Originally Posted by
cpu77
Is there a DIY to replace valve seals with out removing head?
I don't know of any DIY for that job. The procedure requires the following steps.
1 Position crankshaft for #1 cylinder at TDC compression stroke, then turn cranshaft 180 degrees further in the normal rotation direction, CCW facing the engine from the front, to place piston at BDC, at the end of the power stroke.
2 Remove camshafts and cam followers. Set the cam followers aside in order so that they can easily be replaced into the original locations.
3 Using a spark plug hole adapter, and an air pressure regulator, pressurize the cylinder with compressed air, setting the regulator output pressure to ~100 psig.
4 With the air pressure holding the valves closed, use a valve spring compressor and remove the keepers and valve spring on 1 intake or exhaust valve.
5 Using long nose plyers, pull the valve stem seal off of the valve guide. Next, use the protector sleeve over the keeper grooves, and slide a new seal onto the valve stem and press/tap the seal onto the valve guide. Measure the distance from the valve stem tip, to the seal lip before removing one of the old seals so you know when the new seals are installed onto the valve guides all the way. Measure both intake and exhaust seal distances, as they may be different.
6 Replace valve spring and keepers,
7 Replace the other valve guide seals in the other intake and exhaust valves, one at a time.
8 After replacing all the valve guide seals in cylinder #1, replace the valve guide seals in cylinder #4, then after #4 cylinder is done, rotate the crankshaft 180 degrees and replace the valve guide seals for cylinders #2 and #3.
9 After replacing all the valve guide seals in all four cylinders, re install the bucket cam followers, then re install the camshafts.
