Results 1 to 40 of 53
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    DIY: Carbon Canister Fix / Pumping Gas Problem
    If you are having trouble pumping gas then you might want to try this out.
    Possible Causes: clog carbon canister filter or leak detection pump (LDP)
    Tools needed:
    10mm and 13mm socket
    Flathead
    Pliers
    Step 1: remove the three 10mm nuts and drop the cover. After you remove the cover it should look like this.
    Step 2: Unplug the hoses by pushing the round plastic ring toward the carbon box and pulling the hose out. It’s a PITA because the hose is really in there and you also have to be careful on not breaking the hose.
    For the skinny hose I used a flat-head for leverage (shown below). That hose leads to the n80 valve and the larger one goes to the gas tank. You should unscrew the gas cap the try blowing into the large tube to see if air flow through it. If air doesn’t flow through that might be your problem.
    Step 3: use pliers to remove the clamps on the hoses
    Step 4: remove three 13mm bolts and drop the carbon canister
    Step 5: remove the carbon canister filter
    Step 6: Clean the filter
    option 1: Blow air into the filter it should go through fairly easily. If you feel like there resistance then it need to be clean. I cleaned my filter by filling it with water and blowing air through it. I also sprayed carburetor cleaner in it and let it soak in the filter for few mins.
    OR
    option 2: You can cut it open to clean it but you will have to seal it tight. If not an evap cel will come on.
    Step 7: Test to see if the LDP is clog by blowing into the single tube near the driver side. Air should be able to go through it fairly easily too.
    Step 8: Put everything back together and make sure all of the hoses are on tight. If not you will get an evap leak CEL.
    May 21 2007
    Florida
    nice little DIY. not sure ide cut mine open, but to each his own. good writeup regardless
    2018 Navarro Blue Q5
    Deactivated Three Rings
    Oct 07 2008
    Santo Domingo, Dom. Rep.
    Isn't the carbon canister filter sold seperately??
    Established Member Two Rings A4B7GA's Avatar
    Apr 20 2007
    A4 B7 5.5, 05 Exploder
    Bal Harbour, FL
    Thanks for this. I am taking my 5.5 back in again for the 3rd time for the filling issue. I am using their recomended stations and nothing seems to work. I finally got AOA involved as this time I am out of warranty.
    my mod list...really boring $!ht + APR
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    Thank you for the write-up
    I'll move this into the B7 A4 tech soon...
    B8.5 Audi SQ5 | APR Stage 1
    Feb 19 2007
    Louisiana
    Quote Originally Posted by mr_esmit View Post
    nope
    Established Member Two Rings Hazziar's Avatar
    Oct 03 2010
    01 A4 Black
    Northeast
    Awesome solution, thanks for figuring out a practical fix thats basically free to do! I did this DIY on my charcoal canister after I verified it was clogged [couldn't blow air through it]. It completely solved my fill up problems and the knocking noise from the tank that many people experience with this problem. The only things I did different was I cut right below the bonded top cover for a clean separation and removed the thin mesh screen from the cover as that is what was clogged.
    Jan 04 2010
    Jeep Wrangler, VW Atlas
    Southeastern, CT
    what is the pn for a whole new unit? it must be like a 350$ part right?
    Apr 16 2012
    Huntersville, NC
    How did you guys seal everything back together? Do you happen to have any pictures of how it looks after you sealed it? Thanks
    Feb 19 2007
    Louisiana
    i didnt cut mines open...just rinsed it with water
    Apr 16 2012
    Huntersville, NC
    Quote Originally Posted by plokm View Post
    Did this solve your problem? Did you do this with the filter only or the whole canister itself?
    Feb 19 2007
    Louisiana
    Quote Originally Posted by luisrsg View Post
    yes it did and just clean the filter...do not try to clean the canister. Water will damage the canister.
    Apr 16 2012
    Huntersville, NC
    ok thanks man! i'll try it this weekend
    Jan 04 2010
    Southeastern, CT
    i took a look at mine last night. i have a 2007 and it doesn't have the little canister on the side. it just has a curved hose that goes right to body mounted hose. what the do i do now? does the LDP filter do anything regarding filling up?
