Results 1 to 28 of 28
    Dec 07 2008
    Harrisburg, PA
    Cigarette Lighter Not Working
    Guys, checked the fuse it's ok.
    I'm thinking it's the outlet or a wiring issue.
    Thoughts.
    Sep 13 2008
    Western Chicago Burbs
    Check it with a multi meter. I really doubt it's the wiring. The wiring is pretty hefty as well as the connector, and there is nothing down there for it to get snagged on.
    Veteran Member Three Rings estomax's Avatar
    Jan 16 2009
    07 A6 Avant 3.2L, 13 Leaf, 08 Titan
    which one are you having trouble with? The one in the ash tray or the one under the armrest/handbrake? My buddy's b7 A4 just lost the port under the armrest, do you guys know which fuse it ties into? He had a coin fall in there he said so i imagine it blew a fuse somewhere.
    cheers
    Marko
    Sep 13 2008
    OP has a B6. There is only one outlet
    Dec 07 2008
    Harrisburg, PA
    Mine is the one behind the shifter that you push on to spring up.
    Veteran Member Three Rings plokm's Avatar
    Feb 19 2007
    Louisiana
    check all your fuse...I had the same problem and one of the fuse was burnt. It wasnt the lighter fuse.
    Veteran Member Four Rings Coderedpl's Avatar
    Jul 27 2007
    Orange County, NY
    How exactly did you check your fuse?
    I still think it's related to a fuse than anything else.
    Current: F80 M3 | 2018 Q7
    Past:2018 VW Golf R | 2014 S4 | 2016 Nardo Gray SQ5 | 2012 VW Golf R | 2006 Audi S4 | 2006 A4 2.0T |
    Dec 07 2008
    Harrisburg, PA
    Quote Originally Posted by Coderedpl View Post
    I took off the cover on the end of the dash and pulled the fuse.. it was not blown.
    Aug 18 2009
    A Unicorn
    Portland, OR
    I have this same issue on my B7 but the front one. Did you ever resolve it? Which fuse(s) should I check. I
    :: Seller feedback ::
    RIP: 2006 DG Avant Tip
    Jul 27 2007
    Orange County, NY
    The cigarette lighter fuse.
    Aug 18 2009
    A Unicorn
    Portland, OR
    Lol. Yeah yeah. I guess it was a dumb question. Frankly I was too lazy to walk out to the car and check the little diagram
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    Guys I have this same issue but my cigarette lighter fuse is not blown. My front ash tray lighter does not work but the rear one behind the cup holders does. One fuse for both lighters?
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Aug 18 2009
    A Unicorn
    Portland, OR
    They have separate fuses (not sure what the cupholder one is tied in with though). Mine was just like yours - ashtray didn't work, cupholder did. My fuse was definitely blown though - simple fix.
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    ya it totally seems like thats the problem with mine as well. But without pulling every fuse out and checking i feel like i cant be sure. Like I said I looked up what number the cig lighter fuse was and it wasnt blown. nothing else on the fuse list looked like it was tied to the front cig lighter
    Aug 18 2009
    A Unicorn
    Portland, OR
    Dunno man. Mine was definitely blown. But then again I also have a buttload of pennies jammed behind the ashtray thanks to the PO. And I can't find my stupid radio keys to get them out. I was wondering if a penny had shorted something out. Just a thought...
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    basically what happened to me was that i had kept a st. christopher medal my mother gave me in the ash tray. one day it feel into the cig lighter and when i tried to plug in my radar detector, it obviously didnt work. once i got the medal out, it still didnt work. It seems to me that this story screams of a blown fuse yet i dont see one. nothing seems broken within the lighter either.
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    finally found the blown fuse. it was under the name
    front electrical outlet instead of cgi lighter. stupid mistake
    Aug 18 2009
    A Unicorn
    Portland, OR
    Ha ha. Nice. Funny is I think mine says cig lighter... I think
    Jan 12 2013
    New York
    Hi, I have a 06 a4 cabriolet with the exact same problem. All my cig lighters work except the one under the climate control. I pretty sure it just has a blown fuse. Check the cigar lighter fuse already and it still in it best condition. Obviously, this lighter doesn't share the same fuse. Where did you find the fuse for the lighter under the climate control? Please help.
    Active Member Four Rings wahpao's Avatar
    Nov 01 2006
    SNJ
    When u open your drivers side door, theres a panel at the end of the dashboard you have to almost pry open. You can check a fuse chart in your manual. I'm pretty sure it's a 20 amp fuse (yellow).
    08 Avus Silver RS4 Ti Package - SC'd
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    Quote Originally Posted by Jim1988 View Post
    Did you read two posts above yours? Did you check the fuse named "front electrical outlet"?
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
    Jul 17 2013
    2006 A4 Quattro 2.0 Turbo
    Salt Lake City, UT
    I've got a B7 A4 with the armrest outlet not working. Same deal here: dime fell into outlet while empty. I've checked all the fuses and they're all good. The light around the outlet still lights up. Bought a new iTrip thinking that was the problem but still nothing. Any thoughts on this here problem? Thanks!
    Jan 29 2011
    Toronto, CA
    Quote Originally Posted by busky_j View Post
    You sure you checked the "Electrical Socket Front" fuse and not the "Cigarette Lighter" fuse? Even if you did, try replacing it. These fuses are really cheap.
    As for the light, it's a different circuit than the lighter itself so it means nothing. The light comes on and off with the headlights whereas the cigarette lighters are always "ON".
    Jan 29 2010
    north ga
    Bumping an old thread....
    My cigarette outlet is messed up, and who knows how it happened. Its been dead for a year or two now, so I can't charge my phone.
    I recently went to check it again and of course found the fuse blown, so I replaced it. I used the lighter to test it and as soon as I pressed the lighter in, I heard the fuse POP! I replaced the fuse again and the next one blew soon as I tested it again. I did this once more then started trying higher amp fuses. I believe the fuse is a 10 amp, so I tested and blew a 15amp, 20 amp, 25 amp, and the 30 or 40 amp didn't blow (at least not right away) but it also did not make the outlet work.
    Any ideas where the line could be shorting out? It seems like that has to be the issue.
    Feb 04 2016
    London
    God damn. Don't keep putting higher rated fuses in, you'll burn your car down to the ground!
    Now there's 3 things that could be fucked. Your lighter socket, the thing you're jamming into it, or the wiring. Start with the easiest and work back.
    Jan 29 2010
    north ga
    Its a 1-second test, I'm pretty sure the car will be fine.
    It was more just a way for me to laugh at the situation since I had some random fuses in the center console and I was curious to see how many I could blow before I found the limit.
    Unless I find a spare lighter socket in my pile-o-parts I can't really swap it out. And I've tried several chargers, lighter that I know work. I was asking to see if anyone knew a common spot it could be shorting out at.
    Jan 29 2010
    north ga
    Fixed
    I got the socket out to find that there was a tiny piece of metal wedged in the bottom. I'm about 90% sure that the piece of metal came off a Bic Lighter. I always rip off the child safety piece when getting a new lighter and they often shoot in the air when you pry them off. Likely it found its way down in the hole and caused a short the next time I used the socket.
    Jan 02 2017
    tennessee
    mine had the same problem i removed the ashtray and found the connector was not connected
