Results 1 to 39 of 39
Thread: NGK BKR6E
    Registered Member Four Rings BoSNiaN's Avatar
    Jun 02 2011
    2012 Benz ML350, 2007 BMW 325xi, 2006 Audi A4 2.0T
    Exclamation NGK BKR6E
    Anyone running them? I was told they are better than the iridums because they run a step colder but now I realize that only matters of you are running a tune which I am not?
    Anyway, I ask because there is some hesitation when I start the thing cold now...It had the stock Bosch's in there, gapped @ 0.025" and I was told to gap these @ 0.030" which they were already from the factory so I just dropped them in....
    It's weird because it only happens 50% of the time, but it never did before (have to use the starter longer and it "builds" to start, takes 1-2 seconds still but). It does feel like it starts stronger as well, but the cold start idle has dropped from 1200rpm to 800rpm now.
    Is there something wrong or is that normal behavior for coppers?
    2006 A4 2.0T 6 SPD MT // Dolphin Grey on Black // Sport + Premium Package // Quattro
    ==> Complete Mod List <==
    Jun 02 2011
    Stock plugs pulled out @ 111,000KM, think they are the originals?
    Veteran Member Four Rings yungcotter's Avatar
    Jun 09 2010
    Queens
    Well I have the iridium version and those and noticed extended cranking times since its gotten colder( into the 30's F). What is the temperature there now. if i remember in the spark plug diy by stokes if you live in a cooler climate stay at the stock heat range.
    -Theo
    2018 S4,Florett Silver, Magma
    2014 Q5, Phantom Black Pearl, Chestnut, 2.0T,Moms Ride
    2015 S4, Daytona Gray, DSG,Gone
    06 A4 2.0 T, Quartz Gray, Quattro, Tiptronic.
    Jun 09 2010
    Queens
    -Theo
    Established Member Two Rings B7PhiGam's Avatar
    May 06 2009
    1940%20Ford%20Pickup%2C%201965%20Ford%20Pickup%2C%202012%20Chevy%20Silveradro%20LTZ%20Crew%20Cab
    Oregon
    I am running them as of 55k tune up. Stage 1 APR tune. When its really cold, there is still a hesitation, but the car drives great. Noticeable difference? I dont think so.
    2006 Audi A4 Quattro 6MT - Deep Sea Blue
    ST Coilovers / RS4 Sway Bar / Forged DV / Hawk Pads /APR Stage I 91,93,100 Octane / 35% Tint / Custom Calipers
    "So wird Dich meine Liebe auf ewig umschließen"
    Jun 02 2011
    Quote Originally Posted by B7PhiGam View Post
    Where you running stock Bosch ones before? Did you not notice hesitation difference? I was hoping this would minimize starting issues in the winter and it does seem to start stronger, but at the same time it is hesitating so I am not sure what will happen when temps drop to 0 and below
    May 06 2009
    Oregon
    Cold is still cold, plug dont warm up cylinder walls/rings/all the good stuff any quicker. I have noticed it kicks faster without giving it any fuel. They were like 4-6 bucks at my local NAPA so not really an issue not to get them.
    Jan 06 2011
    07 CBR600RR, 2013 A4 S-line Tip Quattro, 2005.5 A4 6mt Quattro, 2013 Scion FR-S, 2013 Nissan 370z
    Edmonton, AB , Canada
    arent bkr6e's still in the stock heat range?? the bkr7e's are the ones a step colder.
    2005.5 A4 Quartz Grey 6MT Quattro
    APR stage 2 91 or 93, Eurocode test pipe, Stasis Cat-Back, APR snub mount, K&N filter, 034 Turbo inlet hose, Vogtland race springs, S-Line sport suspension, LED DRL and city lights, 18" M-Klasse wheels with Falken Ziex 912s 235/40/18
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    B8.5 Audi SQ5 | APR Stage 1
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    ^^^ This
    Jun 02 2011
    Quote Originally Posted by kristokes View Post
    Slightly contradictory with the plug thread I read....
    @NGK PFR6Q (OEM Platinum), are you sure these are OEM? I pulled Bosch's out and I think those are from the factory (even labeled with "VW")
    Jul 19 2011
    Northern Minneapolis, MN
    I am just about to buy plugs and all I have is a tune, so....
    lets get to the bottom of this before I go spend money!
    Veteran Member Four Rings Mister W's Avatar
    Jan 29 2011
    2017 Mitsubishi Outlander GT
    Otterburn Park, QC
    I remember that on the GIAC site, they said to keep original temp range even chipped. They said also that the tune was made for original gap and temp range.
    Like others, i changed them for BKR7E on my Jetta and A4. Now i'm thinking of putting back stock ones, i feel like the car is not idling to his best, without having misfires, it doesn't purr and vibe right in my bottom.
    Owning an Audi is like having a hot girlfriend that's mentally unstable
    2013 Allroad sport pkg, 19" gold Radi8 r8s5, B8 Sline suspension, AEM air filter, more to come...
    Jul 19 2011
    good to know. Maybe I'll keep it stock then. Been waiting on an answer from Vast but that was over a month ago when I asked
    Veteran Member Four Rings Sprode's Avatar
    Aug 27 2009
    07 S-Line, 97 Supra Turbo
    Arlington, VA
    Unless you're having problems, keep your plugs where they are.
    Veteran Member Three Rings ringmaster2.0's Avatar
    Nov 05 2006
    phila
    Quote Originally Posted by Sprode View Post
    Agree with this
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I stepped up to the bkr7e and really like them. It's below freezing today, and no difference in start up. It definately runs smoother, and it did feel like an upgrade.
    I think I gapped at 28. Maybe 30 was too big a gap?
