Originally Posted by
ignus99
So like many others, I am absolutely in LOVE with the piano black trim but can't justify spending over $300 for a set of them, plus giving up my stock trim.
This being said, I've decided to paint them.
BUT - my painting has very limited background... using plasti dip to paint my winter rims, touchups on parts that arnt typically shown, or engine bay stuff.
anyone have TIPS for me? I am assuming i'll need to bondo the stock trim as there is a cross hatched pattern that would show after painting, and methods for prep, paint, clear, or specific types of paint i need (preferably from a rattle can) to ensure the best glossy finish.
THANKS!
If you are going to paint them it's pretty easy.
First this is very important. Work in a clean area you know will not get dirt, dust, or any kind of foreign objects in the paint.
Get some acetone and green bristle pads and take the fish scales off. Scrub the hell out of them. but not to hard because it will scratch the metal, this is okay. :)
LIGHT LIGHT LIGHT coats of black. DO NOT GET IN A HURRY!! When I say light, I mean you can see the silver clearly but the black is apparent.
Repeat x like 5
Once you got the trim completely with very thin coats ( you should be on coat 4 or 5 by now)
Take some very find sand paper - like 6-800 and sand it down under water with a bit of soap.
Clean it up and be careful to apply even pressure and sand evenly throughout the process.
If you sprayed it right, you should expose some of the silver underneath.
Now the process is spray it more, sand it, spray it, sand it spray it. Overall I would say 8-10 coats of light paint is right.
once you are happy with the gloss black take a can of clear coat and simply follow the instructions on the can. Usually it's 2 coats within 40 minutes (that's what mine says) if you want to polish it out then go for it, same process as above but use much higher grit paper like 15-3000. Now you could probably use lacquer on it but I'm not sure how it would react to paint (might wanna test it on an easy to re-paint piece)
Repeat for all pieces.
