My battery shit the bed last night so I did some digging on what's available for the B6/B7 S4 & RS4. Figured this would be useful, especially with winter nearly upon us. The short of it is that the cars need a group 49 battery, preferably in AGM (absorbed glass mat). They're about 60lbs.
All US batteries are made by one of three companies: East Penn Mfg (Deka), Exide, or Johnson Controls. These companies just privately label them for Pep Boys, NAPA, etc. What sucks is that not all batteries sold at Sears, for example, are made by Johnson. It can vary based on the "line" of battery or even the "group". Some companies are vague on specifications, so I apologize if this information is incomplete ** I did my best to call and get the latest data. Sometimes the supplier will change so the specs might vary in 6, 12, or 18 months from now.
I also included warranty information, which is listed as "full replacement/pro-rated replacement". 36 mo/96 mo, for example, means if it dies in the first 3 years, they give you a new battery. If it dies between 36 and 96 months, you get a partial credit on a new battery. Just remember that at the 95th month, you're looking at getting a few bucks "credit" if it dies so I wouldn't worry too much about this. There are a few special batteries in here which have unusual warranties.
When you read the specifications below, you'll see that not all batteries are created equal, even when produced by the same company!
Cold cranking amps, or CCA, are king here. This is a standardized measure for how much current the battery can supply at 0 F when cranked continuously for 30 seconds. Each cell must maintain 1.2v, which works out to 7.2v for a typical 12v battery. Since batteries lose a substantial amount of their power at low temps, we want maximum CCA. For those that live in warm climates, don't dismiss this figure completely. There is a marked difference in battery output between 50 F and 80 F, though obviously at 10 F it's far worse.
The other big figure is reserve capacity minutes, sometimes called reserve time. This is another standardized test for how long the battery can supply at least 25A and stay above 10.5V at 80 F. In real-world terms, it's a measure of how long the battery could continue providing juice if the alternator were to stop. More is better, though I tend to weight the CCA figure higher.
Braille Endurance B10049
Mfg: East Penn
1115cca
150+ min reserve
60 mo (pro-rated replacement only)
$298
Braille Endurance B7548
Mfg: East Penn
945cca
120+ min reserve
$248
NOTE: this is a group 48 battery. It is extremely powerful and matches/beats most group 49s. You'll save about 15 pounds but may need to built a custom bracket to secure it. If saving 15lbs is worth the extra $100, by all means go for this one. The warranties on this are of course much shorter due to its performance nature.
NAPA Legend 84 (8449)
Mfg: Exide
900cca
180 min reserve
24 mo/84 mo
56.5 lb
$134.00
Super Start Premium+ AGM
O'Reilly Auto Parts
Mfg: East Penn
900cca
180 min reserve
24 mo/72 mo
$169.99
Die Hard Gold
Sears
Mfg: Johnson Controls
900cca
150 min reserve
36 mo/100 mo
$134.99
Varta Start Stop Plus
~~~ OEM ~~~
850cca
??? reserve
$145 (varies by dealer)
East Penn Intimidator AGM 9A49
Batteries Plus
Mfg: East Penn
850cca
170 min reserve
$179.99
Carquest European Import
Mfg: East Penn
850cca
170 min reserve
$132.99
Duralast Platinum
Autozone
850cca
170 min reserve
36 mo/96 mo
$154.99
Bosch Premium Power
Pep Boys
Mfg: Exide
850cca
120 min reserve
36 mo/96 mo
$104.99
NAPA Legend 75 (9849)
Mfg: Exide
850cca
170 min reserve
18 mo/75 mo
58.5lb
$114.00
Interstate Megatron Plus 93
850cca
155 reserve
30 mo/85 mo
52lb
$136.95
Odyssey PC1350
Batteries Plus
Mfg: Odyssey
770cca
195 min reserve
48 mo (full replacement only)
$356
NOTE: Odyssey is considered a high-performance battery, despite offering mediocre CCA. Odyssey makes their own batteries and does not use recycled lead from old batteries like everyone else. They also have some unique manufacturing processes that make these a step up in terms of longevity and reliability. For those of you who care, they're made right here in the USA. Unfortunately they're so expensive it's typically cheaper to just buy two normal batteries. Sears sells these under their Die Hard Platinum line, actually...but not in group 48 or 49 sizes.
Autocraft Gold
Advance Auto Parts
Mfg: Johnson Controls?
900cca
150 min reserve
36 mo/84 mo
$155.99
Duralast Gold
Autozone
760cca
100 min reserve
36 mo/96 mo
$124.99
You may have noticed there is no Optima battery listed here. That's because Optima does not make a drop-in replacement (group 49), or even the slightly smaller version which is a group 48. The Yellow Top D27F or Blue Top D31M are similar in specification to a group 49, so theoretically they would work; you'd have to fabricate your own brackets, of course. As of late I am reading about a lot of quality control issues with Optimas compared to the ones of years ago. The warranty replacement process is a huge hassle too, from what I'm told. Given that the Optima specs are not really any better than anything else, I don't see any compelling reason to select them. All of their marketing about "deep cycle" is just another way of saying it's an AGM or gel-cell. If you're wondering, Optimas are made by Johnson Controls.
