Results 1 to 30 of 30
    Sep 20 2011
    Florida
    2007 RS4, Milltek Recommendations??
    Hey guys, i've had my RS4 for a little over 2 years now and it's time for a Milltek Exhaust System. Any recommendations? I think I want to do resonated....if anyone has any videos i'd love to see them as well. What exhaust do you recommend? Thanks guys
    Nov 10 2009
    GM trucks/vans(OBAMA motors)polaris 4 wheeler,urinal,dart board,wash bay
    American Gardens Bldg(midwest)
    Ah... I think you could do much better than that for your Rs4 personally. Im sure others will be along shortly with suggestions. plenty of topics on here already via the search function. good luck.
    PB.
    "I CANT SPECIFY BLONDE ENOUGH" 2013 S4.(REPURCHASED BY AOA FALL 2013!!) 6MT,Monsoon.Sport diff.SS texture trims.Awe catback|Eurocode STS|AluKreuz|sways/links|3m crystaline windshield tint 70%crystaline/sides&rear pinnacle 35%ceramic|HR O.E.springs(Garbage)|Tyrol Caliper Sliders|SS Lines|S-Flo intake|Clear bra|Vag Com Mods.
    Liscense plate delete/...and some other shit im forgetting.
    2008 Porsche Carrera 4S. 6MT. Daily Driven grins ear to ear.
    Sep 13 2008
    Western Chicago Burbs
    Call up JHM. Miltek is just as bad of a design as the OEM system, and the quality is probably worse. Search around the B7 RS4 subforum
    Active Member Four Rings BenSti's Avatar
    Nov 03 2010
    Cupertino, CA
    Milltek is garbage quality. Parts are not symetrical, fit is shitty, but it does sound good.
    2008 Audi RS4 Ibis White w/ Ti Package | 18x10.5 TCIII w/ 275/35 NT01 | PSI Raceline Ohlins | Stoptech Trophy Brakes F/R | Raybestos ST47 | OSGiken 1.5Way Rear LSD | Wavetrac Front LSD | Apikol Diff Mount | 034 Billet Subframe Bushings | 034 Motor Mounts | 034 Aluminum Trans Mount | 034 Spherical UCA | 034 Front Endlinks | JHM LWFW&Stage 4 Clutch | JHM Shifter+Linkage | Custom CAI | Custom Splitter | Hotchkis Sways F&R | Status Ring GT Seats + Half Cage | 034 Rear Endlinks | EBW LW Battery
    Established Member Two Rings B7S4Man's Avatar
    May 31 2007
    08' Phantom RS4
    San Francisco CA
    I put a GMG on mine and it fits and sounds great. gmgracing.com. Good luck
    Senior Member Three Rings patastinky's Avatar
    Apr 07 2011
    2015 Overland
    EARTH
    1st off anything other than OEM is going to give you fitment issues. So lets be real about that. 2nd the Milltek is an awesome sounding exhaust, especially if you pony up for the DP's as well (Milltek). My buddy has an 08' RS4, he is a member of this forum and purchased a new Milltek Non-res catback a little over a month ago. The car sounded awesome! I mean simply AWESOME! Nice growl on start up, after it warmed up a bit it just sounded like a monster! I have the same exhaust (except i own an S4 Avant so i have the s4 avant version) and the difference in sound; idle, full throat, etc. are night and day (compared to mine). Last week he slapped on the Milltek Dp's and APR tune. The car sounds... sounds.... sounds.... just EPIC! I mean it's "throatier" (if that's even a word), the power is there as soon as you get on the gas. It simply roars through the entire RPM range. I mean this exhaust really complements the V8 and it's symphony of sounds.. There was a minor fitment issue at 1st when he had the exhaust installed at a local shop. However that "minor fitment" issue wasn't even noticeable at all. Only if you took measurements would you see that it was off alignment just a tad... At anyrate, Jaime from XLR8 (Branford, CT) took care of that. With that said, anytime anyone posts a thread on Audizine about "exhausts" everyone is going to say "Go 2.50", "Go JHM". What they should be posting (along side that information) is personal experience (like BenSti). I don't think you will be disappointed with the performance, fitment and sound of the Milltek. You should take your time and start your research here on exhausts. This is a great forum with a lot of great people who contribute there time and knowledge to help others. Then after reading what people say try to link up with locals in your area that have an RS4 and see what they got. I just felt like i had to put in my 2cents because there is so much bashing going on, on anything other than 2.50 diameter for exhausts. Milltek in my personal experience is a great exhaust and should definitely be considered..
    btw.. disregard my for sale thread below in my sig
    2015
    SOLD
    JHM 93 tune * JHM Solid Short Shifter * Custom Catless downpipes * Milltek non resonated cat-back exhaust * H&R Sport Springs * VMR 708 RS4 replica's 19x8.5 *
    Deactivated Three Rings
    Aug 08 2011
    Fairport, NY
    I've installed both RES and NON-RES versions. I vote non-res. The sound is awesome and inside the cabin is very civilized. Milltek systems are generally regarded as one of the better fitting exhaust systems. Go ahead and ask any shop thats had experience with Milltek and any of its competing brands.
