Results 1 to 30 of 30
    Sep 10 2011
    None
    Passenger Door Lights Not Working
    Both front and rear passenger doors have no illumination (neither the red markers on the side or the puddle lights). Everything else works fine in both doors (power windows and door locks and their illumination), just not the puddle/marker lights. Any ideas? I find it odd that it's both doors on the same side.
    Senior Member Three Rings Batcave's Avatar
    Feb 08 2011
    Pacific Northwest
    What about the door open indicator on the dash?
    Sep 10 2011
    None
    Let me check...
    Sep 10 2011
    None
    Yep. The door open indicators are working and floor illumination works, but still not puddle and side indicators. I find it weird the two are linked because the fuses are divided front and back and not Driver-side to Passenger-side, so it's not a fuse issue (checked em anyway, but not it).
    Sep 10 2011
    None
    Really need some help with this. Don't really know what to check...
    Veteran Member Four Rings jursch2211's Avatar
    Feb 05 2008
    Illinois
    Search function my friend, even if you didn't know what to search for just try something simple like "door problem" Click Me
    || APR | BW K04-015 | ER FMIC | OEM S4/RS4/R8 Parts | '10 RNS-E | Hotchkis | Adam's Rotors | Podi | OCarbon | Euro Headlights | Euro Color DIS | Euro MKII TT MFSW | Euro Trunk | BBS | Vogtland Coilovers ||
    Sep 10 2011
    None
    Quote Originally Posted by jursch2211 View Post
    Just read that thread. It doesn't really pertain to the issue I'm looking at. In that situation the whole door (locks, windows, everything) quit working. Mine is just the lights, not only that, but the same lights on both doors of the same side of the car. Might go ahead and check all the fuses tonight, see if it some odd something-or-other.
    Feb 08 2011
    Pacific Northwest
    It's probably just something simple like broken wires.
    Feb 05 2008
    Illinois
    Quote Originally Posted by CrazyCal View Post
    This is why I posted what I did, you didn't search. I provided a thread that had some good info on what to check, the door wiring harness. This area has a lot of wires that are prone to cracking. Maybe you don't have all the symptoms but it's another check method. Just pull the rubber grommet back and look for cracked wires, that would be the simplest check, or try opening the door every so slightly and see if the lights flicker or come on when the door opens/closes to a certain point. Then after you tried that, you can report back. It would be strange to have both doors with the same cracked wire but it is possible. I could be wrong with my diagnosis but at least I provided you with another method which you didn't search for and test.
    Sep 10 2011
    None
    Thank you. I do appreciate your input. I will check as soon as I can and report back. I did quickly check the doors tonight (now that it's dark I can see the lights) and they do flicker on for just a split second when I open either door. But I can't get them to stay on even if I try to hold the door at the point where they flicker. Looks like I'll be checking fuses AND pulling the boot back to check the wires.
    Sep 10 2011
    None
    Bringing this back from the dead. Do both passenger doors somehow tie into eachother further down the wiring? That's the only way i can see this issue happening to both doors the exact same way.
    Veteran Member Four Rings Dan1969's Avatar
    Aug 16 2009
    08 Silverado 2500HD 6.6 Diesel
    In the OK Corral
    Can you control the doors from the individual door?
    17 Jetta S 1.4T, 08 Silvy LTZ 6.6T CCSB
    Previous: 1997 VW Jetta, 2004 Audi A4 3.0Q6MT, 15 Audi A3 2.0T Q DSG
    Sep 10 2011
    None
    Yes. Everything works in the door except the puddle lights. When I open the door, the puddle lights flash on for just a split second and then nothing. Both doors on the passenger side.
    Veteran Member Four Rings waldo1324's Avatar
    Apr 06 2009
    the Ghost of the Princess, 2007 Ford Fusion, 2006 Honda Accord
    The StL
    I have the same problem. it's got to-be the switch that recognizes the door is open.. works intermittenty. on other cars there is usually a physical switch that is actuated by the door. in OOOO. it seems the switch is integrated into the latch. let's takethat door card off!
