Results 1 to 12 of 12
    Jul 21 2008
    Spark plug torque specs
    I remember when the car was at the dealer for a HPFP replacement, the techs had checked the spark plugs and noted they were loose. Had previously torqued them to 22ft-lbs per the B7 DIY.
    I do remember somebody mentioning 25ft-lbs for the B8 but can't seem to find the post.
    What are the correct torque specs for tightening the spark plugs?
    Sep 14 2006
    I'm wondering the same thing. I've always used 22ft-lbs on my B6 as well.
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Feb 10 2011
    L
    Would like to know as well. It seems that when my spark plugs were replaced at the 35k maintenance i had a rough start up and a rougher idle. Could it be the colder spark plugs (since they changed from bosch to ngk, it went from a seven to a six, colder plugs)?
    Aug 02 2009
    Hanko, Finland, EU
    Correct torque for "spark plugs in cylinder head" is 30 Nm, and 5 Nm for "guide for ignition coil wiring to cylinder head cover". Information taken from "Maintenance Audi A4 2008 ➤ Edition 12.2010", downloaded from www.erwin.audi.com.
    Jul 21 2008
    Wondering now if they come loose. Will probably be replacing them again soon and will try and check the torque specs again a few thousand down the road to see if they loosened up by themselves.
    Aug 02 2009
    Hanko, Finland, EU
    Don't try this if you feel it is risky. But, a mechanic at an Audi dealership changing my sparkplugs on my B8 2.0T engine once told me that once the plugs starts to face resistance as you screw them in, you should go another 1/4 of a rotation. Then your done.
    Jul 21 2008
    So, retorqued the spark plugs a few thousand miles later and they had indeed come loose. Tightened them to spec and a few more thousand miles later, they remained in spec. I can't remember the exact mileage I checked the torque specs each time but in all I double checked the torque specs twice within a space of 5k miles after initial replacement.
    Sep 06 2010
    Germany
    Is there a write up on the B8/A4 spark plug replacement someone could point me to?
    2011 A4 Avant S-line
    2016 TT Roadster
    Sep 14 2006
    Check a4mods.com The write-ups are all for the B6 platform, but he Martini has great instructions with pictures and the B8 won't be much different. I pretty much learned how to do all of my DIY and maintenance from him lol
    -Thomas
    Current: /S3
    Stage 3 Forum Advertiser Four Rings Info@EuroCode's Avatar
    Dec 24 2008
    Torrance
    erWin Torque Spec is 30nm or 22.13 lb/ft. This only applies to new plugs that have never been torqued. If the plugs are being removed and reinstalled, then we do about 26-28 lb/ft to keep them from leaking.
    EuroCode Tuning, Inc.
    1872 Del Amo Blvd Unit A
    Torrance, CA 90501
    310-294-8108
    Jul 21 2008
    Quote Originally Posted by Info@EuroCode View Post
    I torqued new plugs at 22lb/ft at around 35k and never touched them again for about 15k miles until the dealer stated the plugs were loose when diagnosing what ended up being a hpfp problem. The hpfp replacement together with an intake replacement and fuel mixture running rich codes led me to replace the plugs with new ones again at about 55k. Again I torqued the plugs to 22lb/ft. At or about 57k, i checked the plugs for tightness and found I could tighten the plugs about another quarter to half turn before the torque wrench clicked. A few days ago at almost 60k I checked the plugs again and found I didn't need to tighten any of them.
    Essentially, it seems that the new plug installation at 22lb/ft would loosen up after a few thousand miles (at least in my case)
    I did some basic torque wrench calibrations (hang a weight off the handle and multiple that weight by the length) and the wrench was fairly accurate.
    Thanks for the information on increased torque specs when reinstalling. Useful to know when checking the plugs next time.
    Apr 05 2011
    Pacific Northwest
    Does anyone have a good B8 DIY write up? I cannot find one (only for the B7). I'd really like to do these myself from time to time.
    Highlander's Build Thread