    The non-res system with valves is nice. Gives you major control with the Sport mode button.
    Here's one of my fav vids:
    Senior Member Three Rings Gareth_oau's Avatar
    Mar 13 2011
    Perth Australia
    here's mine before and after the Milltek valveless non-resonated catback
    It is loud and I love it, and unless you want to be extra subtle, then dont bother with resonated.
    Dec 05 2006
    So. Cal.
    I've got a valved non-resonated Milltek on my RS4 and I love it. It's a great system and one of the only ones with the valves. The fit and finish are fine for an exhaust system. Keep in mind that the pipes aren't polished, only the cans are.
    Whoever says that the fitment sucks doesn't have the patience to dial it in. Like many aftermarket systems, you'll have to tweak with it for a while to get it to sit right. I've installed many exhaust systems on Audi's and they all require some tweaking to get them to sit just right.
    Keep in mind that the Milltek is a handmade system. How many other systems claim that?
    Sep 13 2008
    I
    For one, the 2.75" JHM system
    Aug 08 2011
    Fairport, NY
    the silencers (mufflers) are hand assembled. They dont use another manufacturer's silencers. I think thats what he may have meant. I searched "exhaust" on the JHM site, it didnt come up.
    RAudi Driver,
    Have you had the RS4 for a while? Didn't you have an S4? What did I miss?
    Senior Member Two Rings Trogdor1464's Avatar
    Apr 20 2011
    IL
    I've run Milltek on my previous two cars and the fitment was always spot on. What's up with the quality bashing? You guys act like you're gonna be eating off this shit, or driving around with mirrors mounted to the bottom of your car. Gimme a break! The quality/welds are not THAT bad. Now I have to agree, the pipe size for this car is a little on the small size. Don't plan on making a lot of power with it but I've never been disappointed with their sound. As far as JHM goes, is their exhaust even available yet? It's not on their website.
    Dec 05 2006
    So. Cal.
    Quote Originally Posted by Greg@Griffin View Post
    RAudi Driver,
    Sold the S4 in March of 208 and picked up a new Sprint Blue/titanium package RS4. I think JHM is using the Sebring cans like Fast Intentions.
    Aug 08 2011
    Fairport, NY
    that thing is pretty bad ass....
    Veteran Member Four Rings boravr6's Avatar
    Aug 14 2008
    09 CTS-V
    Ontario
    Quote Originally Posted by zhoffman9 View Post
    Take a look here before you commit to anything!
    http://audirevolution.net/forum/index.php?topic=56.0
    ** Proud to support **
    JHMotorsports
    AUDI Revolution
    ~ 2009 Blue Diamond Tricoat CTS-V
    ~ 2006 TD1 Imola B7 S4 sedan 6MT *SOLD*
    ~ 2004 Silver B6 S4 sedan 6MT *SOLD*
    Aug 08 2011
    Fairport, NY
    I'll add a couple things...
    1. look at the massive crimps on the stock system where the pipe enters the rear mufflers.
    2. Milltek is larger that stock.
    3. H pipe is used for sound.
    4. Milltek mufflers are WAAAAY less restrictive that stock. Cut open the stock muffler, you'll find something similar to this:
    Nov 03 2010
    Cupertino, CA
    The point is, if you are going to spend money on new exhaust, you should get something that actually has decent gains, and is good fit/finish.
    My Milltek is very low quality, the clamps are shitty, they don't hold it very well, and if you tighten them down enough to hold it, they dent the piping. The connections from the H-Pipe to midpipes are too close together so the clamps get seized up.
    Mine is for sale if you want it, it can be made to fit well, but it takes more work than it should. It is probably the best sounding system out there. I get compliments on it nearly every day. My friend is making me a custom system with 2.75" downpipes and exhaust.
    Mar 13 2011
    Perth Australia
    you would also need to throw a Tubi into the consideration mix:
    Sep 13 2008
    Added some quotes from the thread boravr6 linked to:
    Quote Originally Posted by technical assistant
    I thought this would be fun.
    One of these is 1600$ and the other one is 160$
    Milltek
    Stock exhaust mod.
    Ill let you figgure out what one costs what.
    Quote Originally Posted by CountVohn
    This should help give a little perspective from stock/milltek to the size difference in the 2.75 JHM exhaust
    JHM on the left milltek/stock on the right.
    I don't have more pictures but this shows the jhm catback
    Joe. Well pointed out. This is what happens when you try to run production parts off a machine there is a compromise of quality.
    I don't think milltek put too much thought into it. I think they say a cheap way to tie in each side of the exhaust and they went for it. Maybe Im not giving Milltek enough credit but I just don't see why they would charge tons of money for the same dia exhaust and do little to no changes
    Senior Member Two Rings karsty's Avatar
    Dec 10 2010
    Edmonton, Alberta Canada
    Man, I wish JHM would email me back. I want there exhaust on my RS4 so bad! Anyone have any more pics of what the JHM catback looks like? Any vids(aside from the one from JHM and I think one other one online)?
