Results 1 to 28 of 28
    Registered User Four Rings PAT@RSW's Avatar
    Jul 02 2008
    BMW M4, SQ5, SL65 AMG
    Green Brook, NJ
    Redline Speed Worx Presents: ANZE Suspension System
    We are proud to now offer ANZE's full line of 100% Custom built suspension systems, which are fully rebuildable and serviceable !
    ANZE Engineering designs the components that are needed to fit or adapt the Penske Racing Shock to your shock application; they are shock fitment specialist. ANZE Engineering is the only company in the United States authorized to do this type of fitment with Penske Racing Shocks. They proudly meet or exceed Penske Racing Shocks high level of quality.
    The suspension systems offer the customer the ability of COMPLETE customization of the shock assemblies:
    - Getting the balance of you car right can be achieved by changing springs, ANZE offers a full line of interchangeable springs / spring rates to fit your application.
    - Load Centering Spring Perch, eliminate the shaft binding lateral forces that coil springs cause. Reduces shaft friction and bending which increses grip.
    - Spring Thrust Bearings, make setting ride height easier. Reduces steering binding forces in strut appliactions (a must have for most strut appliactions). Come in two 2 sizes and styles. 2.25" ID and 2.5" ID, also available in unsealed and soon to be out sealed unit.
    - Remote Resevoir "Canister" Brackets, come in two styles. The "Flat" style is made to mount the canister to body panels. The "V" style is made to mount the canister to roll cages and round tubes. A kit includes velcro straps and canister cover in full length or split.
    - Racing Chassis Mounts, the clevis adapter was made to take "shaft mount shock" application and convert it to a standard "Racing" eylet shock absorber.
    Furthermore whether your looking for hoses with swivel ends, need true "dry break" connectors or fire sleeving ANZE has a solution.
    ANZE Full Front and Rear Remote Resevoir System Installed on a B5 S4
    Anze_setup_sus by Redline Speed Worx, on Flickr
    anze_closeup by Redline Speed Worx, on Flickr
    anze_02 by Redline Speed Worx, on Flickr
    anze_01 by Redline Speed Worx, on Flickr
    anze_03 by Redline Speed Worx, on Flickr
    anze_04 by Redline Speed Worx, on Flickr
    anze_05 by Redline Speed Worx, on Flickr
    Pricing is 100% dependent on the build / application, but for reference pricing starts at $4,300.00 and the ANZE System pictured is approximately $5,700.00
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    If I wasn't poor.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Veteran Member Four Rings DESPOT D S4's Avatar
    May 09 2010
    8S TTRS
    TriState
    Why are the rears upsidedown?
    @iruinaudis
    B5 S4 daily
    8S TTRS fun car
    Nov 07 2010
    LINY
    Quote Originally Posted by DESPOT D S4 View Post
    There not, Look where the spring needs to sit to run true coilover in the rear at that location. Its an inverted shock. Dampening is still on the shafts down stroke whether it sits like that or not.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I think they run them like that to keep the unsprung weight down.
    Should have done the same in the front to get the reservoir line out of the danger zone and keep it from having to move up and down so much.
    Might swap the springs. The helpers are usually on the shock body so the end of the shock body doesnt have to cross the split in full droop.
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    saw these in JR's car this past Sunday at Cars & Croissants.
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Jan 09 2009
    FL
    So would these be comparable to the ohlins motorsports coilovers (with the res.)?
    Registered User Two Rings
    Oct 15 2009
    Washington, NJ
    Quote Originally Posted by Hyphy View Post
    Yes you can compare the Double front single rear set to ohlins. But with Ohlins you don't have a choice on how you want the shocks valved. or what sprigs rates. There are many options that you can add on to this suspension!
    Sep 06 2007
    These are actually 3 way adjustable at all 4 corners. The ohlins are 2 way in the front and 1 way in the rear.
    The anze package shown here is much more adjustable!
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    Dammit I want a set of these sooooo bad, three way adjustable with the ext. reservoir, its about damn time.
    Jan 09 2009
    FL
    Hmm...I might just do this and never look back. Can you possibly pm me a AZ price?
