Results 1 to 24 of 24
    Veteran Member Four Rings NickyAsixx3sixx's Avatar
    Oct 16 2011
    Levittown, NY
    What kind of oil should I use?
    I can't seem to come up with an answer for this in search..
    New to Audi, first Audi..
    2001 A6 2.7T with 97K miles on it, 6 speed. Quattro. I am the second owner, just picked her up last week :) **- What kind of oil should I get??
    Thanks
    2001 A6 2.7T - EPL TUNED, Bright Blue Metallic Vinyl Wrapped, ST coilovers, Miro 111s 19x9.5s all around on 225 tires, 3" SRM downpipes, AEM Meth kit, Magnaflow mufflers, JHM LWFW, JHM Stage3 clutch, B7 RS4 PP, SRM bipipes, JHM Solid linkage
    Veteran Member Four Rings mithril's Avatar
    Jul 23 2010
    Port Moody, BC
    5W40 full synthetic as per VAG specs.
    Oct 16 2011
    Levittown, NY
    Quote Originally Posted by mithril View Post
    Great, thank you!
    Jan 31 2010
    S-Line A6
    East Haven, CT
    OEM filter, nice and cheap shipped from Scotty@advanced
    Shell Rotella T6 from Walmart at $19.99 a jug. 1.5 jugs does the job.
    Cheapest Audi oil change you'll ever get.
    Oct 16 2011
    Levittown, NY
    Can I purchase a filter locally at a Audi dealer? Or maybe an aftermarket one at Autozone/Advance auto parts/pep boys??
    Thanks Vinchenzo
    Quote Originally Posted by NickyAsixx3sixx View Post
    Thanks Vinchenzo
    yes of course, but they'll probably charge an arm and a leg for an OEM filter at your local dealer, and OEM is always best, if not then MANN filters are acceptable, wouldn't really go any other route.
    Oct 16 2011
    Levittown, NY
    Quote Originally Posted by NuGGet_PuFFer View Post
    I guess I'll get an OEM one then. What's a good dealer around here?? I'm from Levittown, how 'bout you?
    Oct 16 2011
    Levittown, NY
    I looked up North American Distributors for the MANN filters, and the closest is in Michigan??
    Oct 20 2011
    CHINO HILLS
    I've been using Mann filter since my first VW/Audi, I think they are pretty good filters!
    Currently, I am using Mobile 1 0W-40 on my 01' Audi A6 2.7t for the past 140K (oil change every 5k), they worked fine.
    I'm from nassau too, but I ordered my oil change stuff online from europaparts.com a vendor on here. they're right in jersey so ground shipping only takes a day to get here, I was already ordering all my parts from them for my timing belt/valve cover gasket service so I got an oil change kit from them as well.
    Don't know if your's has one already, but the oil caps these cars came with were non-vented, and the updated one is vented to help when the pcv/spider hose system gets clogged and the motor becomes pressurized causing gasket failure, europaparts has these as well in addition to MANN filters and pretty much everything you need for our cars OEM or otherwise, check them out.
    Senior Member Two Rings bigdadi's Avatar
    Oct 07 2010
    2012 A4 Quattro Tiptronic 2.0T
    Boston MA USA
    2011 updated AUDI Approved List of Motor Oil ... different brand different viscosity
    http://microsites.audiusa.com/ngw/09..._1997-2012.pdf
    12 A4 Quat 2.0T,
    02 A6 AvtQtr 3.0 (Sold),
    07 Subaru Outback LTD (Sold)
    Veteran Member Four Rings ratherb1's Avatar
    Jun 07 2010
    Rhode Island
    i thought this thread was going to get flamed
    whats wrong with you guys are you guys sick
    -----Romie------
    CURRENT B8.5 S4 IE TUNED
    OLD MKV GTI STAGE 2
    OLD C5-A6-2.7T-STAGE 2-SELFTUNED-ST-TSW
    Feb 07 2008
    The boonies, near Seattle
    This topic has been beaten to death.
    -dre
    Oct 16 2011
    Levittown, NY
    I know thanks.
    Jun 15 2010
    2000 2.7t 6 spd, 2.9tt volvo XC90, B6 audi A4 3.0, 2004 RS6,
    edmonton
    depends a bit on your climate, i just changed mine to mobil 1 0w40, winters coming and it gets to -35deg c here so 0w is a must. just stick to what is approved or not. Lots of guys use rotella, its cheap but not approved.
    4.2T RS6 in Daytona grey (fastest colour)
    2.7T A6 6sp in metallic silver (2nd fastest colour)
    Oct 07 2010
    Boston MA USA
    The Audi approved motor oil makes my mechanic mad ... he insists to put Mobil-1 5W-30 in my Audi. I told him at the back the bottle VW502.00 is not found. He said "trust me, this is good oil with my 30 years automobile experience." He got MAD after I show him the above 2011 Audi approved oil list and tell him that ONLY 0W-40 is approved. Funny thing is he ask me to call the Audi dealer. I told him the list is from Audi, the daddy of all dealers. He still does not want to believe it... funny guy.
    I now think should I go back to his garage as he does not has such basic knowledge of Audi approved motor oil. I am going to extract the 5W-30 out and fill M-1 0W-40 back in tomorrow.