    Sep 13 2008
    Quote Originally Posted by karsty View Post
    They're moving to a bigger shop over the next few weeks so that combined with the s/c release and all the RS4 stuff going on, they're swamped to say the least. Just try to call them a few times
    here is some JHM RS4 vids:
    Dec 10 2010
    Thanks for the vids! I'll try calling them.
    Veteran Member Four Rings NY07RS4's Avatar
    Aug 14 2009
    RS4
    the last vid...tisk tisk on the neutral shift!
    RS4 : K&N : HPS & Stop Tech : DTH Cover : 30% Tint : Tubi Rumore (SOLD!) : Audi Sport Rubber Mats : H-Sport Sways F/R : Stern UCA's : JHM L/W FR & RR : JHM I/M Spacers : JHM LWCP : JHM FULL 2.75" : JHM 3R & LWFW : JHM Tune : JHM Cross Rod : JHM SS : 034 MAF & USM's : 034 Trans Mount : USP Slave & SS Line : Ohlins SL C/O : Stop Tech SS : Apikol Red Diff Mount : HOEN H11 Fogs : LED : MTM 10MM : F Plate Delete : CC Mod
    Veteran Member Three Rings WerkzRS's Avatar
    Apr 13 2005
    B7 RS4, B8 SQ5, Jeep JK
    LA/IE
    JHM exhaust looks pretty sweet, I have the Milltek on my RS right now no fitment issues and when inspecting the whole exhaust i didnt see any crappy stuff. Im pretty sure JHM may be better due to it 2.75" sizing but thats about it. I think they all are great just a matter of how your building your RS? only two types MILD or EXTREME builds...
    2007 RS4 Daytona Gray, 80K (11/01/17) Ohlins/Statsis MS coilovers, ZIZA LED Interior, Milltek DP. w/ Non res valved catback, RNSE 2010-11 upgrade w/ AMI Integration and airtunes adapter (stream music), Euro TTRS steering wheel, Valentine Hardwired, WORK Emotion Cr Kiwami 19x10.5 ET 22 265/30-19..........scared money, don't make money!
    Senior Member Two Rings pierl's Avatar
    Jul 13 2011
    audi RS4
    vancouver
    don't know what's the big fuzz with the muffler\exhaust line.. its mostly personal taste and sound..Clearly the JHM one will give you more power.. But if your'e after noticeable gain..
    downpipes and a tune will give you the most pony for your money (and I would go JHM no doubt)
    this thread smell like the M3forum
    Established Member Two Rings b6scott's Avatar
    Sep 06 2010
    nj
    miltek's mount and look like shit....... AWE FTW
    2007 RS4 Unitronics tune, AWE down pipes and exhaust,body matched reflectors, tints, xenon interior bulbs, ported and polished intake manifold, K&N filter, De-Flapped, AC glove mod, ,JHM short throw ,JHM f/r rotors, JHM lightweight flywheel, JHM stage 4 clutch, JHM solid shift linkage, blackout headlight housing+CC mod, kmd catch can - gone
    2001 b5 s4 stage 3 minus - 12.61@108mph
    Aug 08 2011
    Fairport, NY
    please explain? every system i've fit on the RS4 has fit perfectly.
    Dec 05 2006
    So. Cal.
    ^^It's because you know what you are doing and are experienced. I had no problems with mine either
    Nov 03 2010
    Cupertino, CA
    I think it may be because you sell the exhaust. Mine is defiantly not symmetrical, I have it fitting pretty well now, but it is still not perfect.
    Aug 08 2011
    Fairport, NY
    Quote Originally Posted by BenSti View Post
    Yeah, its not exactly symmetrical. Its that way because of the way they initially design the systems. Its pretty cool the way they do it, but it does result in the two sides being asymmetrical. The slip fittings add a ton of adjustability. A few degrees of rotation in the center pipe can raise/lower the tips by quite a lot.
    In a lot of cases, Milltek doesnt have as large of diameter systems as some other manufacturers. That has always been because they've tended to keep their systems on the tame side and also to keep the gains somewhat equal between tq and HP. In the past couple years, they're trending towards building larger dia. systems (on applications that allow it) because thats what people in the N. American market see value in. Keep in mind, Milltek is in the UK where the requirements/laws are different and so is the customer base. Milltek sells globally and the N. American market is really very different and quite unique. A lot of the systems Milltek makes end up on cars that see alot of track time. In lots of areas, tracks (and governments) impose dB restrictions. Milltek has long since had a reputation of being on the conservative side. Their choice in diameter and balance pipe configurations is done to create a compromise between quality of sound and performance. If you notice, the majority of the people that have gripes with Milltek seem to be the younger guys. Nothing wrong with that, they're just the ones that are usually taking the cars to more aggressive levels of tuning.
    Why am I saying all this? Because, a few people have questioned Milltek's reasoning behind the diameter and design of their systems. I sell and endorse their products NOT because I have to, but because I choose to. I've been involved with Milltek for over 8 years and I'm proud to say that. I hope that we can all respect that people have different tastes and we're all entitled to that.
    -Greg
