Fellas, need help with these codes... Any Ideas.. get EPC light on intermittently.. Bunch of codes... Thanks guys!
DATA:
Sunday,06,March,2016,13:56:32:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 15.7.0.2
Data version: 20150820
www.Ross-Tech.com
VIN: WAUDF78E17A125499 License Plate: 112
Mileage: 224640km-139584mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: WAUDF78E17A125499 Mileage: 224640km-139584miles
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8E0 910 115 P HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0020
Revision: 5EH14--- Serial number:
Coding: 0104010A190F0120
Shop #: WSC 03325 444 58953
VCID: 2E4B19BB2017B072BDAC28D-807A
11 Faults Found:
001152 - Can't Decode, CODE File Not Loaded!
P0480 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 223841 km
Time Indication: 0
Freeze Frame:
RPM: 838 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 67.0°C
Temperature: 30.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.462 V
001112 - Unlicensed Version. Not all DTCs
P0458 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 223850 km
Time Indication: 0
Freeze Frame:
RPM: 203 /min
Load: 61.9 %
Speed: 0.0 km/h
Temperature: 50.0°C
Temperature: 49.0°C
Voltage: 10.922 V
000052 - Unlicensed Version. Not all DTCs
P0034 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 223850 km
Time Indication: 0
Freeze Frame:
RPM: 179 /min
Load: 78.4 %
Speed: 0.0 km/h
Temperature: 8.0°C
Temperature: 8.0°C
Absolute Pres.: 980.0 mbar
Voltage: 10.668 V
000581 - Can't Decode, CODE File Not Loaded!
P0245 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 223850 km
Time Indication: 0
Freeze Frame:
RPM: 203 /min
Load: 61.9 %
Speed: 0.0 km/h
Temperature: 50.0°C
Temperature: 49.0°C
Voltage: 10.795 V
005491 - Unlicensed Version. Not all DTCs
P1573 - 004 - - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 18
Reset counter: 255
Mileage: 223850 km
Time Indication: 0
Freeze Frame:
RPM: 179 /min
Load: 78.4 %
Speed: 0.0 km/h
Temperature: 8.0°C
Temperature: 8.0°C
Voltage: 10.668 V
009216 - Unlicensed Version. Not all DTCs
P2400 - 004 - - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100100
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 223850 km
Time Indication: 0
Freeze Frame:
RPM: 1227 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 39.0°C
Voltage: 11.811 V
000665 - Can't Decode, CODE File Not Loaded!
P0299 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 224089 km
Time Indication: 0
Freeze Frame:
RPM: 3184 /min
Load: 71.3 %
Speed: 55.0 km/h
Temperature: 74.0°C
Temperature: 24.0°C
Voltage: 13.208 V
008577 - Unlicensed Version. Not all DTCs
P2181 - 008 - - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 224146 km
Time Indication: 0
Freeze Frame:
RPM: 1652 /min
Load: 44.7 %
Speed: 76.0 km/h
Temperature: 72.0°C
Temperature: 13.0°C
Voltage: 13.589 V
008852 - Unlicensed Version. Not all DTCs
P2294 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 13
Reset counter: 255
Mileage: 224280 km
Time Indication: 0
Freeze Frame:
RPM: 1227 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 82.0°C
Temperature: 39.0°C
Voltage: 11.811 V
000049 - Can't Decode, CODE File Not Loaded!
P0031 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 224281 km
Time Indication: 0
Freeze Frame:
RPM: 1127 /min
Load: 14.5 %
Speed: 27.0 km/h
Temperature: 68.0°C
Temperature: 38.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.589 V
000054 - Unlicensed Version. Not all DTCs
P0036 - 004 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 224418 km
Time Indication: 0
Freeze Frame:
RPM: 1092 /min
Load: 18.0 %
Speed: 25.0 km/h
Temperature: 71.0°C
Temperature: 36.0°C
Voltage: 13.716 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 K HW: 09L 927 156 B
Component: AG6 09L 2,0TFSI USA 0040
Revision: --H01--- Serial number: 4245588
Coding: 0000002
Shop #: WSC 06325 000 00000
VCID: 2F7504BF271DB97AB6BADD1-807A
No fault code found.