    Feb 19 2007
    Louisiana
    Quote Originally Posted by Giantsfan10 View Post
    you should have it
    May 14 2012
    Brooklyn
    I to need help had a code p0445 which I fix , new cap which was warn out and purge solenoid valve now I am getting code p0442 any ideas
    Veteran Member Four Rings papadelogan's Avatar
    Jul 31 2011
    1999 F250 7.3 Powerstroke
    Gulf Coast of Florida
    I wasn't getting any codes but was having the fuel cutoff issue when filling. I scored the entire canister assembly with only 15k miles for ~$60 off ebay. You might try looking for an ad of a car being parted out and contact them about the canister.
    2013 Phantom Black A5 P+ Cabriolet (2.0T quattro) mods4cars, mesh grill, gunmetal VMR 701, HFC "Boudica"
    2007 Ibis White B7 A4 Ti Avant 6MT quattro JHM Stage 2, HFC, Milltek CatBack, GFB DV+ "the YETI" sold
    2005.5 Black B7 A4 6MT quattro sold
    May 26 2012
    Cincinnati
    This is why I love the message boards, because this is a problem that so many of us have and when someone finally finds a good cheap fix it spreads like wildfire. You've saved so many people so much money. Thanks plokm!
    Jul 02 2007
    Lafayette
    it work's
    Aug 11 2012
    Dallas, TX
    From what I understand, the charcoal filter is the cause of the issue. I wonder if it's possible to bypass the filter and connect a long hose hose and be done with it? I tried purchasing the vapor canister but it didn't come with a filter and there's no way to purchase a filter separately. I'm reluctant to cut the original charcoal filter open because I fear I won't get it resealed and or I'll need to clean it regularly. Can anyone direct me the right way here?
    Feb 19 2007
    Louisiana
    You can bypass it but some people eventually have problem with the LDP..I didn't cut mines up...I just spray alot of carbon cleaner inside of it and I was good to go
    Aug 11 2012
    Dallas, TX
    That's what I'll try. Thanks for the reply!
    Aug 11 2012
    Dallas, TX
    Cleaning the small filter on the side didn't fix my issue so I'm completely replacing the vapor canister and following the Audi recommendation to bypass the small filter on the side with a hose, PN 8E0-201-946-H. If this doesn't do the trick it's on to the LDP.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I removed the entire thing all together. Why do you want to replace it? There is no cel.from removing it.
    2021 Audi S4, P34 Intake
    Aug 11 2012
    Dallas, TX
    Hmm, I've been reading a lot and was under the impression it would through codes and I believe someone mentioned it causes issues with the LDP. In any case, I replaced the canister, purchased a 5/8" heater hose and bypassed the charcoal filter on the side. So far so good, the engine seems more responsive, smoother and I can finally fill up quickly rather than waiting 20 minutes.
    My next project... motor mounts. The fun continues.
    Dec 03 2008
    2018 SQ5
    Yeah, I read there would be codes too, but I have none. Lol. Maybe things changed in the later models, but as for my 05.5, everything is good. It's so nice to be able to fill the tank with one click.
    Oct 11 2013
    Michigan
    I am finally fed up. I have had filling issues for years. Recently I ran out of gas on the highway even though my gauge showed I had gas. Often on long trips my needle doesn't seem to even move until I stop.
    In any case, I just followed the steps above. My one question I had, In Step 2, I blew into the large hose that leads to the tank. Air went in easily but it also blew back out at me. I had removed the gas cap. What should I expect with this test?
    EDITING: 11/5/2013
    After completing the above steps I have successfully filled up twice (11 gallons each time; two different stations) with no issues. The knocking sound I would experience after shutting the car off is also gone.
    Established Member Two Rings Whats4dinner's Avatar
    Feb 26 2012
    2009%20328I%20Coupe%2C%202017%20S550%2C%202017%20Audi%20A4%2C%202001%20BMW%20525i
    Bay Area
    Interesting and thank you for the write up. My problem is that I will go to the pump and my gas needle will never indicate that my tank is full, it will get close to filling up (according to needle reading), but maybe has a half-quarter tank left to fill...even though the gas machine itself has clicked.
