Results 1 to 23 of 23
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    average price to press in new wheel bearings?
    i got quoted 45 a side to press in some new bearings if i bring them the hubs? sound about right or high? i usually diy, but my press broke. for 90 i might just go get a new press from HF.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    ^Yeah, Dimcorner helped me w/ my RF bearing this past weekend, and he brought the same kit with him... I couldn't imagine trying to fit our spindles into a press . The only complaint I had with the kit is that the cap-nut had a cheap little plug weld that sheared off after a few turns, so the bolt unscrewed itself once you really start cranking on it. Nothing that a quick bead w/ my mig welder didn't fix, but the nut & bolt really should be cross-drilled w/ a shear pin IMO.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    i never used the tool... and was able to press on my press at the garage... issue is being safe with the new bearing and having the proper press pieces... luckily we had a bunch of old audi / vw bearings and races laying around. I was able to press it out, but it took a good amount of force.
    problem is a 90 press from HF will probably break while doing the job... i broke the support between my press legs (another handy MIG fix) and it is a lot more heavy duty than the HF... my bearing was seized in there good. just food for thought... craigslist a quality press!
    Feb 13 2004
    S Ã C, CÃ*
    hmm.. wonder how hard that tool will be for me, i have the hubs off already. switching to alum uprights so they havent been mounted to the car yet.
    Veteran Member Three Rings 1NaudiA4's Avatar
    Feb 13 2007
    98 A4
    Chicago
    I was charged $48 a hub for pressing in bearings so sounds about right.
    Feb 06 2010
    Albuquerque NM
    20 bucks or so at a local shop with a press.
    Veteran Member Three Rings Matt Danger's Avatar
    Jun 04 2007
    B5 S4
    ROC NY
    $45 per side? Buy a new harbor freight press.
    770r B5S4 home built & tuned
    Veteran Member Four Rings Korben007's Avatar
    Nov 08 2007
    00 Celica Supercharged, 02 S6, 04 S4 Avant
    Lake Tahoe, CA/NV
    I paid 150 to get all 4 pressed on my CQ. Well worth it considering they amount of time i have spent doing it myself with my own press.
    Sent from my DROID BIONIC using Tapatalk
    Current Rides:
    2000 Toyota Celica GT-S Supercharged - 2008 Audi A3 VRT(SOLD) - 2003 Audi RS6 Avant - 2013 Audi Q7 Prestige
    2000 Audi S4 Stage 3(SOLD) - 2008 Audi TT 3.2 (SOLD) - 2002 S6 Avant Manual w/ S8 PES Supercharged - 2015 Porsche Cayman GTS
    1990 Audi Coupe Quattro(SOLD) - 1993 Toyota MR2 Big Turbo(SOLD) - 2001 Audi S6 Sedan (SOLD)
    @audijedi
    Feb 13 2004
    S Ã C, CÃ*
    Looking at the tool closer, it wont work for the alum uprights as the bearing is bolt in. What i really need to do is remove the hub from the old bearing and push the old hub into the new bearing.
    May 13 2011
    2015 BMW F30
    Im buying this tool for when the time comes.
    | Autospeed | JHM | Pure MS
    Dec 30 2009
    The tool will work to press in the hub too, should work on the bolt ins on the car. Look at the hub press in setup pic I have there.
    2001.5 S4 Sedan
    2018 Q5 2.0t
    Veteran Member Four Rings Gujuhammer's Avatar
    Oct 07 2010
    02' Avant
    Florida
    Where did you guys source your wheel bearings? Is there a kit for all 4? I assume OEM is the way to go.
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by Timtheguru View Post
    But how did you remove the hub?
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    With the tool you don't have to remove the hub. We didn't even use air tools to do BiTurbo's bearing.
    I have done mine and his so far with the tool and it's all gravy. Just make sure you have the big socket for the large nut at the end. We ended up renting a set from Pep Boys.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by Dimcorner View Post
    S***... I just remembered I haven't brought that back yet
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Feb 13 2004
    S Ã C, CÃ*
    guess im not getting how the tool works, but how do you replace the bearing if you dont remove the hub? the hub is pressed into the bearing.
    2nd this tool + mg725 = win
    May 16 2008
    South Texas
    $45 a side is not bad, but for now much more you can buy a mini shop press and do it yourself then in your off time us it to squish various things around the house (barbie doll heads, spam, coke cans etc).
    Jul 28 2008
    Pittsburgh PA
    Quote Originally Posted by infinkc View Post
    agreed... the tool link clearly says remove hub? I also think some cars are easy and some not so much... took me literally 4 times to attempt to break my caliper bolts on my front brakes... i'm sure others did not have as nasty of a time.
    I know that pressing my hub out of the bearing took TONS of force (breaking my press support on first attempt) and popped like a son of a bitch when it let go...
    Mar 08 2007
    Mr. Worl-Wye
    ^Its actually really easy guys. You just use one of the smaller diameter plates on the inside of the bearing and a larger one on the outside that pulls against the spindle, and then the opposite to get it back in (you're tightening the bolt either way). Once you have the tool in hand it's easier to understand.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Sep 27 2007
    Columbia, SC
    Ok let me see if I can explain...
    1. Loosen the top of the hub to move aside the axle out of the way. I then just put the top 2 arms and steering column back in place without tightening in order to get leverage and not have the hub just flapping around.
    2. Remove the spindle? (thinggy that the wheel bolts on to) This will more than likely split the bearing apart since the inner race of the bearing will be stuck to the part. Clamp down on table vice, heat race with torch, place claw side of hammer against race, tap head of hammer with another hammer and it will come off really easy.
    3. Place a flat disk from the kit that is smaller than the opening, but still touches the outside of the bearing in the back of the hub. In front you put the large cup looking thing with it's accompanying metal disk. Put the screw thru it and start tightening. This will tighten the back disk and pull it thru the hole along with the bearing.
    4. Press in new bearing. Use a large disk that is larger than the back of the opening of the hub and a disk in the front that is smaller than the opening, but still touches the outside ring of the bearing. You can go safe route (which is what i did) and use 2 larger than hole disks first to press in until it's almost flush, then switch to the smaller than opening/large enough to press outside of bearing plate.
    5. Press spindle in by switching the back plate to one that is larger than INNER metal ring but smaller than the outer ring on the back. Front you can use any size larger than the opening.
    6. Done.
    I have some pics if you want to see.
    96 Soarer GT - Gone
    Sep 27 2007
    Columbia, SC
    Quote Originally Posted by BITRBO View Post
    You better go today. I think it's only 5 days you have for that.
    96 Soarer GT - Gone
