    Veteran Member Three Rings PovGRide742's Avatar
    May 07 2009
    2001.5 Audi S4, 2010 Audi A6
    Womelsdorf, PA
    Small favor: OEM exhaust sleeve clamp bolt size?
    Does anyone know, or could look to see, what the OEM exhaust sleeve clamp bolt size is? The threads on my original bolts turned into dust as I screwed the nuts on. If I remember correctly, I used an 18mm socket to get them off. I need the M size of the carriage bolt, length (if possible), and if someone could confirm the nut size. I threw mine away... not thinking, so this would be greatly appreciated.
    Brett
    2001.5 Pearl White Audi S4
    034 Carrier / DPs / Exhaust / Inlet Hoses / MAF Hose / Y-Pipe / X-34 | AAM DS | Apikol Diff/Snub Mounts | APR Bipipe | AWE Gauge / DTS / SMICs | B&M Oil Cooler | CM Clutch / Flywheel | DW FP | Enkei RPF1s | EPL Fueling / Tune | FT F21-BTs / Inlets | H&R Premiums | Hotchkis Sway Bars | INA FSI | JHM BBKs / Knob / Trio | SAMCO Hoses | STE PPD | Stern Motor/Trans Mounts | Zeitronix ZT3
    May 16 2008
    WA
    The nut on the other side is 17mm (not 18mm), the length of the shaft (not including the carriage bolt head, but including the square section that keeps it from turning in the clamp) is about 2"
    Aug 25 2010
    1998 Audi A4 Avant
    Iowa
    Bolt is a m10x1.5x55. The factory nuts are 17mm, but any m10 nut with a 1.5 thread pitch will work.
    May 07 2009
    Womelsdorf, PA
    Quote Originally Posted by getslideways View Post
    I thought I hammered a 17mm socket on the nut back when I took it off, but couldn't get one to fit when putting them back on. Thank you sir.
    Quote Originally Posted by Tyler Adamson View Post
    Exactly what I needed... muchos gracias!
    Senior Member Two Rings tambat's Avatar
    Sep 04 2007
    Chicago, IL
    i have two brand new oem exhaust sleeve clamps i could send you really cheap if you were interested. i have no use for them.
    B5 S4 K04'd + (sold)
    can't seem to leave