    Regards,
    Nick
    Edit: I think I'll just call tomorrow to pick someone's brain about customizing a set for the avant.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    The pricing is very similar to the pricing structure of KW Motorsport Coilovers at Wholesale cost. Great buy for guys out there that arent wholesalers.
    Veteran Member Four Rings VR6Bomber's Avatar
    May 13 2009
    XXXX
    Wow.
    Mar 07 2010
    RS4 B5, RS6 V10,RS3 8Y
    CA
    Wow product or price
    Quote Originally Posted by VR6Bomber View Post
    Wow.
    Misano Red RS4 2001 Transforming Phase
    May 13 2011
    2015 BMW F30
    Very nice!
    | Autospeed | JHM | Pure MS
    Jul 02 2008
    Green Brook, NJ
    We have another set of these in stock !
    Jun 14 2007
    2000 S4
    Connecticut
    Looks like a must-have for Santorin owners like myself with the coil matched color going on...
    Direct trade with H&Rs? lol.
    May 13 2009
    XXXX
    Quote Originally Posted by Bond View Post
    Wow Product.
    I've seen the units in person, nothing less than superb quality.
    A true motorsport level suspension.
    Another +1 to RSW
    Jul 02 2008
    Green Brook, NJ
    Thanks for the kind words James !
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Quote Originally Posted by DiscoPotato View Post
    If I wasn't poor.
    Exactly. And the whole reason I'm poor is because I own this car.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Sep 17 2005
    Fremont, California
    Barely more then Ohlins! Nice stuff guys.
    Question; whats the rebuild timelime on these guys? My Ohlins are supposed to be rebuilt every 10,000 miles, which is ridiculous to me. These have longer service intervals?
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    so what's the price point on these bad boys
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Jun 14 2007
    2000 S4
    Connecticut
    Quote Originally Posted by Max@034 View Post
    Wow that sucks...
    Forum Moderator Four Rings
    Apr 16 2005
    Pearl City, Hawaii
    I guess this would be overkill on a street car?
    B5S4/A3S3RS3/Hawaii Forum Moderator - PM Comments/Concerns
    18 Daytona Gray Pearl S3
    00 Laser Red S4 (Sold )
    VAST Performance | BLOUCH | AWE | EvolutionRacewerks | Volk Racing | Vogtland | STaSIS/Alcon | JHM Motorsports | RS4 OEM
    Veteran Member Four Rings sherbet's Avatar
    Jun 26 2010
    '63 Thunderbird
    Walnut Creek, CA
    I personally know people that ran the Ohlins on B7 S4's and went way over 10K before a rebuild. Recently, someone that went ~70,000 HARD miles on them had them rebuilt due to a small leak, but other than that, apparently they took the abuse very very well.
    B5S4 Sedan/ Stg lll/6MT/ Trouble
    B5S4 Avant/ Stg ll/6MT/Daily
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by sherbet View Post
    Yes, I said that they are "supposed" to be rebuilt every 10k. I have over 50,000 miles on mine right now, but they definitely need a rebuild.
    I'd love to get em rebuilt, sell em, and pick up some of these ANZE!
    Veteran Member Four Rings MikeyB3's Avatar
    May 16 2008
    ... Wow. The hotness.
    Senior Member Two Rings BlingOnMyWrist's Avatar
    Sep 27 2010
    Another 2001.5 S4 Avant
    Naples, FL
    Ou lala!
    They cost more than I bought my car for! (Not saying they're not worth that much, haha)
    Glad to see you guys have new stuff for the platform. And good stuff too.
    -AJ
    Pearl White B5 S4 6sp Avant w/ RS6s • Black B7 S4 Avant JHM Stage 2
    Quartz B7 A4 Avant w/ 3P 2.7T 0A3 Swap Project • Silver B5 S4 Avant 01E Swap & RS4 WB Project
    Meteor Grey B8 A4 Avant Facelift 3.0T Swap Project • V10 Touareg Stage 2
    PAST: Laser Red B5 S4 6sp | Stage 2
    photos: flickr
