Results 1 to 2 of 2
    Oct 01 2007
    Chicago
    Replacing front brake pads, 2010 Audi A5 2.0T
    Any special tools I need to replace the front brake pads?
    Also any DIY on replacing them?
    Senior Member Three Rings ChipB's Avatar
    Nov 04 2009
    '21 BMW X5, '16 BMW M4
    Morristown, NJ
    Changing front brake pads is relatively easy - no special tools required. Here's a link to a DIY:
    http://www.a5oc.com/forums/audi-a5-s...hange-diy.html
    Steps 6C and 8 are not needed if you are replacing only pads and not the rotor.
    One thing to watch out for is the brake pad sensor on the front left caliper - if you're going to reuse the existing sensor be careful not to lose the little copper spring bit that is on the end of the sensor.
    '24 RS5
