Hi AZ members,
When I took my B8 A4 to the dealership today, they told me that the brake pads are worn out and need to be replaced.
As they they quoted me $295 for parts and labor, I would like to replace the pads by myself as I have changed brakes and rotors numerous times.
However, it seems like our B8 model has electric ebrake that I might need to use vag-com tool to release the caliper.
While I did search throughout the forum, some says that you need to use vag-com tool to release the rear calipers but doesn't say anything about front brakes.
Are the front brake pads as simple as working on regular cars that do not have electric ebrake? meaing can I simply use C-clamp to compress and open the calipers and swap out the brake pads?
It seems like not many people on the forum have done brake pad job.
Thank you in advance.
