Page 15 of 25 FirstFirst ... 51314151617 ... LastLast
Results 561 to 600 of 967
  1. #561
    Oct 30 2009
    New Jersey
    2004 A6 2.7 s-line:need help with wheel spacer size
    Ok, so I got a newer set of wheels: ALY58851 Audi 2011 A6 10 spoke wheel, Bolt Pattern: 112mm Offset: 48mm Audi Part Number: 4F0601025CP with tires 245/40 r 18 Conti's.
    My OEM wheel was ET43, with 235/40R18 tires.
    I Installed one wheel on the front and it is rubbing.
    My question is what wheel spacer size I need:
    - 5 mm the difference of offset, or
    -10 mm too make up for the wider tire?
    thanks
  2. #562
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    Quote Originally Posted by bau2.7t View Post
    thanks
    To answer this you need to know the width of the wheel
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
  3. #563
    Veteran Member Four Rings Widebody4.2's Avatar
    Jan 08 2012
    S6 Avant
    Central MA
    Has anyone experienced the rear being off. . . As in the left wheel is where the offset should be and the right wheel is tucking both have the same camber per last weeks alignment,
    2017 C7.5 S6 APR Stage 3
    RIP DAZ
  4. #564
    Apr 03 2007
    02 S6, 03 A4 Cabrio, 96 Mustang GT
    Frisco, TX
    welp, ended up with 18x9.5 et30 and 255/40/18s
    hope it doesn't end up looking ridiculous.
  5. #565
    Aug 17 2014
    United Kingdom
    Thinking of getting these.... 8.5j x35x19 Ft and 9j 275x35x19 BBS rim.. for my Black 2.7t Quattro Avant
    http://www.ebay.co.uk/itm/1815045396...84.m1423.l2649
    Thoughts on style? anyone see any issue with the rear being a 275 .... its a narrow body A6 by the way
    [IMG][/IMG]
    Currently have 235x45x17 on stock et45 rims..
    Will also be getting coil overs soon...
  6. #566
    Apr 03 2007
    Frisco, TX
    here's how it ended up
    Eurotek UO03 (BBS LM rep)
    18x9.5 et30
    255/40/18
    Eibach Pro-kit
    5mm spacers up front for now to clear the brakes. I'm going to try a set of 3mm later. There is a little too much poke for me up front and the driver side front hits the upper inner fender bolt.
  7. #567
    Junior Member Two Rings
    Apr 21 2014
    Jurmala/Latvia
    Does someone know why Audi s-line 19" rims are manufactured by two companies: Speedline and BBS?
    (picture from google..)
  8. #568
    Aug 17 2014
    United Kingdom
    Hi.. i want to buy these ... http://www.ebay.co.uk/itm/2912409445...%3AMEBIDX%3AIT
    But they are 5x100 .. now i know i need 5x112...
    I have had a look for some adapters.. the ones i have found are for 5x100 hubs to fit 5x112wheels...
    I need them the other way around...!! are they available?? or will wobble bolts work??
    How do wobble bolts work?? and are they safe??? does anyone on here run with them???
    Cheers... Colin
  9. #569
    Established Member Two Rings CHRISTOPHÉ's Avatar
    Apr 01 2014
    2004 All lowww'd 2.5TDI 6mt
    Plymouth,UK
    H and r do them the other way round I'm sure and available through venom Motorsport. Phone rich he's every good. Wobble bolts you may get away with if they were 5x110 or 5x114.3 so vaux/Saab or any jap other wise wobble bolts won't work. Hope this helps.
    EURO FACELIFT AVANT REAR TUB - SWAP FOR YOUR NARROW US SPEC ONE, PM ME
    WANTED FRONT PLATE RECESS INFILL
    A8 4.2 QS sold
    2004 Allroad 2.5tdi Manual
  10. #570
    Apr 01 2014
    Plymouth,UK
    Where in uk are you? I'm running 8.5/9.5 with matching 245/40/19 but i have an allroad. Sure they would go on tho as I'm also running 25mm spacers at the moment but want 35's!
    A8 4.2 QS sold
  11. #571
    Sep 27 2011
    Vancouver, BC
    Niche Verona 20x9 et25 no spacers...yet. 255/35/20. KW coil overs...set about 1 1/2" lower than that Bilstein kit....
  12. #572
    Jul 18 2009
    D2 S8, E61 535xi, B5 S4
    Subdivisions, NW burbs
    Picking up my c5 allroad next weekend. Really loving these setups. I want to safely push the envelope without rubbing period. Looking to order some forgestar cf5v's in 19x10. What is safe et? Sorry, but new to c5 platform. I see some 19x9.5 and 10 posted with a seemingly high et not to be rubbing inside. Also, 255 or 265/35 for tires? I realize certain manufatures run wider or narrower. Thanks for any help...maybe just go with 9.5 wide to be safe
    18x10 et35 clear uprights?
