Results 1 to 40 of 76
    Jun 07 2011
    gti
    high point nc
    AMS OIL VS. Royal Purple VS. Mobil 1
    what are your thoughts on the engine oils above. Has anybody experimented with AMS oil or royal purple.Have any of you seen any performance gain? Because most the the audi guys down here say Mobil 1 is the way, but i beg to differ. What are your thoughts?
    STILL BOOSTN Ko3s!!!
    Established Member Two Rings 2BehindJordan's Avatar
    Jul 03 2010
    01' A6 2.7QT
    Jersey City, NJ
    Mobil 1
    That is all.
    Sep 12 2008
    South Central PA
    Shell Rotella T6
    /end thread.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings MDJ's Avatar
    Jun 29 2010
    TIAL S4 ** '74 Superbeetle ** '60 MGA
    ^ That
    Veteran Member Four Rings KMPRSSD's Avatar
    Dec 19 2010
    E10 2002tii, 2010 VW Touareg Lux Limited
    Connecticut
    I use Royal Purple 0w-30. Been running it for a while, performace gains are going to be slight if any, no matter what oil you use. Any high end synthetic, will have great lasting effects on your engine. It comes down to whatever you prefer. Royal Purple is about $12 a quart if that helps any
    Senior Member Three Rings lawdogg's Avatar
    Aug 23 2009
    2005 BMW M3, 1994 Stealth TT, 1992 Stealth TT
    San Francisco, CA
    Whether the oils are still true Grp.IV synth's or hydrocracked Grp.III's, so long as you run UOAs and make sure the lubricant is holding up in your engine, it should fine.
    But, if you want to pay less for great lubrication with higher shear limits, HDEOs like Rotella, I think, are undeniably the way to go.
    1994 3000GT VR-4: 11.8 @ 116; 2008 NEPA SOLOII 2nd Place; Modified Mag ... RIP.
    DD: 2004 V70R; Weekend: 2005 BMW M3; Pieces of shit: 1994 & 1992 Dodge Stealth TT
    Veteran Member Three Rings Trile's Avatar
    Jan 26 2010
    Podgorica - Montenegro
    Motul :)
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    RP has been proven to break down very fast in our engines, there are some blackstone reports floating around here to support that I think. Might be good for some applications, just not the 2.7t or 1.8t.
    I dont have any information regarding AMSOil, but I have not heard any bad things and some people run it with good results I believe.
    Motul, TotalQuartz, Pentosin, Lubro Moly, Elf, etc. are all going to be great choices since they are all formulated to be compatible with our engines albeit more expensive and most of them have to be ordered unless your local parts store stocks it.
    Myself, I run Rotella T6 5w-40w. I dont really know why someone would want to run anything lower weight than that even in the winter but I have heard and read of people running 0w-30w of certain oils not sure why though.
    I like the Shell because its easily obtainable, reasonably priced, and doesnt piss out of every seal is getting old on my engine when cold. Mobil 1 did this and I was putting a qt in every 1k miles, switched to shell and I dont have to put but 1qt/10k miles. The Rotella also quieted the valvetrain noise that was present when I bought my car (car came with M1).
    The Shell seems like a good product, WalMart usually has it for ~$20/gal and parts stores will be about ~$7 higher-at least out here on the west coast. I am running the Rotella in my S and my mom-in-laws Allroad and my wife's A4. No problems.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    Its all about the Rotella T6!
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Veteran Member Four Rings bw86's Avatar
    Dec 06 2008
    2.0L 058
    LI
    I've been using German Castrol 0w-30 - might give Rotella T6 a try though
    2008cc - 6262 - Lugtronic - ID1700Xs - IECVA1s - 605@27psi
    --> first start <--
    Senior Member Two Rings murphy_boy_2's Avatar
    Mar 03 2007
    1969 VW Karmann Ghia
    East Lansing, MI
    Mobil 1 is a very good synthetic oil. Amsoil actually gets their oil from Mobil 1, so in reality it is actually the same as Mobil 1. The only thing different with Amsoil is the additives they put in to help it last longer and clean the engine.
    Oct 03 2011
    Georgia
    I think its pretty safe to use the manufacturers recommended brand/weight. The engine was designed using that oil and you can never go wrong using with that. Now what is audi's recommended oil for your car? Id look in your owners manual or ask the dealer.
    Established Member Two Rings PGJ's Avatar
    Jul 25 2010
    B5 S4 Avant, 1972 Volvo 1800E
    RI
    there is no Audi approved Amsoil oil, and thats why I wont use it.