    Love me some European cars. My year old lab Bodie is my avatar.
    Veteran Member Four Rings jaycurn's Avatar
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Going to give this a try and will probably just remove the charcoal canister and rteplace with either this part: 8E0-201-946-H
    as mentioned above or just a piece of bulk hose since the dealer wants $70 for this piece of rubber hose! Does anyone have specs as far as the diameter and length of the hose required??
    Oct 16 2008
    South Florida - Ft Lauderdale
    Quote Originally Posted by Whats4dinner View Post
    Your problem is most probability coming from the fuel sender
    http://www.audizine.com/forum/showth...ghlight=sender
    Phil
    Senior Member Two Rings 6speedman's Avatar
    Aug 29 2014
    Iowa
    Awesome DIY!! I'm going to be doing this this afternoon. I just fueled up this morning in 10* weather. What a pain to be trying to coax some gas in.;(
    Veteran Member Three Rings mcbuck's Avatar
    Mar 21 2010
    '19 Jeep Wrangler Unlimited Rubicon, '16 Grand Cherokee, '12 328 cab
    Charlotte-ish
    Did this last winter. Works as advertised! Now I just lock it on wide open and let it go - FTMFW!
    BUCK
    2011 A4 quattro, 2.0T, A/T, Deep Sea Blue Pearl (my son's car, but guess who gets to work on it?)
    GONE 2013 RS5 Daytona Grey Pearl, X-pipe, 20% tint, Arc Audio/Alpine, interior/backup LED, 034 RSB, H&R sport, V-FF 103, 285/30 DWS06, Girodisc, Hawk
    GONE - B7 A4 quattro, 2.0T, 6MT, 250K....dropped, tuned, and everything else
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Quote Originally Posted by mcbuck View Post
    Did you clean the charcoal filter, remove it or just take the whole charcoal canister and evap tank out as done in this DIY?
    http://www.audizine.com/forum/showth...Detection-pump
    I think rather than replace the charcoal filter alone with a hose, I might just take the whole assembly out!
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by jaycurn View Post
    Do it! My gas pump has not clicked off prematurely since. And no cels from removing it all either.
    Also, the hose is cheap, and i followed the instructions, but one hose wasnt the correct size. My recommendation is removing it all, and if you have a second vehicle, take the old parts with you to home depot and match the tubing that way. Just to avoid having to go to the store twice like i did.
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Perfect... thanks sir! Can anyone confirm hose sizes etc to avoid a mid job parts store mission?
    Established Member Two Rings SmoothCriminal's Avatar
    Nov 05 2014
    2015 Audi S4, 2004 VW R32T, 2018 Subaru Crosstrek
    Indianapolis/IN
    Incredibly useful, I have had P0455 since I got my car (which has only been a few weeks) but I'll definitely give this a try tonight. Thanks!
    Update: So I'm out here under the car and just had a thought. If you leave the gas cap on should you be able to blow into the large hose? Just trying to determine if that would tell you if your gas cap was bad.
    Senior Member Three Rings Jey4's Avatar
    Apr 02 2013
    West Haverstraw/NY
    Thanks for this DIY. I followed it a few weeks back and worked like a charm. I didnt cut open the filter just ran brake cleaner through it a few times and I've been able to fill up the tank twice without any hicups.
    -Jey
    Dec 03 2008
    2018 SQ5
    I removed that whole thing and it's been running like a charm ever since
    Mar 27 2006
    Lots of bikes!
    Portland, OR
    Same! Removed the whole canister and replaced with a couple T's and hoses. No issues since!
    Senior Member Two Rings djsp00kyk's Avatar
    Jul 25 2009
    B9 Sq5, B7 A4, 2.5l swapped NC miata, LS swapped Jeep TJ
    Mississippi
    I did the same thing years ago and have had no issues since.