  13. #573
    Veteran Member Four Rings stef2.7t's Avatar
    Mar 22 2008
    '02 S6
    D'edmonton
    Quote Originally Posted by happy2B5 View Post
    Tried replying to your PM, your inbox is full.
    Use everything here along with this website, http://www.willtheyfit.com/ and you should be able to pick a set fitting your requirements.
    -Stefan-
    '02 S6 Atlas Grey
    '01 A6 2.7T MT Sport --- Sold
    '95 GTI 2.slo --- Sold
    Need Radio Keys, VAG-Com? PM Me, bring beer
  14. #574
    Jul 18 2009
    Ha. Thats the site I used to come up with the 20mm extra clearance needed. Thanks. I know I can space them out and should be ok. Just didnt want to have to redrill to be able to run spacers. Thanks again. Ive read entire thread 10 times in last week.
    Looking at these
    18x10 et35 or 15
    And these
    18x9.5 et22 or 12
  15. #575
    Veteran Member Four Rings A6Avant's Avatar
    Mar 09 2010
    T4 Eurovan 2.5L 5spd (Currently under construction). MKII Jetta (GLI in the making :)
    Salmon Arm , B.C. CANADA
    What are the first set called?
    Jeremy-
    1999 C5 Avant 2.8, 1992 T4 Eurovan 5 spd, Slammed and gift wrapped!
  16. #576
    Jul 18 2009
    Wedssport sa67r. jdm so will need redrill, wobble or m14 to m12 stud conversion
    Edit: Weds ordered. With 265/40/18 tires. Will post once mounted and installed. Picking up the car tomorrow! Cant wait!
  17. #577
    Established Member Two Rings _rouse_'s Avatar
    Aug 31 2013
    Portland Oregon
    Does anyone know where I can get some ipp level arms at?
  18. #578
    Veteran Member Four Rings blkrhyno's Avatar
    Mar 24 2008
    2004 audi a6 2.7T 2005 Nissan
    Brooklyn, New York
    Quote Originally Posted by _rouse_ View Post
    PM sent.
    OEM + work in progress
  19. #579
    Jul 18 2009
    265/40 r18 mounted. Time to see how these fit
    Pretty excited to put them on
  20. #580
    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    cant wait
    IG:@steadysupreme
    Pics&Detail
  21. #581
    Senior Member Three Rings A6Rick's Avatar
    May 31 2011
    New York
    Quote Originally Posted by $teady$upreme View Post
    cant wait
    *breaks out the popcorn*
  22. #582
    Jul 18 2009
    Quote Originally Posted by A6Rick View Post
    Already had 15mm adaptor not enough to clear uprights. Was a little worried about that. Need 20 at minimum. Need to 100% confirm before ordering new ones.
  23. #583
    Veteran Member Three Rings Slavchob's Avatar
    Apr 27 2010
    2003 Audi S8
    Syracuse NY
    OZ Futura
    18x10 ET33
    215/40/18
    Nankang NS-20
    H&R coilovers at 23" GTF
    No fender modification. No rubbing with the amount of stretch. Had the front camber at - 2.5 with the rear at - 4.2.
    -Slavik-
    2004 Audi A6 2.7t Night Blue Stage 1+
    2003 Audi S8 Brilliant Black bagged and 6 speed swapped
    Instagram: @slavchob
  24. #584
    Jul 18 2009
    Gorgeous! Dont think i could ever run that narrow a tire, but damn that looks good.
  25. #585
    Veteran Member Three Rings Chris_s1's Avatar
    Apr 07 2014
    Miami
    beautiful, wow
  26. #586
    Jul 18 2009
    Test fit only and verification of upright clearance using 15mm adaptor + 5mm spacer. All seems good. I may get 21mm adaptors made just to be safe though. All this for nothing as they are going away for winter storage. Oh well, had to verify spacer width. I'm pretty much sold. Entirely different feel to the car with these. 18x10 et35, 20mm spacing with 265/40 tires
    Now for some IPP arms and more level 1 low
  27. #587
    very nice. So you didn't redrill them but used adapters right?
    IG:@steadysupreme
    Pics&Detail
  28. #588
    Jul 18 2009
    Correct. Needs 402 mod but im waiting for a set of IPP arms first.
