Results 1 to 12 of 12
    Active Member Two Rings fromvwtoaudi's Avatar
    Oct 27 2011
    providence ri usa
    Anyone ever get an ESP malfunction light ?
    So yesterday driving around i kept getting a ESP error warning with the ESP light warning icon on the instrument cluster.. It also said to check owners manual. But sure enough today everything is fine..no warning no lights no error..
    Another bug in the system maybe?
    2009 B8 A4..premium plus/meteor grey pearl
    Junior Member Two Rings vandelizer's Avatar
    Sep 27 2009
    Silver Spring, MD
    Quote Originally Posted by fromvwtoaudi View Post
    did you disconnect the battery for any reason? I know when I've had to disconnect the battery I get the same thing. Usually lasts for the rest of the day or so. But sure enough the next day everything is fine. Just from my experience
    Oct 27 2011
    providence ri usa
    Thanks for the reply and nope have not disconnected the battery today! Funny u mention that I remember my gti having the issue once before too.. Hope this is just a one time deal
    Senior Member Three Rings ms3008's Avatar
    Mar 05 2010
    I had this issue once in my 2009 A4. The ESP light would come on sporadically and disappeared after a restart so it made it hard for me to show it to the dealer. But eventually I guess the fault became permanent and the light stayed on permanently and I was able show them the problem.
    Brought it in and they finally found the problem. It was due to an ABS sensor malfunction.
    SOLD - 2011 Brilliant Black TD1 A5, Light Grey Interior
    OEM Carbon Atlas Inlays • 30% ceramic tint • Facelift flat-bottom S5 steering wheel + Pedals • S5 grille + side mirrors • APS+ retrofit • S-line exterior upgrade • LED license plate lights • APR Stg I • Ecodes • Power folding mirrors • Advanced Key
    Apr 07 2007
    B6 A4 3.0 (Wife's Ride)
    Mountain View, CA
    Mine would go on occasionally couple months after purchase. Dealer couldn't find a fault. Went away after a while, never came back.
    Go figure, figured it must have been the sensor becoming acclimated.
    2009 3.2L Sedan BB/Beige. VMR V710 Gunmetal 19" Rims. Exterior Chrome Trim painted Quartz Grey. LED ROW tail lights. KW V1. H&R RSB. StopTech PosiQuiet Pads, Painted Calipers. HOEN Xenon Match Fog Lamps. Fog Grilles converted to S-Line look. Stone Guards. FCA Rear Diffuser. LED interior lights, cup holder lights & door pocket lights. RS4 Pedals. Remus Mufflers.
    Oct 27 2011
    providence ri usa
    Thanks guys!! It was raining pretty hard in the north east the last few days so maybe that played with the ABS that triggered the ESP failure..who knows still having a blast driving this thing!
    Jul 07 2009
    Lebanon
    Did any of you experience violent hesitation/stuttering when the ESP malfunction came on?
    I'm getting this horrible hesitation in all gears at any rpm above 2k, when I slightly press the gas pedal. Otherwise, car drives normal, but as soon as you give it a little gas, you're in for the ride of your life.
    ESP comes on, then disappears. Today, it came on and stayed solid. Turned the car off, then back on again and it disappeared. But sure enough, drive a couple of hundred meters and its back on again.
    Anybody have any input?
    SOLD: 2010 A5
    Active Member One Ring Daleynb's Avatar
    Nov 13 2011
    Toyota Prius on 24"Lexanis
    OC, CA, USA
    I have the same thing, I logged and it showed i was misfiring on cylinder 1 and 3. Took it to the dealer and they said the spark plugs and Coils needed to be replaced for 450. I of course said no bc I could do it myself for 140 thriugh ECS. After replacing I now have the issue when u run it hard and ut tyoucakky happens at 65-70 mph. Then logged and im stukk misfiring in clinder 3. So frustrating bc my car us stukk under warranty. Before this 2 weeks prior they replaced my turbo at 33000 miles. I haven;t even had the car a year and have brought ut un 5 times saying I am having loss of power issues. any input? Also before the turbo my car just died and when the tiw trucj came u trued to start it and it dumped out at least 10 gallons of gas in my garage.
    Active Member Two Rings xmaxnux's Avatar
    Feb 02 2015
    Audi A4 2.0T Quattro S-tronic
    Argentina
    Hello, I've messed up with a heavy rain yesterday and in a 1 meter flood....
    So in a small distance my 2.0T engine stops, the computer says ''ESP Sensor malfunction'' os something like that. I tried turn on the engine a couple of times but no ignition at all.
    Can anyone tell me what should i do?
    Thanks in advance
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Quote Originally Posted by xmaxnux View Post
    Thanks in advance
    Scan with VCDS, clear codes and see if they come back.
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Feb 02 2015
    Argentina
    Thanks, i'll work on that..!
    Jan 20 2016
    Massachusetts
    I have a ESP fault that comes on while driving or just while the car is running on my audi a6 2005 3.2l with 141k and i also get stuttering and hesitation, check engine light is also on. also a "P2296 Fuel Pressure regulator N276 Short to Plus code" Any ideas?