    Mobil 1 meets all specs and is most easily accessible. Why get all creative with oil selection when Audi tells you what to use?
    http://microsites.audiusa.com/ngw/09..._1997-2012.pdf
    Veteran Member Four Rings Fourplay's Avatar
    May 01 2010
    Atlanta
    Quote Originally Posted by PGJ View Post
    Because Mobil 1 shears to a 30 weight in like 1k miles? If you like running a thinner oil, go for it. I use 5w40 and I want it to stay at that viscosity for more than a month's worth of driving.
    Veteran Member Three Rings ThePeoplesChamp's Avatar
    Apr 28 2009
    New Brunswick, NJ
    I use Rotella. If I have a little extra cash then I use lubro-moly.
    2001 Audi S4
    2004 IS300
    1997 Chevy Corvette
    May 16 2011
    AmsOil and that's all.
    Sep 22 2011
    Western MA
    Quote Originally Posted by murphy_boy_2 View Post
    Nonsense. Amsoil has been making synthetic oil long before there was a Mobil 1. Who were they buying it from then genius?
    Veteran Member Four Rings Rdp616's Avatar
    Mar 23 2009
    Hibiscus S4
    SW, Pennsylvania
    I've used all the oils listed above. Imo i like Amsoil the best. I use the european formula. And the engine itself is definitely quieter. I also run it in my bikes, and quads. My dad even uses it in his Harley. But, At the end of the day tho. All the Major oil brands are good in their own respect.
    Single Turbo Hibiscus coming soon
    Veteran Member Four Rings KNaudi's Avatar
    Jan 11 2009
    B5 S4, C6 S6
    Chicago and IN
    Rotella > M1. no question
    My WTB List:
    -Sport (all black) shift surround for 6MT
    -Sport (all black) ash tray cover
    KNaudi's story
    Senior Member Three Rings BenjaminR's Avatar
    Apr 07 2009
    Allroad, CJ5, Camaro, & lots of bicycles
    I will stand by AmsOil
    I run it in my 1.8 and I change the oil every 12,000 miles (recommended change @ 15,00 for turbo applications)
    I have had 0 problems and have actually noticed my engine is burning less oil since I have started running it once I bought the car.
    End of the day I think any of the high end oils are pretty close. Just depends on who you fall for.
    I drink a lot of beer
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by BenjaminR View Post
    Sludge heaven
    - Clint
    Veteran Member Four Rings bigdo26's Avatar
    Jul 21 2009
    Been running Mobil 1 10w40 for about a year, and have had great luck. 0w40 would leak a little out my valve cover seals with a cold/cool engine, but the 10w40 solved that.
    Have run 6 or 7 track days (road course, not drag strip) with the Mobil 1 10w40 and it's held up great.
    2014 Mustang GT w/track pack and Recaros
    Sold: B5 S4
    Track videos: Watkins Glen
    Track videos: Limerock Park
    Apr 07 2009
    Sludge heaven
    Negative, I keep a close eye on it. Just pulled the valve cover and put a new gasket on and it looked great.
    Additionally I run a bit of diesel in the oil about once a year when changing it to remove any if there is.
    I trust AmsOil's work.
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Lubro-Moly best oil ive used to date other than Motul.
    May 13 2011
    2015 BMW F30
    Quote Originally Posted by csosnowski View Post
    I like the Shell because its easily obtainable, reasonably priced, e doesnt piss out of every seal is getting old on my engine when cold. Mobil 1 did this and I was putting a qt in every 1k miles, switched to shell and I dont have to put but 1qt/10k miles. The Rotella also quieted the valvetrain noise that was present when I bought my car (car came with M1).
    I have also heard negative things about Royal Purple.
    Amsoil is good stuff and I like Elf/Quartz as well.
    | Autospeed | JHM | Pure MS
    Registered User Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by *Blue-Angel* View Post
    Lubro Moly Synthoil Premium 5W40 Engine Oil (5 Liter)
    Motul Specific 505.01 502.00 505.00 5W40 Engine Oil (5 Liter)
    Quote Originally Posted by S4 00 2.7 View Post
    Total Quartz 9000 Energy 5W40 Engine Oil (5 Quart)
    Quote Originally Posted by Trile View Post
    Motul :)
    Motul 8100 X-cess 5W40 Engine Oil (5 Liter)
    We carry only the best engine oils available on the market. CLICK HERE for our full inventory of engine oil.
    Jan 26 2010
    Quote Originally Posted by bigdo26 View Post
    10w40 in an s4 ? hmmmmm
    Mar 03 2007
    East Lansing, MI
    Quote Originally Posted by WtA4WtQ5 View Post
    First off you are more than welcome to correct me if I am wrong, people do that on occasion. Second, I was told by my local Amsoil distributor that Amsoil gets their oil from the same tap as Mobil 1 but adds there own additives and detergents so I figured I'd believe him. Third, grow up and realize you don't have to make rude remarks if you find someones statement to be false...