  29. #589
    Mar 22 2008
    '02 S6
    D'edmonton
    Quote Originally Posted by Slavchob View Post
    OZ Futura
    18x10 ET33
    215/40/18
    Nankang NS-20
    How is the ride quality? Any fishy feel when going left or right?
    -Stefan-
    '02 S6 Atlas Grey
  30. #590
    Apr 27 2010
    2003 Audi S8
    Syracuse NY
    Quote Originally Posted by stef2.7t View Post
    With all honesty I think it's great. It handles surprisingly well with it being being as low as it is, and stretched tires. Not fishy at all. However, I didn't necessarily track it at at that setup. I'll do it again come spring though, that's for sure.
    -Slavik-
  31. #591
    Senior Member Two Rings bloodredsmurf's Avatar
    Mar 14 2010
    Annapolis, MD
    First Allroad Setup
    What's up everyone?
    I used to own a B5 S4, up until 2 months ago when I switched to a 2001 Allroad. Got the car with 132k miles, 2.7t Manual Transmission. PO converted it to Coilovers (which I love and Hate). I've done some modifications, including; JHM SS, Navi, Full audio upgrade, and a few other things that I can't think of right now. I could keep going but the point was to post the upcoming setup for the C5! Can't wait to get these stock wheels off the car.
    It's great when it all fits in the car and I still have the front seat empty.
    19x9.5 et40 with 25mm spacers all around.
    ZE950 245/40/19 tires
    Can't wait! Will upload pictures once they're mounted, and installed on the car.
    -Pat
  32. #592
    Veteran Member Four Rings ENDEE666's Avatar
    May 04 2007
    A6 2.7T 6MT Modded. Allroad 2.7T 6MT.
    LI,NY
    ^Should look good. I run 19x10 rear with 255/40/19 on my Allroad with a net offset of et16. Fronts on mine are 19x9, still 255/40/19, net offset et20 I think.
    01 A6 2.7T, blk/blk, 6MT, SSP Tuned!, 3,996 lbs w/ me, full weight, street tires, 29+lb wheels.
    Ran an 11.8 @ 119 at MIR - Sept 2008. FIRST A6 IN THE 11's!
    Also 04 Touareg 4.2 89k with 22x10s
  33. #593
    Mar 14 2010
    Annapolis, MD
    Do you mind posting up a picture to see how it looks? Looks like you're about 5.5 mm farther out in the rear than I.
  34. #594
    May 04 2007
    LI,NY
  35. #595
    Senior Member Two Rings pearlescent's Avatar
    Feb 14 2009
    05 allroad 6sp, 2010 Infiniti EX35
    Milford Michigan
    Quote Originally Posted by ENDEE666 View Post
    Specs? Cayenne wheels? Adapters? looks really good :)
    -Matt
    Current: 05 allroad 2.7t 6spd
    Past: B6 S4 Cab 6spd, B5 A4 2.8 quattro 5spd
  36. #596
    May 04 2007
    LI,NY
    Thx. Wheels came off a Panamera 4S. Real, not reps. Yes, hub adapters that are hub centric and wheel centric, with studs. I think the offset of the wheels themselves are et61 rear and et60 front or something. Net specs are in post above.
  37. #597
    Aug 14 2010
    Buchanan, NY
    Rotiform BWE wheels
    19x10.5 square et27ish square with 2.5" lips up front and 3.5" lips in the rear.
    Tires are 255/30 19 Nitto Invo
    ST Coilovers with SPC adjustable upper control arms
    The wheels are for sale too!!!
  38. #598
    Veteran Member Four Rings VJ's A6's Avatar
    Jan 23 2007
    2000 TL; 2002 GMC 1500 Pickup
    Mr.Rictus your car done yet? Haven't seen an update on your build thread?
    APR Stage 2
    -Koni's / H&R Sport -Hotchkis Sway Bar F+ R - 2.5 Inch Custom DP's - 2.5 Inch Magnaflow Exhaust -LED Tail Lights -S6 Door Blades -Valentine V1 -35 % Tints All Around
  39. #599
    Aug 14 2010
    Buchanan, NY
    Quote Originally Posted by VJ's A6 View Post
    My buddy is moving into a new shop soon so progress has stopped for a bit. The car is supposed to get painted early next year and we're still on track to have that happen.
  40. #600
    Mar 14 2010
    Annapolis, MD
    Alright So I got the Tires mounted and installed...
    My pup wouldn't move out of the picture haha
    And I only got a picture of the Drivers Front. Damn coils are seized so I need to break them loose so I can lower the front about an inch :(
    Kinda wishing I had gone 3mm more in the front and 5mm more in the rear. But I guess I won't know exactly until I get the height of the car where I want.
    Cheers!
