Originally Posted by
RLB6
Plug and play. Even if you don't have provisions for heated seats in your car and the recaros are...still not an issue as there are separate harnesses for power, heat, & airbag.
Bump... but there is a twist...
First, hello to all, this is my first post. Just registered for this topic.
So I am also in a situation of installing B7 S4 Recaros from into my B6 1.8T. The twist is that my B6 is a US-spec, which I brought back with me when I moved back to France. So of course, the B7 S4 wreck which I bought the seats from here is a Euro-spec one, and I am running in a few issues.
Some I have solved, or is in process:
- door panel for memory seats (thanks to the DIY elsewhere on this site)
- hookup to CAN bus for said memory seats
- 30 amps fuse for passenger seat (just blew the 10 amps fuse today)
There are still two issues that bother me:
- My US B6 seats (leatherette, non-sport) had only 2 wires in the yellow airbag plug, while the Euro B7 recaros have 3 wires. The socket on the vehicle side does have 3 pins. Is it safe to plug straight up?
- The rear folding seat had a wire hooked-up to a yellow connector on the right C pillar. It seems that the US-spec A4s comes with a pretensioner on the middle belt as well, while Euro ones do not, and therefore the B7 Recaros do not have that wire. Should I swap the belt rollers & pretensioners between my original seats and the Recaros (btw, if anyone could point-me to a good teardown DIY, that would be great, I was not able to find one...), or should I try to recode the ECU to drop the middle pretensioner or (last resort), should I resistor patch the connector in the right C pillar?
Thanks for any help / confirmation,
Alex.
