Left button (Mode) will bring up contacts in the DIS display. The left wheel, will scroll through the contacts, and when pressed in will answer/hang up the phone.
The right button with the ((( will ask for voice commands, if you say "Dial Name", or "Dial Number" it will do exactly what it says. Dial Name will only dial names you have previously programmed, it does not use this to look in your phone book, you have to program yourself saying the name "Store Name", it will ask you to say the name twice, then the number one number at a time "Two" it will say the number "Two" then you say "one" it will repeat "one"... The problem I have here is, after the last number you have to say "store" to finalize it, I have gone back and forth yelling at the car because it will say "star" thinking I want to dial star, instead of store...
One might ask how useful dial number is... I have found this very useful, if I look up a number in the phones web browser, and the phone doesn't allow me to select it to dial (iphone). So instead of trying to remember the number, I can just read the number from the webpage. Some webpages put phone numbers as part of an image, instead of text so the phone can't select it to dial. (it is 2011, everyone uses smart phones, businesses need to realize this, and include contact info as text on the page).
You can say "help" after it says "Say a command.... (beep)" and it will say "possible commands are..."
I have recently learned, that when I talk loud (after owning the car for a little over a year), it does not recognize the name, so I just say the names now at a low volume, and it works 100% of the time. It also doesn't understand my curse words, after 5 cycles of it telling me the name can not be recognized and canceling... Sooooo glad I learned to talk quietly for it to work.
Once set up, the OE Bluetooth works exceptionally well. I am very impressed with it.
