Volts: 12 V
    Battery Type: AGM
    Weight: 31.700 lbs.
    Did you end up getting the Optima? I'm thinking the same, I've used the red and yellow top on previous cars and they are excellent batteries.
    2012 Audi A4 Premium +MT, Quattro, Xpel bra, SLine BBS CI-R 20x8.5 ET 32
    Mods: APR HFC/DP, APR K04, Bilstein PSS10 Coilovers, Okada Coilpacks, AWE Boost Gauge, Eurocode SSK, OSIR CF Spoiler, APR Carbonio Intake, AWE Exhaust, OSIR CF valence, ÜSS Adjustable Stabilizer set, Alu Kreuz, RS4 grille, Fluidampr,Apikol differential, folding mirrors,Brembo GT BBK, Deval CF splitter,ECS skid plate, RS4 rear brakes, Snow performance Stage3
  28. #228
    Sep 26 2013
    San Jose
    #necro
    Surprisingly my 2010 is still on the OEM battery, and showing 30%. Good thread, though pretty repetitive. People should go back and read.
    Didn't know there was a "low power mode". I was just going to wait until I had trouble starting to swap the battery, but now I'm going to swap right away to avoid the "required" coding to get out of "low power mode". I wonder if the Carista app handles recoding, would be awesome if it did!
    2012 Stronic | Sports Diff Pkg | Chipwerke Pro | aFe Pro Dry | Forgestar F14 18x9 | EBC USR Slotted Rotors | EBC Yellowstuff Pads
    SOLD 2010 B8 A4 Tiptronic | Stasis Engine Tune | Michelin Pilot Super Sports | Forgestar F14 18x9 wheels | Stoptech Powerslot rotors | EBC yellowstuff pads | Bilstein PSS10 - SOLD | aFe Pro Dry Filter
    Me @ Laguna Seca Raceway - https://www.youtube.com/watch?v=z7s8S1Uh7uc
  29. #229
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    My 2009 still says battery 100%. Fingers crossed it stays that way.
    My 2009 A4 Prem+ Build thread
  30. #230
    Mar 07 2012
    I hate the batteries on these cars. It is pretty ridiculous you can't just replace the battery. My car has been stuck in low power mode for about 6 months because no one I have taken it to can seem to figure out how to program the battery to get it back to normal. I have the carista app and i do not believe it does battery coding, although I think I read that it was something that could happen in the future.
  31. #231
    Sep 26 2013
    San Jose
    Quote Originally Posted by toast88 View Post
    Wow, that's ridiculous that an Audi service center wouldn't be able to do it.
  32. #232
    Senior Member Two Rings PCHS4's Avatar
    Apr 22 2011
    Arizona
    Picked up a Bosch AGM Battery for $187 at Pep Boys using the 20% online coupon. Install and coding went fine. Just changed the last digit of the battery serial number.
    2011 S4 Phm Blk, DSG, APR Stage II+, EuroCode Headers/DTS/Sway Bars/Drop Links, Milltek Resonated, APR Intake (rear backpipe), SPC UCA, KW V3, HRE FF01 19x9.5 ET45, PSS 275/35/19.
  33. #233
    Mar 07 2012
    Quote Originally Posted by audiAYYY4 View Post
    Yea I asked them to do it when I had it in for the Oil consumption Piston Ring change, maybe the just didn't feel like doing it, or didn't understand what I was asking them to do
  34. #234
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    Quote Originally Posted by Lambda13 View Post
    Um on an 09 without Nav? Links
  35. #235
    Jul 07 2012
    Boston, MA
    Quote Originally Posted by bluetori View Post
    What do you mean links? I have the battery meter enabled on my MMI and it says 100%. I've had the car since about 30k miles so unless Audi swapped my battery without telling me or charging me mine's still chugging along.
  36. #236
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    same and I'm the original owner. Currently at 97K miles.
    I have Nav.
    My current rides...
    Audi
    Jetta
  37. #237
    Jan 14 2010
    Georgia
    But you don't have Nav correct? I thought you enabled it via VCDS, I don't have Nav and it's not on my car. I meant if you had a link for coding.
  38. #238
    Jul 07 2012
    Boston, MA
    Oh, ya no nav. I wasn't the one that enabled the battery meter either. I don't even remember who did it. May have been @Project Quattro.
  39. #239
    Established Member Two Rings theSaint024's Avatar
    Jul 16 2014
    SF CA
    How complicated is it to replace the battery on a B8 A4?
    Has anyone tested voltage readings with a voltmeter? Using the mmi battery meter seems pretty inexact. All readings say 30% or 100% from what I've read (exaggerating). I suspect my battery is at the end of life but I don't know what the replacement voltage is or even what full voltage is on the OEM battery. I'm reading 12.0 +/- 0.1. From what I've read about car batteries in general, 11.9 is dead. Can anyone confirm this? My wife's 3 month old car has read as high as 14v. I'm pretty sure I'm just going to switch it out but hoping for some more definitive numbers from someone who's checked the voltage before and after a swap.
    2013 allroad - ibis white P+ - The answer is... "it's an allroad bro."
  40. #240
    Oct 23 2014
    Mississippi
    Quote Originally Posted by theSaint024 View Post
    Has anyone tested voltage readings with a voltmeter? Using the mmi battery meter seems pretty inexact. All readings say 30% or 100% from what I've read. I suspect my battery is at the end of life but I don't know what the replacement voltage is or even what full voltage is on the OEM battery. I'm reading 12.0 +/- 0.1. From what I've read about car batteries in general, 11.9 is dead. Can anyone confirm this? My wife's 3 month old car has read as high as 14v. I'm pretty sure I'm just going to switch it out but hoping for some more definitive numbers from someone who's checked the voltage before and after a swap.
    I've tested the battery for our cars with a multimeter. You are correct 12 and above is good (without the engine running). With the engine running it should jump up to 13-14s. Your battery may still be good. I took mine out to be tested at a autozone. But still had battery issues after fully charging it there twice. I ended up getting a new battery and it fixed my issues.