    JR
    2021 Audi S4, P34 Intake
    Senior Member Three Rings A4-Wookie's Avatar
    Mar 27 2011
    2015 Audi Q7
    209, Ca
    Read the spark plug sticky in the tech section..
    "Well it depends on what you mean by stock but coming straight from the factory, our OEM spark plugs are actually UNDER-GAPPED at 0.027". Since OEM spark plugs were made for longevity (~50k+ miles), they were set at a lower gap because the gap will eventually get bigger through time and wear on the electrodes.
    IMHO from personal experience, I believe a 0.032" gap is optimal for our cars." - Kristokes
    2015 Audi Q7
    2013 Audi A6
    2006 Audi A4 Quattro - Stolen and totaled 7/9/2012
    Aug 27 2009
    Arlington, VA
    JR
    Pulling down the gap can definitely help rough idle or small misfires. May not have to do with the heat range.
    Veteran Member Four Rings p1nk50ck's Avatar
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Quote Originally Posted by CorneliusRox View Post
    i picked up the NGK copper's from Amazon for $1.99 each, but they're not running that sale anymore :( i should have bought more when i had the chance. they're still less than 4 bucks each on amazon.
    i'm still trying to find a time/place where i can get some work done to the car. actually, i guess i could just do the plugs when i get home in my parking garage.
    Veteran Member Three Rings grassrootz's Avatar
    Apr 01 2010
    Tampa, FL
    Quote Originally Posted by A4-Wookie View Post
    ^^this. .032" gap fires perfectly. I ran these on my car for exactly 1 month before I forgot to remind the dealer not to pull the plugs. And they miraculously lost 4 brand spanking new plugs in 1 hr. Car never ran smoother. .028" gapping will eventually run out to around .032". Stokes' gap is correct as the plugs will gap out further as they age.
    -GrassRootz
    Aug 27 2009
    Arlington, VA
    Quote Originally Posted by p1nk50ck View Post
    Plugs are super easy, and there are only 4. just make sure you chekc the gap before they go in.
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    yeah, the ones i got are gapped at .028, i was going to do .032
    i just have a few other things i wanted to do (wastegate adjustment, oil change, and a few other small things, so i wanted a better place to do all of it at once)
    Senior Member Three Rings GAIC Husky's Avatar
    Nov 24 2009
    NW Chicago
    I installed NGK BKR7EIX (step colder) with a gap of 0.032 about a month ago (roughly 800 miles) and the car has been running great. No problems with start up even as it has gotten colder out and it will idle like it did with stock plugs.
    Revo Stage II - 034 HFC - 034 IH - 034 SD mounts - AWE FMIC - B&B Exhaust - Q5 BBK - RS4 RSB - GFB DV+ - 42DD Catch Can - 35% tint - Podi Boost Gauage
    Jul 19 2011
    Quote Originally Posted by GAIC Husky View Post
    any performance change?
    Jun 02 2011
    Sorry, but based on how its starting @ 0.030" gap, I couldn't imagine running it at 0.032"....I should have run then @ 0.025 but I am too lazy to pull them out again now
    Could it be related to the fact that I am stock? Although I still don't get how even having a big turbo would would allow you to run bigger gaps comfortably because you would most likely still be using stock ignition components like I do...
    Apr 01 2010
    Tampa, FL
    I did that gapping. You feel it when the car is under load. ie. flooring in 6th. Its a bit quicker to bring on power versus that slow build up.
    -GrassRootz
    Jul 19 2011
    Quote Originally Posted by grassrootz View Post
    you're just talking about gapping it to .032 or switching to the plugs a step colder?
    Nov 24 2009
    NW Chicago
    I did have a slight performance change but I would expect that anytime you change out old plugs. I never had any problems with my old plugs but I just changed them because I hit 30k miles. To say it is better performance than if I replaced them with stock plugs, I don't know. The car does run great and the pull at the top end does feel much smoother. I got all 4 plugs for $30 shipped so it was definitely worth the money and peace of mind.
    Aug 27 2009
    Arlington, VA
    Quote Originally Posted by BoSNiaN View Post
    Bigger turbo=smaller gaps.
    Jun 02 2011
    Huh? Don't you mean the opposite?
    Aug 27 2009
    Arlington, VA
    No. http://www.ngksparkplugs.com/techinf...on.asp#gapping
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Just a note, i made a mistake with my post earlier. i got the NGK BKR7E copper, which are 1 step colder, not the BKR6E copper which are for OEM.
    just wanted to point that out for some readers who might have gotten confused like i did.
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    Installed the BKR7E (NGK Copper 1 step colder) yesterday. Not a noticeable difference in power (not that i was really expecting any), but the car no longer hesitates when starting in cold weather (it used to crank for a few seconds before starting). It's also perhaps a tad smoother when idling.
    Overall, not sure if i want to stick with copper, or go with iridium. perhaps, I'll switch to iridium after my next oil change, and see if i notice any difference.
    Dec 03 2008
    2018 SQ5
    I also switched to the copper bkr7e and immediately noticed an improvement. Definately sticking with them. Have you messed with the mbc yet?
    JR
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    JR
    i still haven't gotten the one from my friend. i think i might just order one online, because i'm getting sick of waiting. they're only 30 bucks
    Jun 02 2011
    Are you chipped? I will be going back to iridiums next oil change just because I don't want to keep switching them out every 5,000...Although I got them for $17 shipped, stock Bosch's are $16 each at the dealer
    Gonna have to find some NGKs that last as long as the Bosch's...
    @rough starts, it seems to have cleared up...is it possible that after freshly changed plugs, you will start up rough for a day or 2? Now my starts are as clean as ever and more powerful
    Sep 18 2008
    06 Audi A4 S-Line
    Arlington, VA
    yup, i'm APR Stage II+ on the 93 octane tune. i mean, who knows, my car's been peppier, but it's also been a lot colder
