Results 1 to 18 of 18
    Jan 03 2011
    Melbourne
    Towing capacity for 2011 a4 2.0t quattro
    Hi guys,
    A search has not revealed a great deal. Is there anything you guys can share about what is required to tow a caravan and capacity of the quattro (i.e. is it advisable and what mods are needed if any such as brake upgrade, power upgrade such as stage 2/3 and of course the tow bar kit).
    Thanks a heap lads.
    Sep 09 2009
    09 RDX
    Rhode Island
    IMO your going to kill the engine if not then cut its life down. I don't think these cars are made to tow anything especially the 2.0, you just putting more stress and strain on all the parts.
    AEM Boost Gauge * Eurocode FMIC * JHM Shiftier * AMR Tune
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    My buddy pulls his sled and trailer on his b7 manual trans, I'd say close to 400kgs. No idea on the max though :P
    Bryan
    Jan 03 2011
    Melbourne
    yeah right thanks guys, does not sound good as I was thinking of a large caravan... anyone with experience/thoughts they can add?
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    You may want to inquire directly to Audi to get some official and hopefully technically sound advice. Advice from the European Audi office would probably be the best. There must be a good number of Audi's towing caravans around Europe over the years and concerns or issues should not be hard to uncover.
    2011 A4 Avant
    Veteran Member Three Rings MYFASTA4's Avatar
    Sep 03 2009
    C7 A6, A4 B7 AVANT, B8 ALLROAD & BOX-SPYDER
    Florida
    im sure that info its in the manual
    2014 S4 6MT, B&T, sport dif., MMI+
    2015 A3 8V
    2001 TT MK1-225
    Mar 14 2007
    09 A4 2.0 6MT AWE Exhaust&FMIC
    New York, NY
    Audi lists the Q5 towing capacity for both the 3.2 and 2.0T engines as 4400 lbs. with a maximum 440 lbs. tongue weight. There may be some other limitation when towing with the A4, but if Audi is okay with blessing both powerplants with the same numbers on the Q5, the 2.0T wouldn't be my concern in the A4.
    http://models.audiusa.com/q5/detaile...ions?engine=64
    Jan 03 2011
    Melbourne
    thanks guys, I am in Australia and thedealers I have spoken to have been vague at best (amazingly...)
    Apr 16 2010
    Washington, DC USA
    I looked in my B8 A4 owner's manual recently and saw 2000 pounds with a 200 pound tongue weight.
    Established Member Two Rings Devils Advocate's Avatar
    Oct 17 2011
    San Diego
    Maximum load is by far not the only thing you should take into consideration. The size of your vehicle compared to the size of what you are towing plays a large role. Imagine towing a lightweight aluminum boat behind your little sedan, if the wind picks up and starts tossing the boat around, how do you think that's going to affect your car? You'd be lucky if the only the hitch snapped and your car didn't flip with it. Towing a large caravan(RV type deal I'm assuming, not a dodge caravan on a two wheel uhaul trailer, which is inherently a bad idea anyway) with a sedan is a very bad, and dangerous idea not only for you but everyone else on the road. I guess this is bad form to have a somewhat negative or warning type first post, but it hadn't been said yet and is quite needed.
    Case in point: This is an SUV (and probably a bit of driver error), with a load. Imagine a vehicle half the size like the a4 pulling something, it's not pretty.
    http://youtu.be/SFzCnsr_gEQ
    Aug 25 2013
    2014 Audi A4 6MT, Nav, Premium Plus, No Sport Pkg
    Washington D.C.
    I know this is an old thread, but my 2014 2.0T A4 6MT Quattro driver's manual says that we're limited to a class I or class II trailer. It doesn't mention any specific specs on trailer weights. However, here are the specs for towing from a british manual for a 2009 A4:
    Interestingly, the 2.0T was not listed in the British Owner's Manual. BTW, a class II hitch can only tow 3500LBS. So why can they tow so much more across the pond?
    May 10 2012
    downingtown, PA
    It's NOT just the engine when considering towing capacity. other factors include the design of the frame, transmission, suspension, and brakes.
    Veteran Member Four Rings booost's Avatar
    Jul 17 2008
    '12 VW Beetle Turbo DSG, a boat
    Sorry, nothing useful to add but I wanted to post this from the 'what did you do to your B8 today' thread
    Click: B8 Quartz Grey Metallic A4 2.0T quattro | 18" Peelers et35| APR stage 1 | aFe | eurocode | H&R | 3.0 TDI FMIC | PowerStop | PODI
    Sold: B5 Silver A4 1.8T Quattro 5MT GIAC KO4 | B5 Santorin Blue A4 2.8 Quattro 5MT | B6 Caribic Blue A4 3.0 cabrio
    Aug 25 2013
    Washington D.C.
    Quote Originally Posted by tofast2belast View Post
    Yes, but the chart above shows that the 3.2 out-tows the 1.8T by 1,000lbs. If you ask Audi of America, they'll say that our cars are rated at 2000lbs towing capacity.
    So, the math goes this way:
    British A4 3.2= 5,000LBS Towing Capacity
    British A4 1.8T= 4,000LBS Towing Capacity
    American 2.0T = 2,000LBS Towing Capacity
    That's some screwed up math, right there! What gives?
    Aug 25 2013
    Washington D.C.
    Quote Originally Posted by booost View Post
    One car to rule them all! Well done, sir.
    Senior Member Two Rings Classy's Avatar
    Feb 02 2014
    NH
    Id feel pretty comfortable towing a Jetski or something small like that behind my Manual A4.
    If only I had quick access to a lake... :/
    Senior Member Two Rings dylannorton's Avatar
    Oct 01 2012
    For those who have installed wiring for their trailers. Did you use a kit with a regulator or just simply wires to the connector? I plan to just buy the wires at home depot for 8 bucks that hook directly up to the 4 prong connector rather than spending money on a kit online.
    Jul 07 2012
    Rocklin, CA
    Quote Originally Posted by dylannorton View Post
    I believe you need the kit or else you will get error codes. The computer will sense an increased load and throw an error because of it. The kits (like the one from Curt) will only sense the voltage on the line, and then power the wiring harness using power from your car battery directly.
