Results 1 to 9 of 9
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    Which power steering fluid?
    So my power steering fluid is dry and there for makin noise, my fault. Which is the right power steering fluid? I did a search and found pentosin chf-11s. Where can i get this or anything else i can use?
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
    Nov 11 2011
    Boston
    Advance Auto Parts and Napa carry Pentosin CHF-11s. There is a good DIY writeup somewhere for flushing the fluid and cleaning the reservoir filter in B6 cars, but the process is nearly the same (don't have to remove the headlight on B5 cars). It's really easy and took me 20 mins.
    Sep 14 2008
    I think theres a napa around campus, and an advance auto parts as well. i will check this out. i dont really want to drive the car because there is literally nothing in my res. but foam, and thats really bad to drive with, even a little bit...
    i will try to remember to check back to this thread if i can find some at napa or advanced.
    - thanks.
    Feb 26 2010
    NOVA
    NAPA always has it, i never find it on the shelf anywhere else.
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    CLICK HERE for all of our power steering fluids.
    We carry OEM, Pentosin, and Fuchs.
    Deactivated Two Rings
    Aug 19 2011
    1998 Audi A4, Quattro, 2.8/30v, Tip; 2001.5 VW Passat GLS, 2.8/30v, 5spd, w/Unitronic
    Groton, CT
    This is the only type of fluid you'll want to put in our PS systems:
    • Hydraulic System Fluid (Power Steering Fluid) - Pentosin CHF11S 1 Liter
    Putting anything else in our PS systems, can lead to severe damage, which can be quite costly in the end.
    Nov 21 2006
    san francisco, ca
    I use Mobile1 ATF, cheaper and more readily available.
    1998.5 A4 2.0TQM ADR/058, Custom ME5 tune by 034, ABA 92.8 stroke forged crank, Scat rods, JE Pistons (83mm/8.5:1), Schrick cams, Supertech springs and retainers, inconel exhaust valves (+1mm), Spa T3 mani with a Precision 5557E-B, 034 3inch exhaust, etc, etc, etc. 034 featured user
    2012 S4 Prestige, Titanium, Monsoon gray metallic, DSG. 034 ECU and TCU tunes and other bits.
    Nov 08 2011
    excelsior
    redmond can you link to the cleaning tutorial?
    Veteran Member Four Rings TConklin821's Avatar
    Mar 17 2011
    Binghamton, New York
    I just get it at the dealer.
    2001 A4 1.8TQM. Custom catless turbo back, GTRS turbo, 440 green giants, FMIC, custom tune, ECS RA4 clutch + LWFW, short throw, ST coils, 235-40-18 tires
    ^RIP^
