Included with my timing belt kit is the front crank seal. I'm wondering if I should bother replacing this, as I don't believe it's leaking and a search doesn't find anyone who has ever indicated they ever had one of these leaking. I find references to the rear main leaking, but not the front.
If I do replace it, I see mention of needing a special tool, but am I correct in thinking it's not really required? I figure I just mark everything first and then use my impact gun to take the crank bolt out. Timing belt sprocket should then come off revealing the seal, no? Removal and replacement should be about the same as the cam seals, right?
