So, I just recieved my VAG-Com tool today. Love it, but I don't know what the hell I'm doing. lol
Ran my first scan. I can sorta make sense of it. Been doing some reading, but I'm throwing a few codes. Don't know if they're old codes. I just picked up the car about 2 months ago, so I suppose they could've been lingering. Should I just clear them and see if they come back?
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Mileage: 139750km/86836miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AK HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0004
Coding: 0016711
Shop #: WSC 63351 000 00000
VCID: 79F7EE2D4942
7 Faults Found:
17834 - EVAP Purge Valve (N80): Open Circuit
P1426 - 004 - No Signal/Communication - Intermittent
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 004 - No Signal/Communication - Intermittent
17841 - Secondary Air Pump Relay (J299): Open Circuit
P1433 - 004 - No Signal/Communication - Intermittent
17829 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 002 - Lower Limit Exceeded - Intermittent
17697 - Boost Pressure Control Valve (N249): Short to Ground
P1289 - 002 - Lower Limit Exceeded - Intermittent
17881 - EVAP Leak Detection Pump: Open Circuit
P1473 - 004 - No Signal/Communication - Intermittent
17522 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 A
Component: ABS/ESP allrad 5529
Coding: 04275
Shop #: WSC 42389
VCID: 264DF551E87C
No fault code found.
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 AD
Component: A4 Klimaautomat 1323
Coding: 00000
Shop #: WSC 63351
VCID: 63CBAC45DBCE
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 F
Component: int. Lastmodul USA 0517
Coding: 01013
Shop #: WSC 63351
VCID: 356F221D25DA
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No: 8E0 035 593 E
Component: SDAR XM 0080
VCID: 2B5B0465F39E
1 Fault Found:
02635 - Tuner Not Enabled/Activated
35-10 - - - Intermittent
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 K
Component: Airbag 8.4EP 1001
Coding: 0010607
VCID: 3F83403517E6
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0611
Coding: 01041
Shop #: WSC 63351
VCID: 3E7D3D3110EC
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 P
Component: KOMBI+WEGFAHRS. RB4 D42
Coding: 01201
Shop #: WSC 23190
VCID: 366D251138DC
WAULC68E64A216858 AUZ6Z0C0452848
2 Faults Found:
01303 - Telephone Transceiver (R36)
49-00 - No Communications
01300 - Control Module for Navigation with CD-Rom (J401)
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1512
Coding: 11848
Shop #: WSC 63351
VCID: 72E5D9011434
Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0004
Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0004
Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0004
Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0004
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
00532 - Supply Voltage B+
37-10 - Faulty - Intermittent
Address 55: Xenon Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00060
Shop #: WSC 63351
VCID: 04098FD93E80
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II NP2 0470
Coding: 00201
Shop #: WSC 00003
VCID: 2C590779F690
1 Fault Found:
00858 - Connection; Radio ZF Output to Antenna Amplifier
29-00 - Short to Ground
End ************************************************** ******************-
