Results 1 to 25 of 25
    Oct 16 2011
    SLO
    Unhappy Rough idle after AUX Water pump replacement? Help!
    My aux water pump was starting to leak more and more so i followed a guide i found for taking off the intake manifold and replacing the pump. I am pretty sure everything is connected again and i didn't mess with anything but the pump. Now the car idles very rough. There is also a strangle whistling sound when the engine first starts that i have never heard before. It evens out when i get above 2500rpm and sounds fine. No error codes are thrown. I re-used the intake manifold gaskets... are they not re-usable? Could it be that i cracked the spider hose or whatever the hard plastic hoses are in the back? Did a sensor wire break? How do i debug this? Would a video help people?
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    check all vaccuum hoses for leaks..
    re check EVERYTHING over and over agian.. if it wasnt there before its something you did while replacing the AUX pump
    the pump replacement itself wouldnt have ANY sort of adverse effect on idle!
    isolate the sound and i bet you find the problem..
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Veteran Member Four Rings amd is the best's Avatar
    Oct 05 2007
    '91 200 20v, 01 A4 2.8 PES
    Manteca, CA
    The cracked spider hose and/or the fact that you reused the IM gaskets could certainly cause idle issues if you have created a vacuum leak. Do you have a boost gauge installed? What is it pulling for vacuum at idle?
    2012 Golf TDI
    2001 A4 2.8 Avant
    1991 200 20v
    YouTube
    8V Audi S3/RS3 Facebook Group
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    vacuum leak. pressure test needed. fyi..
    RS6 hybrids and corn
    Oct 16 2011
    SLO
    Wow fast responses
    Ok, I read about pressure testing and i will make one from home depot parts and try that tomorrow. I have never done a pressure test with an air compressor.... Jeep people just spray carb cleaner everywhere while the engine is on until the rpm spikes.
    I am ordering the center boost gauge... finally. When I saw the price I almost shat myself. Do people install vacuum gauges permanently? If so, where?
    Veteran Member Four Rings wannabeS4's Avatar
    May 14 2008
    01 S4 Avant
    New Hampshire
    I had the same problem recently and realized I hadnt torqued that intake mani down all the way, fixed my rough idle. I agree you probably have a vac leak somewhere.
    Brilliant Black S4 Avant
    #BODENARMY
    Jan 24 2010
    Paramus,NJ USA
    I'd say check your IM Gaskets maybe your didnt change them or you broke on of the 1 million plastic hoses under and behind the intake.Happens every time.Thats why many people relocated the aux water pump to resolve this issue and make it more accessible.
    Oct 16 2011
    SLO
    made pressure tester
    I put in about 10 psi and i do not hear any leaks ... i am going to try soapy water next. Any ideas ?
    Tried soapy water, only some tiny bubbles where one of the hard plastic hoses connects to a check valve. The system holds a few psi for quite a while so i don't think its a vacuum leak.
    Oct 16 2011
    SLO
    I tried running the engine without the MAF sensor plugged in and it seems to run exactly the same...... thats not what is supposed to happen right? Did i break the sensor somehow?
    I should be getting a code reader in a few days so maybe it will report no signal ?
    Jan 24 2010
    Paramus,NJ USA
    check fault codes first.If you have any sort of leak the engine will be runnning lean and will have lean codes on short term fuel trim and long term.report back once you've pulled the faults thats the best way to go.
    Oct 16 2011
    SLO
    with my shitty code checker i pulled the code p0300 (random misfires). I get the good bluetooth code reader soon!
    Veteran Member Four Rings shorterthanrich's Avatar
    May 24 2009
    2000 S4 Nogaro Blue, 1996 Ford Exploder
    Boston
    You definitely have a vac leak or damaged the MAF sensor/wires. Are you sure no dirt/grit snuck its way in between the intake manifold and the heads? i.e. messed up your gasket seal?
    FREE BEER, click: Pintley - Tap Into Your Tastes!
    My iPhone/Android App
    2000 S4 Nogaro Blue DxC/BritishTurbo Stage GTX
    GTX2863 Build Thread - 575WHP
    Oct 16 2011
    SLO
    i just watched all the stats using torque lite. Now once it has heated up it seems to run better. The maf is showing what looks like logical data, the coolant temp looks right. It just seems to run really really rough when its cold and just at low rpm. I might take a video of it and post it. What engine data would be out of place at idle? My timing advance is 10-30 ... is that normal ?
    Oct 27 2006
    Currently only S4
    Fort Walton Beach FL
    Oct 16 2011
    SLO
    Yeah the solenoids are plugged in right. i did not disconnect the fuel lines when i did this either.
    After some more testing i have noticed that on initial start-up it is working fine when the rpm is about 1200 and its cold. Only does it start to get really rough when the RPM drops to the normal 800. It is now quite repeatable. Where are the check valves that people say fail?
    Senior Member Two Rings acoleman's Avatar
    Feb 07 2011
    Bismarck, ND
    Did you open the throttle body while pressure testing? If there is a leak at the intake manifold, I don't think it would leak during a pressure test unless it's open.
    2001 A4 -sold
    2001 Stage 3 S4 -sold
    2005 A4 -sold
    2012 Q7 -sold
    2013 A4-sold
    2015 SQ5 -sold
    2017 Q7 prestige -current kid hauler
    Oct 16 2011
    SLO
    I did not open the throttle body.... i thought since it doesn't make a perfect seal it would not block anything... am i wrong about this? I think my next step... unfortunately... will be buying new intake manifold gaskets.
    Feb 07 2011
    Bismarck, ND
    Quote Originally Posted by rat9 View Post
    Ya you're probably right. Sounds like new intake manifold gaskets should do the trick.
    2001 A4 -sold
    2005 A4 -sold
    2012 Q7 -sold
    2013 A4-sold
    2015 SQ5 -sold
    Oct 16 2011
    SLO
    Ordered the intake manifold gaskets and spacers. i will report back with my results. Thanks for the ideas!
    Oct 16 2011
    SLO
    I replaced the gaskets and this time really moved the intake all the way off so i could clean it all and have a good look. I am sure everything was clean and torqued this time. I also replaced the spark plugs and coolant sensor. Nothing has changed.
    My MAF reads about 10 when at idle, I also noticed that the timing advance fluctuates between 0 and 20 when it is at rough idle... is this related to the problem? Shouldn't it just stay at about 0?
    Feb 07 2011
    Bismarck, ND
    My S4 is doing the exact same thing as this. I'm getting it checked out on Saturday, I'll let you know what I find out.
    2001 A4 -sold
    2005 A4 -sold
    2012 Q7 -sold
    2013 A4-sold
    2015 SQ5 -sold
    Oct 16 2011
    SLO
    So i am playing with the spider hose now looking for cracks, does anyone know if the pancake pcv valve is supposed to be a check valve or do anything other than be an elbow? Mine has full air flow in both directions and that seems wrong..... ????
    Oct 16 2011
    SLO
    Well the consensus is that the pancake valve is NOT a simple check valve and mine is working fine. In other news I have sprayed out the check valve that connects DIRECTLY into the accordion pipe and i think i have solved my problem! This check value was NOT installed when you do a pressure test so that is why it took so long to find. I should probably replace this valve but cleaning it seems to be working for now.
    Oct 16 2011
    SLO
    Well my problem has changed. I am going to start a new thread because this really has nothing to do with the water pump any more.
    Oct 16 2011
    SLO
    The solution to this problem for those of you searching this thread was my MAF sensor. Everything is fine now.
