Nevermind, I found it in the spare tire area under the floor mat.
E0A = No special edition
1KD = Disc brakes, rear
3FE = Electric slide/tilt sunroof with sun screen/sunblind
F0A = No special purpose vehicle, standard equipment
T7F = 6-cylinder gasoline engine 2.8 L unit 078.2
1MU = Leather trimmed sports steering wheel for air bag system with Tiptronic
7G0 = Without preparation for VTS (vehicle tracking system)
3L5 = Electric seat adjustment for both front seats
1SA = Without additional engine guard
J0L = Battery 340 A (70 Ah)
0L2 = Electric throttle actuation
3NZ = Rear seat bench unsplit, backrest split folding
C1L = Alloy wheels 5,5J x 15 Offset 41
4UB = Air bag for NAR
1LB = Disc brakes, front
8GL = Alternator 120 A
3BH = Left exterior mirror: flat, adjustable from outside
7R0 = Without side lights
6G0 = DVD changer
6XJ = Exterior mirrors: automatically dimming,electrically adjustable/heated
5MG = Decorative inserts, burr-walnut
0G7 = Tiptronic
U1D = Instrument insert w/ mph speedo, clock, tachometer, trip odometer and additionalinstruments (voltage, oil temperature)
9Q2 = Multi-function display/on-board computerwith check control
4X3 = Side air bag front with curtain air bag
3Y0 = Without roll-up sun screen
G1A = 6-speed automatic transmission
5BQ = Wooden floor in load compartment with aluminum strips on sliding door entry
1AH = Electronic differential lock (EDL)
7X0 = Without park distance control
0YS = Weight range 17 installation control only, no requirement forecast
X9A = National sales program USA
8ZA = Without AM/FM reception
2K2 = Reinforced bumpers
4K2 = Radio remote controlled central locking "SZV"
5RW = Right exterior mirror: convex (US) large viewing field
1BA = Standard suspension/shock absorption
4R3 = Power windows with comfort operation
0JL = Weight category front axle weight range 11
M70 = 6-cyl. gasoline eng. 2.8 L/142 kW V6 5V LEV base engine is T7F
6R0 = Selector lever cover
5D2 = Carrier frequency 315 MHz
4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
I don't see anything about Bose in there.
I found this while searching: "On the back there will be 4 sockets, one is a vertical 10 way, three are horizontal and stacked one on top of the other, the lowest of these is the 8 way power ISO, in the middle is the 8 way speaker ISO, at the top is the 20 way mini ISO connctor.
If you have a plug in the centre section of these three (only 4 central wires will be in use if you do) then you have the half amplified system, if that position is unoccupied, then you have the BOSE system."
I'll give that a look as well!
