I've been battling a "MAF" problem with this car for some time now, and i'm finally ready to ask for some help because I have no idea wtf is going on with this thing. I say "MAF" because I really dont think its the MAF sensor. Here are the symptoms:
- In idle, multiple misfires and runs like junk, sounds like its got a huge cam, blip the throttle and smooths out and runs fine until it drops back to idle again
- Throws 7 codes: 300-304, 306, & 102 (misfires for all but cyl 5, and MAF low circuit)
- It will run like ^that^ until it disregards the MAF sensor (at least thats what i understand), i then get a solid ESP light and it runs great until i clear codes and it goes back through the cycle
What i've done:
- If I unplug the MAF, I get a solid ESP and CEL, and the car runs fine (aside from hard reverse to drive transitions on the TIP).
- Since it runs fine with the MAF unplugged, I've tried replacing the MAF with a brand new one but get the same issue.
- I thought I may have had a bad MAF out of the box, so i bought another one with the SAME result
- Replaced all my vacuum lines thinking it could be a vacuum leak, same result (plus doesnt make sense as it runs fine with MAF unplugged)
Before anyone suggests it, I had the CP recall done.
Any suggestions guys? It acts like the MAF is bad but I've tried two brand new MAFs.
