It smokes under boost and on startup. Idle is getting rougher. I'll be doing a compression test today and calling AOA this week as the car has an extended power train warranty. Ideas, suggestions or random comments are welcome. I'll keep everyone updated.
Previous/ongoing symptoms:
-low boost
-torn stock dv
-oil buildup in every inlet and pipe
-oil consumption (1qt every 1200miles)
-PCV went out
-intermittent smoke under boost and on startup
-exhaust issues, running hot, exhaust smelled/sounded funny
Parts/Fixes
-upgraded DV (rev D)
-adjusted wastegate
-replaced N75
-replaced PCV with catch can
-found cat clogged, installed RAI DP
UPDATE: AOA is replacing the turbo under warranty.
