my airbag light decided to come on recently, and produces the following code:
00588 - Airbag Igniter; Driver Side (N95)
002 - Lower Limit Exceeded - MIL ON
I've tried all the usual remedies, including clearing the code, disconnecting/reconnecting the battery, and reseating the harness both at the clockspring and the airbag itself. I also checked to make sure that there wasn't a short in the harness or the connectors anywhere, and reseated the 4-pin harness going into the clockspring.
If I disconnect the airbag and clear/recheck the fault codes, I get the same code with different sub code - now it's the upper limit that's exceeded. This makes sense, since the airbag control module is checking the resistance across the airbag circuit. With the airbag disconnected, there's infinite resistance, hence the upper limit exceeded.
The lower resistance limit means that there's a short somewhere, but where? I've ruled out the harness. I can't check the airbag itself since there's a very good chance of setting it off. I can check at the clockspring, and measured that there is continuity across the two pins for the airbag circuit (pins 3 and 4), but I don't know what that tells me.
Any ideas where to go from here?
The Ross-tech page for the code simply tells me it's either the clockspring, airbag harness, or airbag itself, but doesn't give any info on how to narrow it down to which component is to blame:
http://wiki.ross-tech.com/wiki/index.php/00588
FWIW, I have the TT s-line multifunction wheel and airbag, with retrofitted B7 clockspring and steering control module. I hadn't modified the airbag harness to connect the 2 ignitors but did today to see if it would make a difference (it didn't). It's been working fine for the past 2+ years, so I don't think it's a factor here but wanted to mention it anyway. I haven't tried putting my original wheel/airbag/etc back in since it's a fair amount of effort, and if it worked it would only tell me that one of the components I already know/suspect is the issue.
