This is how I changed my battery on Audi A4 2009 (B8)
You may use this as reference only. I am not a mechanical, electrician, Audi/Vw mechanic, etc.
Note: Coding the battery did not seem to be required in my case.
Step 1, open your trunk and use the latch to open the cover.
Step 2, Unscrew spare tire and remove.
Step 3, Remove plastic cover
Step 4, Remove tool holder and tools
Step 5, Remove Spare Wheel holder using 13mm socket.
Step 6, Remove Battery Holder using 13mm socket.
Step 7, I don't know my radio code so I connected an Aux battery to the trunk to keep power in the car. NOTE this is not safe as when you remove the battery the Positive is still LIVE so make sure it doesn't touch the body or yourself!!
Step 8, Remove battery cover, by just un-clipping the two bottom sides
Step 9, Use a 10mm socket, to loosen battery terminal clips.
Step 10, Remove Black Hose into Negative side
Step 11, Remove the Positive and Negative. Make sure they don't touch and the Positive does not touch the car body!
If coding is required the serial # is engraved on the battery and brand is on a sticker on top of the car.
Step 12, put battery in and unplug batter in hood if one was connected.
Reverse what order of how you took out old battery.
Turn on car and drive for a little bit. In my case I plunged in VAG and erased all the errors (low voltage errors)
Did I miss anything?