    12 A4 Quat 2.0T,
    Oct 16 2011
    Levittown, NY
    I went with Rotella T6, it's not approved??? oh boyyy, might have to drain that out get something better :( hmmmmmm
    Veteran Member Three Rings Calimus's Avatar
    Oct 26 2010
    88' Scirocco, 89' Cabriolet, 16' A3 E-Tron, 05' FJR1300
    NW Georgia
    Nicky - Don't worry about the Rotella, it's fine. A lot of folks get very hung up about what's on a dealer/manufacturer approved list. What you really need to be concerned about is that there aren't any additives that are harmful and that you are in the correct weight range. Rotella T6 meets those requirements. Many of those approved lists are due to agreements and partnerships between the manufacturer and those related parts/oil/ect.. companies. Some of it is actually based on science but some of it is just based on deals/partnerships.
    I've run Rotella in my Audi for the last year with no issues (save for the damn VC leaks but that's unrelated). I also use it in my VW's, save for the Scirocco's which just get 20-50 castrol normal dead dino's since it's cheap, does the job and they have a high change rate.
    Continue with the Rotella, just make sure the weight is fine for your climate. 5w should be fine for NY since you generally don't have constant temps in the deep negatives during winter (I'm actually from the Buffalo area so I know what a good lake effect winter is like up there). Just remember to give the engine some time to warm up before taking off and keep the rev's low till she's near normal running temps. 0w is great for the great white north since they see weeks of deep negative temps. Then again, many cars up there have block heaters too which is a massive help.
    I know I'm sure to get flamed for what I've said, but that's fine. I've never had an engine lock up or fail in any way due to the oil I've used or work I've done. I did have a VR6 snap a timing chain, but that's because the chain guides broke and I didn't catch it quick enough. Just keep you oil changed at proper intervals or even less than normal if it makes you feel better and you will be just fine.
    William
    12' 3.0T A6 Prestige - The white whale
    02' 2.7t A6 - Gone but not forgotten
    Oct 07 2010
    Boston MA USA
    The motor oil subject sure starts a long debate. Everyone has its point.
    I think my decision of change is correct because Mobil-1 0W-40 is in the Audi list (safe w/VW50200 listed at bottle) and should be better than viscosity 5W-30 for the Boston winter.
    Both are Mobil-1, 0W-40 has VW50200 approved and the other does not, so this is not partnership issue as upstair stated.
    12 A4 Quat 2.0T,
    Established Member Two Rings PPGOAL's Avatar
    Nov 17 2006
    Holland MI
    The guy I bought my 2.7T from at 37k used Mobil1 0W-40 and I have for the next 153k miles. No problems. I will admit that my spring oil change usually involves about 5 qts of 5W-30 and the rest 0w-40, but winter is straight 0W-40 to ensure the turbos are well lubed when it is below zero out. It gets changed every 7-9k and that used to be 4 changes a year, now down to two.
    2011 A4 2.0T Premium Plus MT6
    Colgan Bra and Mirror Covers; stage 2 clutch
    2003 A6 2.7T MT6 - sold March 2015
    Premium-Cold Weather-Bose; GIAC-Bailey DVs-Samco TBB-K&N
    AWE Stage 2 Clutch+Lightweight Flywheel; Colgan Bra; SS Brakelines
    Billy Boat Downpipe Kit, Velocity RS4 Replica Rims
    2018 Maserati Ghibli SQ4
    2005 Chrysler Crossfire SRT6
    2005 Chrysler Crossfire Roadster MT6
    Veteran Member Four Rings G Men 08's Avatar
    Feb 05 2008
    One trick pony at the time.
    Waterloo NY
    Its motor oil. As long as you are not high performance, pretty much any name brand fully synthetic from 5w30 to 0w40 will be just fine. So many people make such a huge deal out of the oil they put in their car saying that the other stuff is junk, and this stuff is the best thats why I pay 10 dollars or more per quart blah blah, and really have absolutely no reason to put it in their car.
    A Mann filter, (10-12 dollars at any online distributor pretty much) with a full synthetic as stated about will be just fine.
    B6 A4 3.0-sold
    C5 A6 4.2-sold
    C4 A6 2.8-sold
    B5 S4 A few mods-SOLD thankfully!!
    MKIV Golf TDI- SOLD MPG were amazing but other than that...
    C5 allroad 2.7 auto
    Veteran Member Three Rings Hambone101's Avatar
    Apr 21 2009
    1967 Mercury Cougar
    Clearwater, FL
    In the 2.5 years of owning my car, I've used Mobil 1, Castrol Synthetic, and Fuchs in either 0w-40, 5w-40 or 5w-30. Never had a problem with any of them. Just keep up with the service intervals and you'll be fine.
    redneck truck - Everybody quieted down when the guy up in the back of the theater asked his date for a Come flavored slurpee.
    Veteran Member Three Rings jmgraham78's Avatar
    Jan 19 2010
    2004 Acura TL, 2000 A6 2.7T MT, 2001 Allroad
    I use car motor oil..............
    SEARCH THE FORUM............
    2000 A6 2.7MT - currently gutted, a few parts left, PM me if you need anything.
    Veteran Member Four Rings mikehawk666's Avatar
    May 17 2010
    Colorado
    extra virgin olive oil
    '78 F350
    VW T3 tintop
    Mk2 GTi VR6
    E46 Touring