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 29 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    I've run quite a few different oils now to test them out. All changed with the same filter at the same 5k interval.
    Royal Purple 5W-40 did the worst. Many people have come to the same conclusion with the 1.8T engine as well. It sheared out pretty quickly not to mention when it was drained it was very dark and smelled terrible. Did not like it at all.
    Next up was Castrol Syntec 5W-40 (now Castrol EDGE). Pretty decent oil, help up well, and didn't discolor all that much. We use this in our oil changes at the local VW/Audi dealership.
    After that I decided to try out the Mobil 1 0W-40. This stuff sucks terribly. I ran it in my W8 and had some serious valvetrain clatter from it after running for a minimal amount of time. It shears out quickly and it's expensive. Avoid.
    Next was the Mobil 1 5W-40 Turbo Diesel Truck. This has gained immense popularity within the past year. I used this in my mom's TT225 along with my S4 and love it. Holds it's weight and does not shear out and definitely doesn't break down under stress. Can be had for a good price and it's readily available as well.
    And my current oil - Rotella T6. Got the idea from here and Bob is the Oil Guy. Ran this through mom's TT225 with excellent results and currently have it in my S4. Just finished 2,000 miles on it including a 150 mile spirited cruise. Even hot this stuff is still pretty thick and it's still yet to discolor much from the golden brown it went in as. Can be had for very cheap and can be purchased at Wal-Mart readily. This is the oil I will be sticking with for my VAG vehicles unless they're still under warranty.
    IMO from what I've seen the oil specifications mean jack as long as you use a good quality synthetic oil. The only engine I would be much worried about would be the PD diesel motor in the 04-06 vehicles as it is EXTREMELY picky on oil, but for 1.8T and 2.7T vehicles, T6 is the way to go.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    May 01 2010
    Atlanta
    It burns less oil because you lined all the leaky gaskets with a hearty coating of sludge.
    Active Member Two Rings Speedyj's Avatar
    May 06 2007
    OZ
    http://www.youtube.com/watch?v=49kETjPZP9Y
    a real dyno test on oils...
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Another Shell Rotella T6 here...
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Mar 03 2007
    East Lansing, MI
    Quote Originally Posted by Speedyj View Post
    Wow! I am extremely impressed that oil can make a difference in that much power! I will no longer be using Mobil 1 in any of my cars. Is Nulon readily available? I can't say I have ever heard of it...
    Jeff
    Veteran Member Four Rings DiscoPotato's Avatar
    Sep 16 2009
    Delray Beach, FL
    Quote Originally Posted by Dan[FN]5857 View Post
    Shell Rotella T6
    /end thread.
    This.
    1996 A4 - Rolled into the woods
    2001.5 S4 - Stolen
    2001 STG3+ S4 - Sold
    2011 M3 - Blown up
    2017 S3 [11.990 @ 112.38mph] - Current
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    LubroMolly is what I use, and have been using for years and years on all of my cars... UOA on it from my 2.7 was very good so why change a good thing.
    Veteran Member Four Rings Kruat's Avatar
    Nov 10 2004
    01 S4, 03 RS6, 15 A8L, 16 PSD F350
    Longview, WA
    I normally run amsoil, but lately I've been putting pentosin both my cars, since I found a local shop that carries it. Honestly, haven't noticed any difference in amsoil to pentosin.
    Side note, I put mobil 1 in my truck, just because its cheapier and easy to find.
    --Mike--
    01 Casa S4
    03 Mugello RS6
    15 Moonlight A8L TDI
    01 Aviator TT (sold)
    99.5 Santorin A4 (sold)
    04 Cobalt Allroad (sold)
    Sep 22 2011
    Western MA
    Actually if you find that rude and I hurt your feelings, I apologize.
    Established Member Two Rings IMOLA_KEV's Avatar
    Feb 20 2011
    2000 imola s4
    TORONTO
    Quote Originally Posted by schnellboy View Post
    I tried using royal purple but was going through a pint a week, so now I jus stick with mobile 1 ftw
    Mar 03 2007
    East Lansing, MI
    Haha no I don't care all that much I was just putting my opinion out there and it just isn't necessary to thrash fellow audi people... Make fun of the BMW and Mercedes people and of course the Honda/Acura people... ;)
    Mar 03 2007
    East Lansing, MI
    I just sent that and realized I own a Mercedes so maybe you were in the right :(
    But! I have owned 2 b5 A4's, 1 b5 S4 and 1 c4 S6. All of which I used mobile 1 and because of this thread will never use again... Sounds like the rotella t6 is the best oil for the buck!