    Sep 16 2010
    Central Wash
    Yeah, it's the microswitch located on the door latch. One of my rear doors did that when I bought my 03' . I think what happens is the switch still 'works' meaning the ground signal when door is open is happening at the latch, but a connection on the latch is failing.
    I tricked it by soldering a short length of wire around the circuit- basically I ran a wire from the connection on the latch microswitch to the wire in the harness at the main connection for the latch. Fixed.
    I used VCDS to read measuring blocks and tested the wires one-by-one at the latch until I found the wire that, when grounded, told the door locks module the door was open. Patch that wire to the microswitch.
    Apr 06 2009
    The StL
    Quote Originally Posted by rollerton View Post
    awesome. but alas, im minus VAG COM (the good one anyway).. ill just replace the microswitch(
    ""GHETTO MODIFIERS"" member #1
    The Princess: SOLD.. i love you, please forgive me
    "I agree with Waldo 100%" -1997GTX
    ..psst if you have a 2003+ 225 TT, email me..wally.iverson(at)gmail.com
    Sep 16 2010
    Central Wash
    You could do it with a multimeter or even a test light too.
    You just want to probe the wire at the latch harness, if you use a test light to ground, the interior light will come on when you hit the magic wire. Verify that your microswitch is still cycling ground/ no ground when the door-latch-catch is operated, and if so solder your patch wire from the microswitch to the wirenat the harness.
    If you replace the microswitch it may not fix it if the the connection on the circuit board has failed.
    Senior Member Two Rings asg1290's Avatar
    Dec 04 2010
    San Francisco, CA
    sorry for the necro bump but I just encountered this exact issue today. Only my passenger side puddle lights are not working. Everything else works as normal. Did you ever figure yours out?
    Feb 12 2008
    Michigan
    Makes me wonder if the ccm could be showing one it's it's multiple failing points? Both of my passanger doors intermittently will not trigger the puddle lights or door open sign on the dash, like when car is running they don't work but when car is off they work
    Dec 04 2010
    San Francisco, CA
    Quote Originally Posted by Fast4esT View Post
    Door open signal on the dash works, windows work, etc. I'm going to spray a little wd-40 up in latch to see if that helps.
    Veteran Member Three Rings 1/4 scale's Avatar
    Mar 03 2004
    North Carolina
    Quote Originally Posted by Batcave View Post
    Probably the cause. Check and peel back boots between body and door and check small wires. My problem with windows and door light function was actually related to the driver's door at this location.
    2002 A4 Avant 1.8T • APR +1 • DSMIC • JJ tip • RS4 mounts • SB OFE HD • Apikol snub • B5 S4 binders • 18" Ultraleggeras w/ Conti D/Ws • APR exhaust • APR TBHose • Stasis SS • S4 rear sway • AMS ss • e-codes • Pzwo lip • S4 blades • USP roof spoiler • Apex track studs
    Dec 04 2010
    San Francisco, CA
    Quote Originally Posted by 1/4 scale View Post
    I ordered a bunch of micro switches since they are cheap. Out of curiosity, what was specifically wrong with the drivers door that caused the passenger side to go out? I swapped out my drivers window switch the other day. Maybe I broke something.
    Registered Member One Ring voltage's Avatar
    Mar 06 2018
    Yamaha YZF R1, Aprilia SXV 550
    Montreal
    I got similar situation with rear left door ( behind driver )
    Here is my case
    Couple of weeks ago I had my two left doors ( Driver door and rear left door ) replaced under Audi Rust warranty.
    The doors were replaced with new doors - painted etc.
    all look good but last night I noticed that rear left door lights :
    button illumination light
    door latch illumination light
    warning light ( red )
    entry light ( puddle light - in my case with audi logo ) is not working
    I cant lift or open the window from this door button
    I cant lock the car from rear left door lock button
    Sound is working
    The door locks and unlock from car key or driver door
    the window open and close from driver door
    I haven't got the rear windows locked from driver door as the rear right door is completely functional , lock/ window lights - all of the lights.
    Dash indicate when door is open and closed.