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Revision: 00000000 Serial number: 00000000000000
Coding: 0004528
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BL
Component: A4 Klimaautomat 2833
Coding: 00000
Shop #: WSC 00000
VCID: 6CCFD3B3D68B0752D358725-5140
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 01023
Shop #: WSC 65536
VCID: 3D692EF7FD715EDA3406779-4B1A
Address 0F: Digital Radio Labels: 8E0-035-593-XM.lbl
Part No SW: 8E0 035 593 E HW:
Component: SDAR XM
Revision: Serial number: AUZ4Z7E1039024
Shop #: WSC 00000 000 00000
VCID: 2B4D10AF1305C56A9AD2091-515E
1 Fault Found:
02635 - Can't Decode, CODE File Not Loaded!
000 - Can't Decode, CODE File Not Loaded!
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H12 3840
Revision: 91H12384 Serial number: 0036N0G0HYKX
Coding: 0032607
VCID: 3C6F23F3E66B52E20338425-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 3C7N0
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB403C84FB2 ÿ†63
Subsystem 5 - Serial number: 84FB2 ÿ†6342DRB4041047189ÿ†63
Subsystem 6 - Serial number: 047189ÿ†6352ARB401B95A5F ÿ†63
Subsystem 7 - Serial number: 95A5F ÿ†6362ARB401B71AD6Wÿ†63
Subsystem 8 - Serial number: 71AD6Wÿ†63729RB401BE2723Nÿ†63
Subsystem 9 - Serial number: E2723Nÿ†63829RB401BE33F2Xÿ
Subsystem 10 - Serial number: E33F2Xÿ
1 Fault Found:
00532 - Can't Decode, CODE File Not Loaded!
002 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 254
Reset counter: 39
Time Indication: 0
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 04041
Shop #: WSC 06325
VCID: 4191520781893A3A50EE1B9-4B1A
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 951 N HW: 8E0 920 951 N
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0023208
Shop #: WSC 05167 444 14772
VCID: 357936D7C541839AFC769F9-5140
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023208
VCID: 357936D7C541839AFC769F9-515E
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 J HW: 8E0 035 192 J
Component: RNS-E US H72 0260
Revision: 01S Serial number: AUZBZ2G0403015
Coding: 0301638
Shop #: WSC 00000 781 01234
VCID: 2B4D10AF1305C56A9AD2091-517C
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Date: 2011.05.07
Time: 19:38:24
Freeze Frame:
Voltage: 12.60 V
00446 - Unlicensed Version. Not all DTCs
002 - will be decoded. - Intermittent
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 169
Time Indication: 0
Date: 2011.05.07
Time: 19:31:24
Freeze Frame:
Voltage: 10.80 V
Mileage: 655350 km
Count: 603
Clock: 13:34
00858 - Unlicensed Version. Not all DTCs
007 - will be decoded.
Freeze Frame:
Fault Status: 01100111
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.06.16
Time: 09:09:19
Freeze Frame:
Mileage: 655350 km
Count: 1606
Clock: 09:08
00857 - Can't Decode, CODE File Not Loaded!
004 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.06.16
Time: 09:09:59
00467 - Unlicensed Version. Not all DTCs
004 - will be decoded.
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.06.16
Time: 09:09:32
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CG
Component: Komfortgerát T7B 4135
Coding: 11884
Shop #: WSC 06325
VCID: 78E7FFE392D3BBF227D0FE5-4B1A
Subsystem 1 - Part No: 8E1959801G
Component: Tõrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tõrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tõrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tõrsteuer.HR BRM 0606
5 Faults Found:
00962 - Can't Decode, CODE File Not Loaded!
35-00 - Can't Decode, CODE File Not Loaded!
01374 - Unlicensed Version. Not all DTCs
35-00 - will be decoded.
01371 - Unlicensed Version. Not all DTCs
01574 - Can't Decode, CODE File Not Loaded!
01573 - Unlicensed Version. Not all DTCs
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2941EAA719F9D74A68FE139-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH03 0020
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0301638
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 169
Time Indication: 0
Date: 2011.05.07
Time: 19:38:24
Freeze Frame:
Voltage: 12.60 V
Freeze Frame:
Fault Priority: 7
Fault Frequency: 8
Reset counter: 169
Time Indication: 0
Date: 2011.05.07
Time: 19:31:24
Freeze Frame:
Voltage: 10.80 V
Mileage: 655350 km
Count: 603
Clock: 13:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.06.16
Time: 09:09:19
Freeze Frame:
Mileage: 655350 km
Count: 1606
Clock: 09:08
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.06.16
Time: 09:09:59
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 111
Time Indication: 0
Date: 2009.06.16
Time: 09:09:32
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005012432
Coding: 0011677
VCID: 3D692EF7FD715BDA3406779-5140
End-------------------------(Elapsed Time: 05:54)--------------------------