    I've made few pictures to illustrate
    and run diagnostic with VAG Com 12.12 ( diagnostic log bellow )
    Here are pics (I don't know how to make them visible)
    https://photos.app.goo.gl/m1NKq8b96LDJqFBk2
    https://photos.app.goo.gl/TQX8a9wZIfpBa4Th2
    https://photos.app.goo.gl/rcivoSe2Pu0x6zZe2
    https://photos.app.goo.gl/dqgKcLfo4hRcsfd32
    VIN: ******* Mileage: 214360km/133197miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Xenon Range -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 000
    0
    62-Door, Rear Left -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
    Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
    Component: TSG FA H11 0306
    Revision: Serial number: 0000009038310
    Coding: 011C03204E00410001
    Shop #: WSC 06335 000 00000
    VCID: 4581B79FCC543D36E75-8010
    1 Fault Found:
    00446 - Function Limitation due to Under-Voltage
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 22
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
    Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
    Component: TSG BF H11 0306
    Revision: Serial number: 0000009025102
    VCID: 4487AA9BC76E043EF0B-8011
    No fault code found.
    Address 5F: Information Electr.
    Cannot be reached
    Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
    Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
    Component: TSG HL H10 0306
    Revision: Serial number: 0000101486843
    Coding: 010C03204000210001
    VCID: 428BAC83DD7A0A0EC27-8017
    2 Faults Found:
    02123 - Door Warning Light / Entry Light
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 147
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 22
    Time Indication: 0
    Date: 2064.00.00
    Time: 00:00:00
    Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
    Component: TSG HR H10 0306
    Revision: Serial number: 0000101486851
    End ---------------------------------------------------------------------
    I will appreciate all the technical help
    If somebody can tell me what these codes mean it would be great.
    Have an appointment to the dealer but is after a month .... and I honestly have very little faith
    Thanks
    When I am on the road, no one can stop me.
    Audi A4 B8 Avant 2.0 TFSI Premium +
    Yamaha YZF R1
    Aprilia SXV 550
    Jun 29 2014
    Dopest foot mobile you ever did saw!!!!
    United States
    Check the harness for wires that have become brittle and cut over time. My driver door had loss of lights and no sound from the speaker. I looked at the harness where the door opens and shuts and that's all it was. I cut and soldered the wires and good as new. Good luck.
    03 Avant 3.slow, H&R sways, custom 2.5" exhaust, RNS-e, Airlift with v2, Rotiform ccv 19x10 square set up, Recaros and S4 paddle shift wheel cause I'm old and my knees hurt :)
    Feb 12 2008
    Michigan
    check the driver door wiring harness. my passenger door lights started working after I replaced the driver door harness.
    Mar 06 2018
    Montreal
    Thanks for the advises guys
    I open the trim and found the problem.
    One of the plugs was disconnected from the control Unit.
    This one:
    https://photos.app.goo.gl/QukzQNGTEFwTWYzi2
    everything went back to its normal working order.
    Cheers
    Yamaha YZF R1
    Aprilia SXV 550
    Jul 07 2018
    SugarLand TX
    Quote Originally Posted by voltage View Post
    This one:
    Cheers
    Hello Voltage.... I am having the same problem with my 2001 Audi A6 2.8T. My passenger door front and back light will not illuminate and will not trigger the interior light.
    Which trim did you open? where exactly did you find this module in the picture? Thanks. My was working until yesterday
    Senior Member Two Rings 36dbldz's Avatar
    Dec 15 2018
    Escalade ESV, Audi A7
    North Florida
    I'm now joining the party. Did you figure it out?
    Quote Originally Posted by azontodance View Post
    Sent from my Pixel 3 XL using Audizine mobile app
    Senior Member Three Rings jj94tt's Avatar
    Feb 24 2011
    Pittsburgh
    I just want to add - the door latch has a 7 or 9 pin connector. These common problems may not be caused by the micro switch itself... but by solder connections where the connector pins are attached to the circuit board. In my case, the problem was especially annoying to trace because everything tested fine when it was apart. But when the latch was put together and the screws tightened, the circuit board flexed just enough that the pin-board connections became unreliable.
    2005 A4 B6 3.0L 6MT USP Ocean Blue
    USP CLUB MEMBER #230
    Jul 14 2009
    Pasadena
    having this issue now. Checked door wires and they all seem to be fine. I might just buy a new harness
    IG: @matthewee
